mahjongg
Re: STICKY: Raspberry Pi OS (64 bit) beta test version feedback
Tue Jun 09, 2020 4:08 pm
rasp14 wrote:
Tue Jun 09, 2020 7:26 am
Hi All,
I'm trying out new 64 bit OS released recently. Here is the uname -a output of my Raspberry Pi 4 4GB. Using image with name "2020-05-27-raspios-buster-arm64.zip".
Linux raspberrypi 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/Linux
I came across an issue, when i install docker on my Pi. The file "/sys/fs/cgroup/memory/memory.stat" is missing and i can't view it within my container. Whereas the file is available in my old version of OS. I'm using an nginx image. Not sure if anyone encounter this issue before, appreciate if anyone can guide me to enable the memory file in container.
Here is the output from my container in 64 bit OS
pi@raspberrypi:~ $ sudo docker run -it --rm --entrypoint sh nginx:1.17.9-alpine
/ # cat /sys/fs/cgroup/memory/memory.stat
cat: can't open '/sys/fs/cgroup/memory/memory.stat': No such file or directory
Here is the output from my container in old OS.
pi@raspberrypi:~/edge $ sudo docker run -it --rm --entrypoint sh nginx:1.17.9-alpine
cache 0
rss 155648
rss_huge 0
shmem 0
mapped_file 0
dirty 0
writeback 0
pgpgin 1353
pgpgout 1345
pgfault 1914
pgmajfault 0
inactive_anon 0
active_anon 77824
inactive_file 0
active_file 0
unevictable 0
hierarchical_memory_limit 8796093018112
total_cache 0
total_rss 155648
total_rss_huge 0
total_shmem 0
total_mapped_file 0
total_dirty 0
total_writeback 0
total_pgpgin 1353
total_pgpgout 1345
total_pgfault 1914
total_pgmajfault 0
total_inactive_anon 0
total_active_anon 77824
total_inactive_file 0
total_active_file 0
total_unevictable 0
Here is the docker info output for 64 bit
Client:
 Debug Mode: false
Server:
 Containers: 0
  Running: 0
  Paused: 0
  Stopped: 0
 Images: 4
 Server Version: 19.03.11
 Storage Driver: overlay2
  Backing Filesystem: extfs
  Supports d_type: true
  Native Overlay Diff: true
 Logging Driver: json-file
 Cgroup Driver: cgroupfs
 Plugins:
  Volume: local
  Network: bridge host ipvlan macvlan null overlay
  Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
 Swarm: inactive
 Runtimes: runc
 Default Runtime: runc
 Init Binary: docker-init
 containerd version: 7ad184331fa3e55e52b890ea95e65ba581ae3429
 runc version: dc9208a3303feef5b3839f4323d9beb36df0a9dd
 init version: fec3683
 Security Options:
  seccomp
   Profile: default
 Kernel Version: 5.4.42-v8+
 Operating System: Debian GNU/Linux 10 (buster)
 OSType: linux
 Architecture: aarch64
 CPUs: 4
 Total Memory: 3.709GiB
 Docker Root Dir: /var/lib/docker
 Debug Mode: false
 Registry: https://index.docker.io/v1/
 Labels:
 Experimental: false
 Insecure Registries:
  127.0.0.0/8
 Live Restore Enabled: false
WARNING: No memory limit support
WARNING: No swap limit support
WARNING: No kernel memory limit support
WARNING: No kernel memory TCP limit support
WARNING: No oom kill disable support
WARNING: No cpu cfs quota support
WARNING: No cpu cfs period support
Here is the uname -a output of my old OS.
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
was posted elsewhere, instead of here, as it should have, quoting it here was the simplest solution
mmoseeker
Re: Raspberry Pi OS (64 bit) beta test version
Wed Jun 10, 2020 1:29 am
person1729 wrote:
Sun May 31, 2020 9:55 pm
Does usb boot work with this version on the pi 4?
yea.it works.update the new bootloader
sergiup
Wed Jun 10, 2020 9:47 am
This one? I've got this booting from the SD card, but using a USB-connected SSD drive for the root fs (I did this based on these instructions, basically changing cmdline.txt to point to the SSD disk id. If I can flash the image straight to USB
pi@raspberrypi:~ $ vcgencmd bootloader_version
Apr 16 2020 18:11:26
version a5e1b95f320810c69441557c5f5f0a7f2460dfb8 (release)
timestamp 1587057086
Having said that... It looks like it might work, as per the below, but rebooting without the uSD card fails (BOOT_STOPPED etc):
pi@raspberrypi:~ $ findmnt -n -o SOURCE /
/dev/sda2
pi@raspberrypi:~ $ findmnt -n -o SOURCE /boot
/dev/sda1
BRX7
Wed Jun 10, 2020 12:46 pm
is 3d accelaration still not fully supported for 64bit oses?
thatchunkylad198966
Wed Jun 10, 2020 1:31 pm
Correct.
