gsh
STICKY: Raspberry Pi OS (64 bit) beta test version feedback
Thu May 28, 2020 6:43 am
In reference to the announcement:
viewtopic.php?f=117&t=275370
Thought I'd create a thread for discussion...
Gordon Hollingworth PhD
bensimmo
Re: Raspberry Pi OS (64 bit) beta test version
Thu May 28, 2020 7:04 am
I'll give it a try later.
I also assume someone will try it on Pi2 v1.2 , I can't as I don't have one and there are not many around.
What's the plan with it, to keep it in line with the 32bit version or draw a line and spec the Pi3 as minimum and move forward leaving 32bit to run nicely on Pi3 and before since the older Pi are getting increasingly outpaced by the Desktop's needs?
Here's to getting this to work as smoothly as the 32bit version.
gsh
Thu May 28, 2020 7:08 am
In the long term we'll keep both running at the same level for as long as is feasible. If the technology divides us we may have to switch to some long term stable solution. But I don't expect that to happen in the next few years.
Gordon
wildfire
Thu May 28, 2020 7:40 am
Just so happens I've a 3b+ and 4b4 v1.1 idling around, I'll try it out on both once I get another couple of PSU's.
ETA: Scratch that, 8Gb model just ordered.
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
Thu May 28, 2020 8:15 am
While the current Zero range is still being sold, I don't see 32-bit disappearing for a while.
Unreadable squiggle
Thu May 28, 2020 10:52 am
Removed
Last edited by fruitoftheloom on Thu May 28, 2020 1:39 pm, edited 1 time in total.
The information is out there....you just have to let it in.
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
ag123
Thu May 28, 2020 11:08 am
thanks i may try this out, since i'm running rosetta@home which uses the 64 bits kernel. 64 bits is normally used if you need to go beyond 4GB , but apps today are being built with an assumption it would go beyond 4GB :lol:
PeterO
Thu May 28, 2020 11:54 am
rpi-image seems unhappy taking image names on the command line. Seems they have to be absolute paths.
But seems to work OK ...
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/Linux
pi@raspberrypi:~ $ free -h
              total        used        free      shared  buff/cache   available
Mem:          7.6Gi       177Mi       7.2Gi        36Mi       243Mi       7.3Gi
Swap:          99Mi          0B        99Mi
pi@raspberrypi:~ $
PeterO
Thu May 28, 2020 11:59 am
You only need 64 if your process needs more than 3GB of memory, which is the limit in 32bit world. Of course, you can have multiple processes each using 3GB in 32 bit world, that works fine. Hence 32bit will work fine on the 4 and 8GB models, unless you have a specific need for >3GB in a single process.
Thu May 28, 2020 12:41 pm
This will likely seem a daft question but..
..we had a 64bit kernel for Raspbian ARMHF but it was still 32 Userland
..now we have a ARM64 OS, is it 64 Userland ?
Therefore if running Raspbian ARMHF with 64 kernel & 32 Userland, is there an update path or only a fresh install ??
PeterO
Thu May 28, 2020 12:47 pm
Something is amiss in "apt land" though. Getting errors when installing openGL ES dev packages. (Reported on github).
PeterO
ag123
Thu May 28, 2020 1:28 pm
actually 1 of the concern is if the 'old' 32 bit binaries would run :lol:
it seemed it should be possible as over in this thread
viewtopic.php?f=29&t=275398
i managed to run 64 bit apps (on 64 bits kernel) in 32 bits userland ;)
Thu May 28, 2020 1:44 pm
Seems yet again I need more sleep, had another reading session:
But power users, who want to be able to map all 8GB into the address space of a single process, need a 64-bit userland. There are plenty of options already out there, including Ubuntu and Gentoo.
Not to be left out, today we’ve released an early beta of our own 64-bit operating system image. This contains the same set of applications and the same desktop environment that you’ll find in our regular 32-bit image, but built against the Debian arm64 port.
https://www.raspberrypi.org/blog/8gb-ra ... now-at-75/
So we now have a stable ARM32 / 32 Userland OS and a Beta ARM64 / 64 Userland OS.
Be interesting to see how ARM64 would run on BCM2837 2B or 3A !!
Raspbian re-naming etal:
"raspberry pi 32-bit OS" = raspbian base userland + raspberry pi kernels (32-bit and 64-bit) + raspberry pi UI and graphics stack enhancements + raspberry pi additional software
"raspberry pi 64-bit OS" = debian arm64 base userland + raspberry pi 64-bit kernel + raspberry pi UI and graphics stack enhancements + raspberry pi additional software
viewtopic.php?f=66&t=275380&sid=1a468f2 ... d#p1668466
Last but not least another reason not to use Ubuntu Server........
gordon77
Thu May 28, 2020 2:28 pm
I've downloaded the 64bit beta, tried 2 cards, Sandisk Ultra 128GB and 32GB, using Pi Imager, both fail verification.
dickon
Thu May 28, 2020 2:38 pm
I've downloaded it, written it to my bootserver, and, after the usual edits to /boot/cmdline.txt and /etc/fstab, now have a functioning 3B with a 64b desktop.
I've been using these things since launch in 2012, and this is the first time I've seen the desktop in the flesh...
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
gsh
Thu May 28, 2020 2:55 pm
Are you sure you're using the latest version (should say v1.2 in the taskbar)
What operating system are you using?
ag123
Thu May 28, 2020 3:06 pm
hi , i'm downloading it, but perhaps make a torrent out of it? at 1GB it may get popular fast hence bittorrent may help there.
gordon77
Thu May 28, 2020 3:08 pm
installed v1.2 now, and trying again
gordon77
Thu May 28, 2020 4:20 pm
Fixed, thanks
W. H. Heydt
Thu May 28, 2020 4:26 pm
Nomenclature.... As "Raspberry Pi OS" is going to be pretty awkward to type as often as we've typed "Raspbian" (which is bad enough), I'll be using "RPiOS". If versions need to be specified, there can be "RPiOS32" and "RPiOS64". I'd welcome others joining me in this.
trejan
Thu May 28, 2020 4:30 pm
PiOS to go with Agnostics?
gordon77
Thu May 28, 2020 4:33 pm
Fixed, thanks. Maybe remind others to use v1.2.
ShiftPlusOne
Thu May 28, 2020 4:47 pm
https://downloads.raspberrypi.org/raspi ... ip.torrent
PeterO
Fri May 29, 2020 8:44 am
Is it just me ? apt update and apt upgrade seem to run noticeably faster on 64 bits (and 8Gb) .
PeterO
Kendek
Fri May 29, 2020 9:02 am
PeterO
Check the /etc/apt/sources.list files; http://deb.debian.org/debian (64-bit / arm64) vs http://raspbian.raspberrypi.org/raspbian (32-bit / armhf)
