Question is in the title, i wonder if it's possible.
I've got spacedesk running and i would like to reduce the latency caused by a router's wifi becoming weak with time + high amount of devices connected,
so i thought i could use my raspberry pi as a router, so i can keep it next to my pc, i will have low latency due to short distance, and i'll still have internet on my pc from ethernet.
what kind of setup would that require?
so basicaly, make the raspberry pi into a LAN
PS: my tablet doesn't support ethernet AFAIK and can't use the wifi adapter on my pc or it will BSOD because drivers suck, and there is no other available
i originally tried it with my phone also using usb tethering, but it requirement to setup a proxy via an app called "proxy server" and i don't know how to set it up for spacedesk, so i gave up
