PiUser10
Re: STICKY: Raspberry Pi OS (64 bit) beta test version feedback
Thu Jul 02, 2020 7:42 am
Just ran a sudo apt update && sudo apt upgrade which updated chromium from ver 80 to ver 83
It is now so slow as to be unusable.
Check chrome://gpu and still shows accelerated but webgl aquarium test has dropped from 20-23 frames
to just 10-13 frames.
Disabled all extensions no change, cleared cache no change, reboot Pi no change.
Even just getting the settings page to display takes an age so it is not down to internet connection.
CPU load is showing at 90%+ during page rendering , even for the settings page.
Ran Firefox and it's performance is normal.
Anyone else having issues with this version of Chromium on Pi OS beta 64 bit ?
P.s I am running vc4-kms-v3d-pi4 and not vc4-fkms-v3d if that makes a difference, I will try
the fkms mode to see if it has an effect on the results.
Running on Pi4 1.4 8Gb model.
PiUser10
Thu Jul 02, 2020 7:51 am
Follow up to chromium update issue problem persists with either fkms or full kms dtoverlay.
dickon
Thu Jul 02, 2020 8:54 am
Is Chromium, like VLC, one of those packages that Pi Towers has made extensive modifications to, to accelerate it on the Pi? If so, you've probably just pulled in an unoptimised, updated Debian version.
PiUser10
Thu Jul 02, 2020 9:05 am
That is a possibility, I just assumed that the repro system would only use the Pi optimised versions.
Is there an easy way to regress the update and prevent it happening again for future chromium package upgrades ?
PiUser10
Thu Jul 02, 2020 10:03 am
The only version of chromium listed via apt list for 64 bit is the 83. version so can't select an older one to regress to.
I ave tried re-install the chromium-rpi-mods but this did not fix it.
However I tried running the current 83 version from the command line and got the following errors :-
/usr/lib/chromium/chromium
MESA-LOADER: failed to retrieve device information
[30677:30690:0702/105343.939362:ERROR:nss_util.cc(283)] After loading Root Certs, loaded==false: NSS error code: -8018
MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
failed to load swrast driver
Which I think may be the cause of the issues
Anyone able to shed any light on this ?
brainsys
Thu Jul 02, 2020 10:12 am
This may be part of a message it's time to move on from Chromium. I did - my browser history was Lynx -> Mosaic -> Netscape -> IE -> Chrome(ium) -> Vivaldi.
There isn't a proper released modern V3 ARM64 variant. I couldn't get the 'secret' V2/ARM64 to work but Vivaldi V1/ARM64 appears to be working OK. This is only Day 2 of my BETA experience but generally impressed so far. RPI 4/8GB.
Which leaves the interesting question of what browser should be bundled into the final release of PiOS64? The PiOS32 struggles with Chromium and is taking resource from the Foundation but under-delivering - ie being stuck on older versions.
idpitt
Thu Jul 02, 2020 11:40 am
Yes. Had the same issue this morning. Will need to roll back the update since Chromium 83 can't even load Gmail without crashing out ( after a few minutes of failing to load ).
PiUser10
Thu Jul 02, 2020 11:51 am
I was unable to find a method of rolling the update back, let me know if you succeed and what commands you used.
I hope someone from the Pi development team can correct this version of chromium browser (it will need to be fixed before the beta goes to supported version).
I have installed Vivaldi from the arm64 .deb file (as detailed in rely from brainsys above) and it flies along (basically chrome 83 with a skin on steroids)
with full acceleration enabled.
idpitt
Thu Jul 02, 2020 12:55 pm
Same issue as you - can't reinstall the 80 version completely ( at least not in the 5 minutes I had to try this out ). This happened to me on Sakaki's Gentoo build too which ultimately caused me to ditch the Pi as a casual browsing device due to it's fragility of this kind. Up until this point, the 64 bit beta experience has been outstanding on an 8GB unit. If necessary, I'll do a re-image since the set up I have is pretty straightforward.
