Wed May 20, 2020 11:20 am
topguy wrote: ↑Wed May 20, 2020 7:41 am
Yes you should be able to move the SD card from the 2GB to the 4GB without any problem.
If you move the SD card you move *everything* that is installed on the old Pi, there is nothing stored on the old Pi, it has no inbuilt storage.
+1
However, if you have another uSD card, you could use Raspbian's, "built-in"** , SD card Copier to "clone" the card instead. (Good practice for a basic backup too!) .
Trev.
** FWIW, a few screenshots of the process can be seen here:
https://www.cpmspectrepi.uk/raspberry_p ... OnP4B.html
