.. And as the OP has no idea what a data sheet is and also failed to answer the question which ' old tablet' (appropriate answer would be manufacturer, model,etc) his display comes from he will most like fail to design a full custom interface board for it.fruitoftheloom wrote:
A Datasheet is a Technical Document which shows the functions of the Input / Output Data Connections as well as Timings etcetera etcetera...
...even if you found a Datasheet you would need to build an interface board.
The tablet is a Master Model MID900aBUGSworstnightmare wrote: ↑Tue Apr 28, 2020 4:20 pm.. And as the OP has no idea what a data sheet is and also failed to answer the question which ' old tablet' (appropriate answer would be manufacturer, model,etc) his display comes from he will most like fail to design a full custom interface board for it.fruitoftheloom wrote:
If there isn't even a public datasheet then the chances of getting this LCD working are extremely low. You need to find something else to use for your Pi. If you want an easy life then make sure it says it is compatible with a Pi.
Search internet ebay etc with the screen model number.
