Garg435698
encryption
Fri May 29, 2020 2:09 pm
Is there a good summary of available options for Raspbian full-disk encryption for the Pi 4's SD card, and for any attached hard drives (e.g. for an NAS server)?
Kendek
Re: encryption
Fri May 29, 2020 3:08 pm
I think there are two evaluable options; dm-crypt with LUKS, and fscrypt.
For performance reasons, I recommend using Adiantum in both cases:
CONFIG_CRYPTO_ADIANTUM=m
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_NHPOLY1305_NEON=m
CONFIG_FS_ENCRYPTION=y
> sudo cryptsetup luksFormat --type=luks2 --sector-size=4096 -c xchacha12,aes-adiantum-plain64 -s 256 -h sha512 --use-urandom /dev/device-or-partition
/etc/fscrypt.conf:
	"source": "custom_passphrase",
	"hash_costs": {
		"time": "5",
		"memory": "131072",
		"parallelism": "4"
	"compatibility": "",
	"options": {
		"padding": "32",
		"contents": "Adiantum",
		"filenames": "Adiantum",
		"policy_version": "2"
	"use_fs_keyring_for_v1_policies": true
> sudo tune2fs -O encrypt /dev/partition
> sudo fscrypt encrypt /directory/path
dickon
Re: encryption
Fri May 29, 2020 3:19 pm
Worth noting that there's no hardware crypto on any Pi SoC, so it'll all be done in software and may have quite a hit on performance. CPU-intensive workloads may be hit hard if anything is doing disc IO at the same time, for example.
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
Kendek
Re: encryption
Fri May 29, 2020 3:23 pm
The Adiantum performs perfectly well here. ;)
Garg435698
Re: encryption
Sun May 31, 2020 7:33 pm
Thanks, I'll give it a try.
Re: encryption
Sun May 31, 2020 9:40 pm
True but apparently the latest PIOS has this accelerated using NEON, so should be a bit quicker -would be interesting to see results.
dickon
Re: encryption
Sun May 31, 2020 9:52 pm
Good news. Any idea which algorithms, and is there any attempt to port that to userland libraries?
It'll still have an impact, of course.
Re: encryption
Sun May 31, 2020 10:00 pm
No idea, Eben mentioned it in the blog post, that's all I know.
dickon
Re: encryption
Sun May 31, 2020 10:02 pm
I must've missed that. I'll look.
Ta.
