Dimension02000
cifs fstab/mount problem
Mon Apr 27, 2020 9:41 pm
I have a cfis share that I cannot mount on (Buster). The problem occurs with the password. I get an "Invalid argument" error. If I manually enter the credentials the error occurs upon entering the password. If I use fstab it happens when I issue the mount command. Here is the fstab entry:
//192.168.10.110/Backups /Backups cifs defaults,uid=1000,gid=1000,umask=000,credentials=/etc/security/fstab.EAP 0 0
Can someone help me debug this? TIA.
thagrol
Re: cifs fstab/mount problem
Mon Apr 27, 2020 11:15 pm
Try a forum and/or web search. This has come up before so you may find a solution that way.
if you can't, post your server config, both globally and relating to the share, as well as details of the hardware and software it is running.
Dimension02000
Tue Apr 28, 2020 8:10 am
Thanks for the reply. I didn't find anything helpful but after playing around I was able to mount the share 'rw' with the following command:
sudo mount -vv -t cifs -o username=pi,uid=1000 //192.168.10.110/Backups /Backups
The bizarre part is when I remove the umask parameter from the fstab entry, the error goes away and the share is mounted rw, at least for that uid. I can accept that. I guess the Windows side does not like me giving full permissions to all users. However, the error is really useless at best and misleading at worst.
thagrol
Tue Apr 28, 2020 11:37 am
I think you'll find that umask is not a valid mount option for cifs. Use file_mode and dir_mode instead. See
man mount.cifs
Incidentally, if you're going to force permissions to be wide open, there's little benefit to forcing UID and GID too.
LTolledo
Tue Apr 28, 2020 11:54 am
check your credentials file, should be in same format as:
user=notyouofcourse
password=forgetmenot
if like below
user = notyouofcourse
password = forgetmenot
you will have headaches....
Some people be like:
