Biblioman
Raspberry Pi 4 B won't boot from SD card
Tue Apr 14, 2020 6:52 pm
Hi, I have the RPI4 v1.2 RAM 4G and it does not start. I am using a good charger (4A) but it is not the original of the Raspberry. The issue with USB Type-C cables is supposed to be fixed in version 1.2. My question is: has anyone managed to run the RPI4 with non-original chargers?.
Thank you
http://www.aquihayapuntes.com
drgeoff
Re: Raspberry Pi 4 B won't boot from SD card
Wed Apr 15, 2020 7:33 am
Read the "not booting" sticky.
Quis custodiet ipsos custodes?
Biblioman
Thu Apr 16, 2020 11:38 am
Is the first thing I did.
I do not have the official power source. but I am using a good power supply of more than 3A. My question is if anyone has had problems with the power supply in v1.2.
I have seen the schematic and nothing has changed regarding the USB Type-C connector
https://www.raspberrypi.org/documentati ... educed.pdf
Problem in v1.1:
https://www.scorpia.co.uk/2019/06/28/pi ... resistors/
Thu Apr 16, 2020 11:47 am
Thank you
It was USB Power Delivery which was the issue, not USB Cables par-se...
Biblioman
Thu Apr 16, 2020 12:04 pm
the question is that I have reviewed the schematic and the board with a magnifying glass and I don't see any hardware modification in version v1.2 with respect to v1.1
trejan
Thu Apr 16, 2020 12:43 pm
Yes. Works fine here with a 2.4A Anker charger. I don't have any USB peripherals attached so the reduced current capacity is no problem.
The USB-C CC problem is generally not an issue for most people. You only see a problem if you have expensive high current USB-C PD chargers e.g. laptop chargers or expensive e-marked USB-C cables.
That is the v1.1 schematic. AFAIK there hasn't been an updated version for v1.2.
It isn't immediately visible unless you look very closely. The one of the traces around the USB-C connector was changed but general component placement is still the same. The easiest change to spot is the moved component near the micro SD socket but that is unrelated to the USB-C CC fix.
Thu Apr 16, 2020 1:24 pm
If you have a 1.2 board you won't have any problems with the power supply, whatever type it is. Your problem is elsewhere.
If you have a 1.1 board, you may have problems with very specific power supplies that use PD negotiation. Mosty power supplies will however work fine.
Biblioman
Thu Apr 16, 2020 3:28 pm
Then think I have a problem ( faulty RAM chips ). Attached screen ... any more ideas?
https://www.dropbox.com/s/hwypobf7nf3b8k9/img.jpg?dl=0
Thank you
drgeoff
Thu Apr 16, 2020 3:34 pm
Re-install Raspbian Buster on the micro-SD card. If still failing install on another micro-SD card.
Biblioman
Thu Apr 16, 2020 4:49 pm
That's not it, I've already tried 5 different cards and I don't even remember how many times I've installed Raspbian
Thank you anyway
Biblioman
Thu Apr 16, 2020 6:55 pm
Just one more question, if the board does not have any additional hardward components, what modification have you made to make it work with any power supply?
trejan
Thu Apr 16, 2020 7:34 pm
PCB traces were altered.
Thu Apr 16, 2020 7:35 pm
https://www.theregister.co.uk/AMP/2020/02/21/pi_4_fixed
Biblioman
Mon Apr 20, 2020 10:15 am
Hello thanks for the answers, I have managed to boot the RPI4 4G v1.2 by lowering the CPU speed in config.txt
arm_freq = 700
I have the following errors in the kernel
pi@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.97-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[    0.000000] On node 0 totalpages: 1012736
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
[    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[    0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[    0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:6F:CF:F5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 3735564K/4050944K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 53236K reserved, 262144K cma-reserved, 3264512K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   ( 688 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 28692 entries in 85 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000007] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000022] Switching to timer-based delay loop, resolution 18ns
[    0.000302] Console: colour dummy device 80x30
[    0.000332] console [tty1] enabled
[    0.000387] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.000408] pid_max: default: 32768 minimum: 301
[    0.000753] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000775] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001723] CPU: Testing write buffer coherency: ok
[    0.002225] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003045] Setting up static identity map for 0x200000 - 0x20003c
[    0.003249] rcu: Hierarchical SRCU implementation.
[    0.004345] smp: Bringing up secondary CPUs ...
[    0.005342] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.006519] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.007641] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.007816] smp: Brought up 1 node, 4 CPUs
[    0.007832] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.007844] CPU: All CPU(s) started in HYP mode.
[    0.007855] CPU: Virtualization extensions available.