One man's trash is another man's treasure! :) Pi's I have; Pi Zero, Pi Zero W, Pi 2 x2, Pi 3 x2, Pi 4 4GB x2.
6by9
Wed Jun 10, 2020 3:46 pm
Correct.
I must be imagining this then
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
pi@raspberrypi:~ $ uname -a
pi@raspberrypi:~ $ DISPLAY=:0 glxinfo -v | grep -A12 Extended
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Broadcom (0x14e4)
    Device: V3D 4.2 (0xffffffff)
    Version: 19.3.2
    Accelerated: yes
    Video memory: 3798MB
    Unified memory: yes
    Preferred profile: compat (0x2)
    Max core profile version: 0.0
    Max compat profile version: 2.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.1
OpenGL vendor string: Broadcom
3D acceleration is supported
Hardware video codec acceleration isn't through MMAL (it is through V4L2), so VLC and Chromium aren't currently accelerated.
thatchunkylad198966
Wed Jun 10, 2020 3:53 pm
Correct.
VERSION_ID="10"
ID=debian
    Version: 19.3.2
    Accelerated: yes
    Unified memory: yes
Sorry, I should've said not VLC/Chromium.
My bad.
rasp14
Wed Jun 10, 2020 4:15 pm
Hi All,
cache 0
rss 155648
rss_huge 0
shmem 0
mapped_file 0
dirty 0
writeback 0
pgpgin 1353
pgpgout 1345
pgfault 1914
pgmajfault 0
inactive_anon 0
active_anon 77824
inactive_file 0
active_file 0
unevictable 0
total_cache 0
total_rss 155648
total_rss_huge 0
total_shmem 0
total_mapped_file 0
total_dirty 0
total_writeback 0
total_pgpgin 1353
total_pgpgout 1345
total_pgfault 1914
total_pgmajfault 0
total_active_file 0
total_unevictable 0
Client:
 Debug Mode: false
Server:
 Containers: 0
  Running: 0
  Paused: 0
  Stopped: 0
 Images: 4
 Plugins:
  Volume: local
 Swarm: inactive
 Runtimes: runc
 Security Options:
  seccomp
   Profile: default
 OSType: linux
 CPUs: 4
 Debug Mode: false
 Labels:
 Experimental: false
  127.0.0.0/8
Thanks again for moving my post to here. Hoping someone can help me out on this.
6by9
Wed Jun 10, 2020 4:30 pm
My bad.
VLC and Chromium will use 3D acceleration, eg Google maps.
They won't use hardware codec acceleration, eg playing Youtube.
Two very different things.
brainsys
Wed Jun 10, 2020 5:02 pm
Is the hardware 3D acceleration omission likely to be remedied for first stable release?
6by9
Wed Jun 10, 2020 5:35 pm
What hardware 3D acceleration omission?!!?! 3D acceleration is fully hardware accelerated as I'd just shown in the last 4 posts.
jazzl
Wed Jun 10, 2020 7:51 pm
Just wanna confirm that this works great booting from an SSD drive connected to the USB-port on the pi 4 8GB version.
I went to 64-bit after under raspbian 32-bit having tried to install the only conda I could find for aarch64, miniforge, which kept on telling me that I should be using an x86 machine - even if the installer was for aarch64.
On raspian 64 bit, the same installer did its job with no issues.
Great job!
phil995511
Wed Jun 10, 2020 10:31 pm
fruitoftheloom wrote:
Mon Jun 08, 2020 12:18 pm
phil995511 wrote:
Mon Jun 08, 2020 12:13 pm
Hello, is it possible to include the beta of Raspberry Pi OS 64 bits on Noobs to install and use it on SSD please.
Ubuntu 20.04 on Noobs would also be very pleasant for the users that we are, while waiting a bios with a 100% functional boot on USB.
Regards.
RPi Imager is a far better tool for installing Operating Systems, NoobS is past its prime !!
