jahboater
Re: STICKY: Raspberry Pi OS (64 bit) beta test version feedback
Tue Aug 04, 2020 9:34 am
rclark wrote:
Tue Aug 04, 2020 3:55 am
However, tonight I tried to use fstrim command on the T5 and it says the discard operation is not supported. Only reporting this in case this is a bug. I just figured most USB SSDs would support the trim function.
Did you mount the T5 with the "discard" option ?
Pi4 8GB running PIOS64 Lite
rclark
Tue Aug 04, 2020 6:05 pm
I just looked at fstab and don't see it having a discard option. It has 'defaults,noatime'. Should I add the discard option as well?
jlgreer1
Wed Aug 05, 2020 2:03 am
I use a niche software system called Inform 6 and its set of libraries to develop parser based interactive fiction. Inform 6 published an important update within the last two weeks. I am pleased to say that RPi OS (64 bit) already has the updated version available in the repository. The new version compiles as expected.I certainly didn't expect it to be available for some time.
Again a very nice surprise for the new RPi OS beta version.
https://faroutscience.com
xevilstar1
Wed Aug 05, 2020 8:01 pm
I must say I am a happy camper on my pi 4 8G using the 64 version of the system. I thank the team/person that made it.
do you want my tilix and deps debs ?
jlgreer1
Sat Aug 08, 2020 11:07 pm
I have run into a small issue with one of my specialty IF development apps.
It is Zilf 0.9. It runs as expected on standard Raspbian OS but not on the 64 beta.
Zilf complains that the libstdc++.so.6 is not available.
libstdc++.so IS available. I wonder if I made a link to that library if it would work?
Not a major issue, just something that needs to be worked out.
Thank you
Kendek
Sun Aug 09, 2020 6:40 am
If Zilf is 32-bit, then change it to arm64. Or install the armhf variant of the libstdc++6.
sudo dpkg --add-architecture armhf
sudo apt update
sudo apt install libstdc++6:armhf
Sun Aug 09, 2020 7:55 am
Thank you
https://packages.debian.org/buster/libstdc++6
The above provides libstdc++.so.6
Last edited by fruitoftheloom on Sun Aug 09, 2020 8:04 am, edited 1 time in total.
Sun Aug 09, 2020 7:57 am
sudo apt update
Why would you want to mix ARMHF and ARM64 packages ?
Kendek
Sun Aug 09, 2020 8:11 am
The best solution if install the arm64 version of the Zilf. But if it's not possible for some reason (I don't know), the compatible armhf libstdc++6 is available. There are a lot of closed source armhf binaries that don't have arm64 version. And if you want to run an armhf binary that compiled from C/C++ source code, then you will need the compatible runtime libs.
jlgreer1
Sun Aug 09, 2020 9:03 am
Thank you for the input regarding zilf.
I did add the lib but that led to other issues. 64 Zilf binaries are available for x86 linux, Windows and OS X. For some reason only the 32 bit version is available for arm linux. I will try to contact the developer.
Thank you again,
v/r
Jeff
panca
Mon Aug 10, 2020 4:19 pm
So will that give me 64-bit Apache, php and mysql? The 32-bit php has very constrained date-precision - I'd switch for that feature only to be compatible with other servers... Thanks!
Mon Aug 10, 2020 4:54 pm
Yes RaspiOS64 is 64 Kernel & 64 Userland and uses Debian ARM64 as it bases...
Lokathor
Wed Aug 12, 2020 4:00 am
Is the zip file with the 64-bit OS image from May 27 still the latest image?
If so, I assume I should just `apt-get` update and upgrade basically as soon as the system first turns on to get any updates since then?
Wed Aug 12, 2020 4:30 am
It is APT update / full-upgrade / reboot to bring RaspiOS64 up to date:
https://www.raspberrypi.org/documentati ... pdating.md
ggrats
Wed Aug 12, 2020 8:11 am
No, are you sure that's a good option to add? I see people blindly adding it everywhere for anything flash/nand etc.
Unless you can prove with your specific storage it's a good idea, it might not be.
https://askubuntu.com/questions/148877/ ... c-for-ssds
https://www.intel.com/content/dam/suppo ... 02-002.pdf
IMPORTANT: Do not discard blocks in filesystem usage.Be sure to turn off the discard option when making your Linux filesystem. You want to allow the SSD manage blocks and its activity between the NVM (non-volatile memory) and host with more advanced and consistent approaches in the SSD Controller.Core Filesystems:•ext4– the default extended option is not to discard blocks at filesystem make time, retain this, and do not add the “discard” extended option as some information will tell you to do.