[    0.008832] devtmpfs: initialized
[    0.022008] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.022269] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.022294] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.031833] pinctrl core: initialized pinctrl subsystem
[    0.032876] NET: Registered protocol family 16
[    0.036513] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.038360] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.038374] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.038601] Serial: AMBA PL011 UART driver
[    0.042564] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.060051] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-12 12:36, variant start
[    0.070071] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
[    0.122431] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[    0.126503] vgaarb: loaded
[    0.126950] SCSI subsystem initialized
[    0.127202] usbcore: registered new interface driver usbfs
[    0.127268] usbcore: registered new interface driver hub
[    0.127390] usbcore: registered new device driver usb
[    0.129004] clocksource: Switched to clocksource arch_sys_counter
[    0.228829] VFS: Disk quotas dquot_6.6.0
[    0.228934] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.229155] FS-Cache: Loaded
[    0.229372] CacheFiles: Loaded
[    0.230016] simple-framebuffer: probe of 0.framebuffer failed with error -12
[    0.241380] NET: Registered protocol family 2
[    0.242231] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.242265] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.242350] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.242440] TCP: Hash tables configured (established 8192 bind 8192)
[    0.242584] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.242617] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.242878] NET: Registered protocol family 1
[    0.243612] RPC: Registered named UNIX socket transport module.
[    0.243624] RPC: Registered udp transport module.
[    0.243636] RPC: Registered tcp transport module.
[    0.243648] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.243667] PCI: CLS 0 bytes, default 64
[    0.247502] Initialise system trusted keyrings
[    0.247718] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    0.259287] FS-Cache: Netfs 'nfs' registered for caching
[    0.259934] NFS: Registering the id_resolver key type
[    0.259963] Key type id_resolver registered
[    0.259975] Key type id_legacy registered
[    0.259999] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.262884] Key type asymmetric registered
[    0.262897] Asymmetric key parser 'x509' registered
[    0.263038] bounce: pool size: 64 pages
[    0.263098] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.263303] io scheduler noop registered
[    0.263317] io scheduler deadline registered (default)
[    0.263522] io scheduler cfq registered
[    0.263537] io scheduler mq-deadline registered (default)
[    0.263550] io scheduler kyber registered
[    0.299768] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[    0.299792] brcm-pcie fd500000.pcie: could not get clock
[    0.299869] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    0.299916] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[    0.359052] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[    0.359388] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    0.359408] pci_bus 0000:00: root bus resource [bus 00-01]
[    0.359429] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[    0.359482] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    0.359656] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.363140] PCI: bus0: Fast back to back transfers disabled
[    0.363162] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.363437] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    0.363575] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.363927] pci 0000:01:00.0: PME# supported from D0 D3cold
[    0.367387] PCI: bus1: Fast back to back transfers disabled
[    0.367407] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[    0.367465] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    0.367490] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    0.367567] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.367589] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    0.367854] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    0.368065] pcieport 0000:00:00.0: Signaling PME with IRQ 53
[    0.368264] pcieport 0000:00:00.0: AER enabled with IRQ 53
[    0.368469] pci 0000:01:00.0: enabling device (0140 -> 0142)
[    0.373589] iproc-rng200 fe104000.rng: hwrng registered
[    0.373868] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.374515] vc-sm: Videocore shared memory driver
[    0.375012] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    0.387886] brd: module loaded
[    0.399820] loop: module loaded
[    0.400736] Loading iSCSI transport class v2.0-870.
[    0.402849] libphy: Fixed MDIO Bus: probed
[    0.403386] bcmgenet fd580000.genet: failed to get enet clock
[    0.403407] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[    0.403429] bcmgenet fd580000.genet: failed to get enet-wol clock
[    0.403450] bcmgenet fd580000.genet: failed to get enet-eee clock
[    0.403475] bcmgenet: Skipping UMAC reset
[    0.403768] unimac-mdio unimac-mdio.-19: DMA mask not set
[    0.419046] libphy: bcmgenet MII bus: probed
[    0.459676] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[    0.460828] usbcore: registered new interface driver r8152
[    0.460912] usbcore: registered new interface driver lan78xx
[    0.460987] usbcore: registered new interface driver smsc95xx
[    0.461335] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.461374] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    0.464110] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[    0.464462] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
[    0.465456] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.465475] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.465491] usb usb1: Product: xHCI Host Controller
[    0.465506] usb usb1: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[    0.465520] usb usb1: SerialNumber: 0000:01:00.0
[    0.466158] hub 1-0:1.0: USB hub found
[    0.466251] hub 1-0:1.0: 1 port detected
[    0.466825] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.466854] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    0.466879] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    0.467325] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    0.467343] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.467358] usb usb2: Product: xHCI Host Controller
[    0.467373] usb usb2: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
[    0.467387] usb usb2: SerialNumber: 0000:01:00.0
[    0.467994] hub 2-0:1.0: USB hub found
[    0.468090] hub 2-0:1.0: 4 ports detected
[    0.469592] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.469837] dwc_otg: FIQ enabled
[    0.469849] dwc_otg: NAK holdoff enabled
[    0.469860] dwc_otg: FIQ split-transaction FSM enabled
[    0.469876] Module dwc_common_port init
[    0.470136] usbcore: registered new interface driver uas
[    0.470254] usbcore: registered new interface driver usb-storage
[    0.470489] mousedev: PS/2 mouse device common for all mice
[    0.471950] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.472919] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 400000 KHz
[    0.475848] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 466666 KHz
[    0.476526] sdhci: Secure Digital Host Controller Interface driver
[    0.476538] sdhci: Copyright(c) Pierre Ossman
[    0.477022] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    0.477515] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.481082] ledtrig-cpu: registered to indicate activity on CPUs
[    0.481263] hidraw: raw HID events driver (C) Jiri Kosina
[    0.481414] usbcore: registered new interface driver usbhid
[    0.481425] usbhid: USB HID core driver
[    0.482328] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[    0.484000] [vc_sm_connected_init]: start
[    0.491824] [vc_sm_connected_init]: end - returning 0
[    0.493272] Initializing XFRM netlink socket
[    0.493307] NET: Registered protocol family 17
[    0.493424] Key type dns_resolver registered
[    0.493838] Registering SWP/SWPB emulation handler
[    0.494593] registered taskstats version 1
[    0.494612] Loading compiled-in X.509 certificates
[    0.503463] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    0.503538] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    0.509254] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    0.509927] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[    0.510723] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    0.510738] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    0.537027] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[    0.537143] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[    0.555583] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.557239] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.558888] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.561848] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.563503] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.569052] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    0.572681] of_cfs_init
[    0.572788] of_cfs_init: OK
[    0.573504] Waiting for root device PARTUUID=ea7d04d6-02...