Noobs allows you to install the OS on a USB3 SSD which is very practical, after installation Noobs is used as a bootloader, which limits wear and tear on the SD card, the SSD offers a read / write speed of +/- 350 Mb / s.
Regards.
RPi 4 with 4 Gb of RAM @ arm_freq=2000 / over_voltage=5 / gpu_mem=192 + FLIRC case for Raspberry Pi 4 (CPU @ 69 ° C max) + Beta frimware (pieeprom-2020-06-03.bin) for USB3 SSD booting + SSD Samsung 850 Pro 1To + Raspian OS 64 Bits Beta
phil995511
Wed Jun 10, 2020 11:04 pm
Finally I installed the latest version of the Beta frimware (pieeprom-2020-06-03.bin). With is it is possible to boot Raspbian 64 Bits directly from an SSD with this frimware, I'm very happy !! It works very well and stably.
Some software imported from Ubuntu ppa works fine, but others like Google Chrome, RPi Imager, Geekbench, GLX do not seem to be supported ?? I guess I have to be patient...
I read this article :
https://www.raspberrypi.org/blog/vulkan ... urce-code/
And I found this link :
https://blogs.igalia.com/apinheiro/2020 ... ome-demos/
Someone would have tried to install manually the news graphics drivers as indicated above by infapi00 ?
I assume that the Beta of Raspian 64 Bits will be updated in a while to be able to benefit from these drivers ??
I look forward to it !!
Regards
PS With so many good technical advances, I will almost end up dreaming of a RPi 4 B + equipped with 8 GB of RAM and a CPU engraved in 16/14 nm, to keep the hardware / software compatibility and effectively improve the CPU usage frequency.
RichardUK
Thu Jun 11, 2020 11:32 am
Trying to build for Mesa 3D GLESv2. GLESv2 and EGL libs not found. As per the original sticky announcement post linker searching in /usr/lib
Trying to install libgles2-mesa-dev and I get
sudo apt install libgles2-mesa-dev
Reading package lists... Done
Building dependency tree
libgles2-mesa-dev is already the newest version (19.3.2-1~bpo10+1~rpt1).
You might want to run 'apt --fix-broken install' to correct these.
 libgles2-mesa-dev : Depends: libgles-dev but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Trying to install libgles2-dev gives me the following error.
sudo apt install libgles2-dev
Package libgles2-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libgles2-dev' has no installation candidate
uname -a
Linux rpi4 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/Linux
Should I be able to build for gles2 for this beta? Or am I trying the wrong package?
Thanks for the great work. :)
RichardUK
Thu Jun 11, 2020 11:40 am
A quick addition, the following gives this output.
 sudo apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
  libegl-dev libgl-dev libgles-dev
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 38 not upgraded.
11 not fully installed or removed.
Need to get 0 B/170 kB of archives.
After this operation, 2,224 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 90663 files and directories currently installed.)
Preparing to unpack .../libgl-dev_1.3.0-7~bpo10+1_arm64.deb ...
Unpacking libgl-dev:arm64 (1.3.0-7~bpo10+1) ...
dpkg: error processing archive /var/cache/apt/archives/libgl-dev_1.3.0-7~bpo10+1_arm64.deb (--unpack):
 trying to overwrite '/usr/include/KHR/khrplatform.h', which is also in package libraspberrypi-dev 2+git20200520~143707+2fe4ca3-1
Preparing to unpack .../libegl-dev_1.3.0-7~bpo10+1_arm64.deb ...
Unpacking libegl-dev:arm64 (1.3.0-7~bpo10+1) ...
dpkg: error processing archive /var/cache/apt/archives/libegl-dev_1.3.0-7~bpo10+1_arm64.deb (--unpack):
 trying to overwrite '/usr/include/EGL/egl.h', which is also in package libraspberrypi-dev 2+git20200520~143707+2fe4ca3-1
Preparing to unpack .../libgles-dev_1.3.0-7~bpo10+1_arm64.deb ...
Unpacking libgles-dev:arm64 (1.3.0-7~bpo10+1) ...
dpkg: error processing archive /var/cache/apt/archives/libgles-dev_1.3.0-7~bpo10+1_arm64.deb (--unpack):
 trying to overwrite '/usr/include/GLES/gl.h', which is also in package libraspberrypi-dev 2+git20200520~143707+2fe4ca3-1
mahjongg
Thu Jun 11, 2020 11:54 am
meinside wrote:
Thu Jun 11, 2020 2:58 am
I've installed Raspberry Pi OS 64 bit (beta) on my Raspberry Pi 4 (4GB),
and tested Raspberry Pi camera with it,
but it is not working as expected.