SSD firmwares probably manage it better than the OS does.
anubisg1
Thu Aug 13, 2020 9:24 am
any idea when this will be released as stable and officially supported?
brainsys
Thu Aug 13, 2020 10:30 am
"When it's ready" is the boilerplate and sensible reply. Some dev shops work to deadlines. If revenue depends on ir and you can afford to throw resources at unexpected glitches on the critical path - this is the way to go. But it does lead to shortcuts which may fix issues in the short term that cost in the long run. So the RPT sensibly takes a more conservative approach.
Nethertheless, may I chance my luck in asking what the development path looks like, what major milestones need to be accomplished? Is it worth waiting for the upstream Debian 11 release expected next year? Will it likely go on some magical day to general release or may we see some more beta/release candidates en route?
Remember 64 bit is the future for RPi. It's important they get it right rather than early.
Thu Aug 13, 2020 5:20 pm
RPF / RPT never ever give public deadlines..
mrdone
Thu Aug 13, 2020 6:26 pm
Today after the last update of raspberrypi-sys-mods on RPi 3b+ I got the following error over ssh:
Message from syslogd@raspberrypi at Aug 13 17:29:20 ...
 kernel:[27795.904857] Internal error: Oops: 96000005 [#1] PREEMPT SMP
 kernel:[27795.905165] Code: f9400000 36880440 f9400e60 f9400000 (f9401400)
Message from syslogd@raspberrypi at Aug 13 17:34:11 ...
 kernel:[28087.101281] Internal error: Oops: 96000047 [#2] PREEMPT SMP
After that I was not able to connect to RPi over ssh and it seems that it is unable to boot.
jlgreer1
Sat Aug 15, 2020 12:04 am
Zilf - Interactive Fiction update.
I was unable to get Zilf 0.9 to work on this new version of RPi 64 bit OS.
In addition, I was also unable to use Zilf 0.8 with "mono" as worked with earlier version of RasPi
(In previously appeared to work but the compiled files did not parse correctly.)
Jeff
pasman1
Sun Aug 16, 2020 4:48 pm
hi.
i am testing RaspbOS 64bit.
Good job !!! Works faster than 32bit version.
I found one small bug: in game "gweled" there are no sound.
Regards.
RPi4-4GB RaspOS 32, Bootloader: 2020-09-03, VL805: 000138a1
my-pi-x
Sun Aug 16, 2020 6:01 pm
@gsh
Raspberry Pi OS (64 bit) vs. Raspbian
Why are you making the same mistakes as in Raspbian?
Ok, nice to see, that /etc/apt/sources.list is now pointing to debian ...
BUT:
Pi-User got root-rights without password via sudo - WHY?
wpa_supplicant is running twice - WHY?
For what do we need dhcpcd5 ... isc-dhcp-client ist still working on the device ... - WHY?
Is it a Beta or Alpha?
:shock:
mrdone
Sun Aug 16, 2020 6:42 pm
May be someone got the same issue. I just got new RPi 4 with 8Gb. When I start with the new image of Raspberry Pi OS 64bit, VNC server works fine out of the box. However, when I update the system with sudo apt update and sudo apt upgrade it stops working. My Windows computer says that connection was refused by the other computer. I know that initially VNC server was not supported in 64 bit OS version, but as I understand by now this issue was resolved and it should work. Moreover, it works just fine on my RPi 3b+ with 64 bit OS.
Any suggestions?
rubenrp
Tue Aug 18, 2020 4:57 pm
I have the issue with the VNC server not running after an upgrade as well. There is some more relevant information here:
https://github.com/raspberrypi/Raspberr ... /issues/86
If anyone has a way to fix the problem with the missing libmmal.so.0 library, it would be greatly appreciated.
6by9
Tue Aug 18, 2020 5:17 pm
MMAL isn't supported on 64bit builds at present.
I have no knowledge of why VNC server is using MMAL - it isn't required for screen scraping. They may be using it for video encoding, but I thought they normally used their own (proprietary) codec instead of H264.
