leoj
will a RJ45 male to USB female adapter work?
Sun Apr 19, 2020 5:01 pm
will a RJ45 male to USB female adapter work on a Raspberry Pi model B Rev 2? im am going to buy a Raspberry Pi model B Rev 2 to use for octoprint but i need the 2 usbs for webcam and to connet to my printer but i need a internet conection and i have wifi usb so can i use a RJ45 male to USB female adapter to connect the wifi usb??
W. H. Heydt
Re: will a RJ45 male to USB female adapter work?
Mon Apr 20, 2020 1:20 am
Anything with a male RJ-45 plug and a female USB-A is NOT going to turn a Pis RJ-45 Ethernet jack into a USB port.
Note, by the way, that a Pi2Bv1.2 has *4* USB ports, so I'm not sure just what your concern is here. Also, for the same price you could get a Pi3B or Pi3B+ (or, at list, a Pi4B2) any of which has built in WiFi. Even if you're getting your Pi2Bv1.2 on the cheap (i.e. less than the $35 list), it would still probably be less expensive to get a later Pi than that Pi *plus* a WiFi dongle.
Burngate
Mon Apr 20, 2020 9:15 am
... im am going to buy a Raspberry Pi model B Rev 2 ...
Best advice - Don't.
That's an old Pi 1B - not Pi 2B.
Perhaps think about a Zero-W and a USB hub?
Mon Apr 20, 2020 9:26 am
Please can you confirm what model you intend to purchase, though a Raspberry Pi 4B 2GB is only $35.00:
https://www.raspberrypi.org/products/
RPi 4B 4GB (SSD Boot)..