It seemed to work:
$ vcgencmd get_camera
supported=1 detected=1
but when I run raspistill,
mmal: mmal_port_event_send: event lost on port 1,0 (buffer header callback not defined)
and resulting file is not image/jpeg:
test.jpg: data
I've tested with two cameras and cables, but the same result.
What should I check now?
Edit: even the red LED doesn't blink when shooting.
[Moderator copy pasted here]
RichardUK
Thu Jun 11, 2020 12:10 pm
Got the package installing now. I had to remove the failed install, do 'sudo apt update && sudo apt upgrade -y' and try the install again. That now installs without errors. My best guess is that I had forgotten to do the initial update / upgrade after first boot.
eglInitialize is failing but I can dig into that a bit more if GLES2 is expected to work. It's now building ok. :)
MarkDH102
Fri Jun 12, 2020 12:17 pm
64 Bit OS. Pi4 4GB. Wireless/Headless. X11 VNC. Screen size (Preferences-->Screen Configuration-->HDMI1-->1920 * 1080, 60Hz)
I seem to have lost the ability to resize any window.
I can drag them around and use the maximise/minimise but the "grab handle" does not appear when I move the mouse to the edge of the window.
I've tried "Appearance Settings-->Defaults" for medium screen but no change.
Screen resolution set to 1920 * 1080.
Only other packages installed are Claws mail and CuteCOM, both of which work fine.
SOLUTION :
sudo nano /etc/systemd/system/x11vnc.service
[Service]
ExecStart=/usr/bin/x11vnc -xkb -noxrecord -noxfixes -noxdamage -display :0 -auth guess -rfbauth /etc/x11vnc.pass
In ExecStart, add
-cursor some
Also add (for autorepeat)
-repeat
mahjongg
Fri Jun 12, 2020 5:45 pm
hitsware wrote:
Fri Jun 12, 2020 5:19 pm
Please change the new PiOS so that
sound is enabled from Sonic-Pi .
Thank You ,
Your Humble Servant ,
Michael Miller
bobmon
Success running simple asm code on RPi 3B and 4B
Sun Jun 14, 2020 8:56 am
Feedback: I currently have the 5/27 beta version running on a Raspberry Pi 3B (also on a 4B/4GB and a 4B/2GB). Headless connection through a laptop, using dnsmasq and dhcpcd so the RPi can issue an IP address to the host laptop's Ethernet port.
I just verified that I can assemble and run a simple 64-bit "hello world" program, and a command-line argument reporter that links the C "printf()" for output. Haven't double-checked the C compiler, but it seems likely to work okay :-)
I am planning to use this OS for a fall course in C and ARM Assembly programming. Keep up the good work.
PeterO
Sun Jun 14, 2020 9:28 am
Old GLES2 code won't work because the firmware interface has gone.
Any standard openGL ES 3 examples will work now with no need for any specific PI code.
Try some of these.. https://github.com/danginsburg/opengles3-book
PeterO
spectrum6
Sun Jun 14, 2020 1:03 pm
Just wanted to drop in and say that the 64-bit kernel & OS is working well for me, I am mostly using it for Linux containers and compiling in those containers. I look forward to the improvements you guys are working on to get MMAL-based acceleration working on 64-bit. Thanks for your hard work on this effort.
I managed to install snap, and through snap install lxd (4.1), it appears 4.2 is looking for a vlan_filtering on the bridge device in the /sys (/sys/class/net/%s/bridge/vlan_filtering) filesystem that doesn't exist due to the kernel not being compiled with the option. It was a new feature added to lxd 4.2 (PR #7465).
It should technically be an lxd bug, since the kernel configuration is optional, as indicated by this bug report:
https://bugs.launchpad.net/ubuntu/+sour ... ug/1882955
apt-get install snap
snap install core core18 snapd
snap install --channel=4.1/stable lxd # (latest/stable installs 4.2, which has the issue)
But anyways, wanted to share my feedback and thank the team for your effort.
rwcooper
Mon Jun 15, 2020 8:27 pm
Hi, does anyone have sysbench running? If so, how did you go about installing it? Thanks...Randy
gsh
Tue Jun 16, 2020 6:02 am
Gordon Hollingworth PhD
