pootle
ifconfig inside crontab fails on raspbian lite
Wed Apr 22, 2020 12:18 pm
I have put the following in crontab:
@reboot sleep 55; /sbin/ifconfig >>/home/pi/test.log 2> &1
but it disappears without trace - not even an empty file.
I'm on a pi 0 W running raspbian lite
Have I done something silly or is there a real problem here?
I was calling it using subprocess from python, but the app disappears without trace - apparently not even an exception.
epoch1970
Re: ifconfig inside crontab fails on raspbian lite
Wed Apr 22, 2020 12:31 pm
pi@red:~ $ /sbin/ifconfig >>/home/pi/test.log 2> &1
-bash: syntax error near unexpected token `&'
pi@red:~ $ /sbin/ifconfig >>/home/pi/test.log 2>&1
pi@red:~ $ head -2 /home/pi/test.log
bridge0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 172.17.255.230  netmask 255.255.0.0  broadcast 172.17.255.255
pi@red:~ $
pootle
Wed Apr 22, 2020 12:41 pm
Ah! thanks for lifting the brainfog. I use shell so rarely it's easy to make silly mistakes.