PiUser10
Thu Jul 02, 2020 12:57 pm
OK to answer my own question I downloaded the following .deb files from debian ftp mirror
chromium_80.0.3987.162-1_deb10u1_arm64.deb
chromium-l10n_80.0.3987.162-1_deb10u1_all.deb
chromium-common_80.0.3987.162-1_deb10u1_arm64.deb
chromium-sandbox_80.0.3987.162-1_deb10u1_arm64.deb
chromium-driver_80.0.3987.162-1_deb10u1_arm64.deb
chromium-shell_80.0.3987.162-1_deb10u1_arm64.deb
Then I ran
sudo apt install ./chromium_80.0.3987.162-1_deb10u1_arm64.deb ./chromium-l10n_80.0.3987.162-1_deb10u1_all.deb ./chromium-common_80.0.3987.162-1_deb10u1_arm64.deb ./chromium-sandbox_80.0.3987.162-1_deb10u1_arm64.deb ./chromium-driver_80.0.3987.162-1_deb10u1_arm64.deb ./chromium-shell_80.0.3987.162-1_deb10u1_arm64.deb
which downgraded the chromium browser to the working version 80
(I think you may only need 3 of the above files chromium, chromium-common and chromium-sandbox as these were the only 3 downgraded the other 3 were just installed as new packages)
idpitt
Thu Jul 02, 2020 12:59 pm
Then I ran
Thanks. Will do this sometime today.
brainsys
Thu Jul 02, 2020 7:14 pm
Yes - that's a pretty elusive beast. Finally located 3.1.1929.45 as: https://downloads.vivaldi.com/stable/vi ... _arm64.deb. Installed nicely and now synced with the rest of my RPi and non-RPi clients.
Enjoy.
washran
Thu Jul 02, 2020 8:01 pm
The Chromium Browser was working fairly OK for a few weeks and now it's choking up. I switched to Midori and it works pretty good. I'm using # Version 83.0.4103.116 (Developer Build) built on Debian 10.4, running on Debian 10.4 (64-bit) ... It's not functional at all...
washran
Thu Jul 02, 2020 8:24 pm
I decided to download the Vivaldi Browser. It works better than Midori and Chromium at this moment.
idpitt
Thu Jul 02, 2020 8:58 pm
Then I ran
Sorted. Many thanks.
malchore
Contact: YouTube
Fri Jul 03, 2020 4:43 am
Then I ran
Thank you. This worked well. I had a lot of trouble finding the packages on the debian ftp mirror but once I did I downloaded them and installed.
PiUser10
Fri Jul 03, 2020 10:18 am
If you want to continue to do apt upgrade and not have the standard chromium packages updated from
version 80 to the faulty version 83 then issuing the command
sudo apt-mark hold chromium chromium-common chromium-sandbox
should stop them being updated until they are manually released again via
sudo apt-mark unhold chromium chromium-common chromium-sandbox
sakaki
Fri Jul 03, 2020 5:04 pm
Just fyi (and with apologies for the OT!), the current (v1.6.0) release of gentoo-on-rpi-64bit ships with v84.0.4147.30 of Chromium. This gets ~25fps @ 500 fish @ 1024 pixels, but you do need to turn off window manager compositing (Applications -> Settings -> Window Manager Tweaks; Compositor tab) for best performance. Screenshot below captured on an RPi4, using fkms:
Also seems to run gmail without any particular issues.
hth, sakaki
rwcooper
Fri Jul 03, 2020 6:49 pm
Then I ran
Where did you find these files and how did you get them? I've been searching for a couple of hours but can't seem to find them. Thanks...Randy
rwcooper
Fri Jul 03, 2020 7:07 pm
PiUser10 wrote:
Fri Jul 03, 2020 6:56 pm
You will find them at :-
http://ftp.br.debian.org/debian/pool/main/c/chromium/
Thanks! I got them. I'll try installing only the 3 files on my test system...Randy
digitalecloud
Fri Jul 03, 2020 7:17 pm
mistermix wrote:
Fri Jun 19, 2020 4:12 am
I'm testing the 64-bit version here and removed everything from the desktop packages transforming into a lite version and it's running smoothly
using open media vault + kubernetes k3s, low processing, running several pods and no problems, to run local server is very good, good work.
I signed up here today just to thank u, and I'm waiting for an official Lite image, it could even be beta too :)
- Does it shows the right processor within OMV?
- Docker do not show ram disk usage
rwcooper
Fri Jul 03, 2020 7:41 pm
Installing the 3 files you suggested worked great! Thanks...Randy
bingyd
Fri Jul 03, 2020 9:44 pm
Trying to revert Chromium to 80
Have downloaded the chromium 80 files into home/pi/Downloads, but when I try the sudo apt install get an error E: unsupported file.
Do I need to load them into another directory or change properties?
PiUser10
Fri Jul 03, 2020 9:52 pm
Make sure you have downloaded the files ending in _arm64.deb (64 bit for beta) and not _armhf.deb (32 bit for non beta)
Then in terminal session change to the directory containing the files (normally Downloads) and run the sudo apt command.
If it still fails the downloaded files must be incomplete or corrupt I guess.
