PiVPN + local devices / DNS not working ?
Posted: Wed Apr 22, 2020 4:30 pm
by TD540
I got a router with DHCP disabled and a Pi that has PiVPN using Wireguard, and Pi-hole with DHCP server enabled.
I got two MacBooks connected to Pi-hole: MacBook 1 has a little web server, MacBook 2 can surf to MacBook-1.local:8000 and browse the website.
iPhone is connected to PiVPN (via external 4G connection) and ads are indeed blocked because of Pi-hole. iPhone cannot surf to MacBook-1.local:8000. iPhone can also not ssh into raspberrypi.local. Why not ?
Re: PiVPN + local devices / DNS not working ?
Posted: Wed Apr 22, 2020 7:41 pm
by epoch1970
For a start, mDNS (.local names) does no go across networks.
The Wireguard VPN is a network, so on either side of it machines can't see the other's .local domain.
Try connecting with the IP addresses.
Or with DNS names, e.g. macbook-1.<lan-domain-name>, if Pihole has defined a domain name for the LAN.
(DNS works across routers, otherwise the internet would not exist...)
Posted: Wed Apr 22, 2020 9:02 pm
by TD540
the hostnames inconsistently seem to work without .local extension. just surfing to http://macbook-1 works!
but SSH'ing the pi via its supposed hostname raspberrypi still does not...
pi@raspberrypi:~ $ pivpn -d
::::            PiVPN debug              ::::
::::            Latest commit            ::::
commit 4e8d4dfd8ef01e49f3137d5fc5a2afa14a465e47 (grafted, HEAD -> master, origin/master, orig
in/HEAD)
Author: Orazio <orazioedoardo@users.noreply.github.com>
Date:   Tue Apr 7 13:45:43 2020 +0200
    Merge pull request #1000 from psgoundar/pivpn
    Updated listOVPN to Include Expiration Dates
=============================================::::        Installation settings        ::::
PLAT=Raspbian
OSCN=buster
USING_UFW=0
IPv4dev=eth0
IPv4addr=192.168.1.2/24
IPv4gw=192.168.1.1
install_user=pi
install_home=/home/pi
VPN=wireguard
pivpnPORT=51820
pivpnDNS1=10.6.0.1
pivpnDNS2=
pivpnHOST=REDACTED
INPUT_CHAIN_EDITED=0
FORWARD_CHAIN_EDITED=0
pivpnPROTO=udp
pivpnDEV=wg0
pivpnNET=10.6.0.0
subnetClass=24
UNATTUPG=1
INSTALLED_PACKAGES=()
::::  Server configuration shown below   ::::
[Interface]
PrivateKey = server_priv
Address = 10.6.0.1/24
ListenPort = 51820
# begin iphone
[Peer]
PublicKey = iphone_pub
PresharedKey = psk
AllowedIPs = 10.6.0.2/32
# end iphone
::::  Client configuration shown below   ::::
[Interface]
PrivateKey = iphone_priv
Address = 10.6.0.2/24
DNS = 10.6.0.1
[Peer]
PublicKey = server_pub
PresharedKey = psk
Endpoint = REDACTED:51820
AllowedIPs = 0.0.0.0/0, ::0/0
::::    Recursive list of files in       ::::
::::    /etc/wireguard shown below       ::::
/etc/wireguard:
configs  keys  wg0.conf
/etc/wireguard/configs:
clients.txt  iphone.conf
/etc/wireguard/keys:
psk  server_priv  server_pub  iphone_priv  iphone_pub
::::            Self check               ::::
:: [OK] IP forwarding is enabled
:: [OK] Iptables MASQUERADE rule set
:: [OK] WireGuard is running
:: [OK] WireGuard is enabled (it will automatically start on reboot)
:: [OK] WireGuard is listening on port 51820/udp
:::: Having trouble connecting? Take a look at the FAQ:
:::: https://github.com/pivpn/pivpn/wiki/FAQ
:::: WARNING: This script should have automatically masked sensitive       ::::
:::: information, however, still make sure that PrivateKey, PublicKey      ::::
:::: and PresharedKey are masked before reporting an issue. An example key ::::
:::: that you should NOT see in this log looks like this:                  ::::
:::: YIAoJVsdIeyvXfGGDDadHh6AxsMRymZTnnzZoAb9cxRe                          ::::
::::            Debug complete           ::::
Posted: Wed Apr 22, 2020 9:25 pm
by bls
I've found that for reliable, consistent DNS results on the local network, it's best to set up a definitive infrastructure that works in all scenarios.
Specifically, run your own DNS (and probably DHCP) servers. the Pi4 is plenty capable of supporting this for a home network. Pi-Hole for those that prefer GUI-based solutions, and there are tons of script-based solutions (including the one I use) for those that prefer shell-based.
In either case, no need to ever edit DNS config files and no "my computer can't be accessed" due to some naming or VPN-related issues.
And, if you run your own DHCP server as well, at some point in the future you'll be very happy with your past self when your router dies or needs to be replaced. :lol:
Posted: Fri Apr 24, 2020 9:44 am
by DustZombie
mcdvoice
in/HEAD)
PLAT=Raspbian
OSCN=buster
USING_UFW=0
IPv4dev=eth0
IPv4gw=192.168.1.1
install_user=pi
VPN=wireguard
pivpnPORT=51820
pivpnDNS1=10.6.0.1
pivpnDNS2=
pivpnHOST=REDACTED
pivpnPROTO=udp
pivpnDEV=wg0
pivpnNET=10.6.0.0
subnetClass=24
UNATTUPG=1
[Interface]
ListenPort = 51820
# begin iphone
[Peer]
PresharedKey = psk
# end iphone
[Interface]
DNS = 10.6.0.1
[Peer]
PresharedKey = psk
/etc/wireguard:
Effective and interesting post for reading, i really love it and waiting for updates
