Jamrr
Shutdown Button not Working???
Fri May 15, 2020 2:34 am
New here with a stupid question to an obvious problem that I cant seem to find the answer to.
Why does clicking the "Shutdown" button, in the Shutdown Options" frame, not shut down the PI4?
mooblie
Re: Shutdown Button not Working???
Fri May 15, 2020 7:07 am
If the green activity LED eventually gives ten regular flashes, then stops, the shutdown has worked OK.
However, it doesn’t actually cut the power, so the red power LED stays on until power is physically removed or switched off “at the wall”.