[    0.620519] random: fast init done
[    0.639018] mmc1: new high speed SDIO card at address 0001
[    0.692007] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[    0.693335] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    0.697527]  mmcblk0: p1 p2
[    0.708696] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    0.708747] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    0.709373] devtmpfs: mounted
[    0.719138] Freeing unused kernel memory: 2048K
[    0.749331] Run /sbin/init as init process
[    0.829063] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.011699] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    1.011718] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.011734] usb 1-1: Product: USB2.0 Hub
[    1.013778] hub 1-1:1.0: USB hub found
[    1.014082] hub 1-1:1.0: 4 ports detected
[    1.223918] systemd[1]: System time before build time, advancing clock.
[    1.335424] NET: Registered protocol family 10
[    1.336943] Segment Routing with IPv6
[    1.380741] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.381582] systemd[1]: Detected architecture arm.
[    1.391772] systemd[1]: Set hostname to <raspberrypi>.
[    1.394681] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[    2.197379] random: systemd: uninitialized urandom read (16 bytes read)
[    2.208347] random: systemd: uninitialized urandom read (16 bytes read)
[    2.208748] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    2.209848] random: systemd: uninitialized urandom read (16 bytes read)
[    2.210509] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.217169] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    2.218014] systemd[1]: Listening on udev Control Socket.
[    2.218562] systemd[1]: Listening on udev Kernel Socket.
[    2.218730] systemd[1]: Reached target Swap.
[    2.443378] i2c /dev entries driver
[    2.897913] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.048516] systemd-journald[117]: Received request to flush runtime journal from PID 1
[    3.673828] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[    3.674565] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[    3.675225] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[    3.675813] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[    3.781347] media: Linux media interface: v0.10
[    3.832573] videodev: Linux video capture interface: v2.00
[    3.838250] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    3.841478] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    3.841506] [vc_sm_connected_init]: start
[    3.845963] [vc_sm_connected_init]: installed successfully
[    3.872288] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    3.886341] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.887013] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.900453] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    3.915277] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    3.919767] bcm2835_audio soc:audio: card created with 8 channels
[    3.943565] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    3.943619] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    3.959117] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    3.959158] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    3.970685] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    3.970740] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    4.177768] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.187770] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    4.261602] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[    4.261721] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    4.263049] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[    4.263064] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.263077] [drm] No driver support for vblank timestamp query.
[    4.263088] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[    4.300965] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.415274] brcmfmac: F1 signature read @0x18000000=0x15264345
[    4.427623] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.428565] usbcore: registered new interface driver brcmfmac
[    4.674295] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.693906] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[    6.823604] uart-pl011 fe201000.serial: no DMA platform data
[    6.907017] 8021q: 802.1Q VLAN Support v1.8
[    6.934996] random: crng init done
[    6.935013] random: 7 urandom warning(s) missed due to ratelimiting
[    7.251475] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    7.413961] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    7.413981] brcmfmac: power management disabled
[    7.851309] bcmgenet: Skipping UMAC reset
[    7.959544] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[    7.959780] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.969320] bcmgenet fd580000.genet eth0: Link is Down
[   12.089254] bcmgenet fd580000.genet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   12.089288] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.214799] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[   13.457140] Bluetooth: Core ver 2.22
[   13.457201] NET: Registered protocol family 31
[   13.457209] Bluetooth: HCI device and connection manager initialized
[   13.457228] Bluetooth: HCI socket layer initialized
[   13.457241] Bluetooth: L2CAP socket layer initialized
[   13.457279] Bluetooth: SCO socket layer initialized
[   13.470927] Bluetooth: HCI UART driver ver 2.3
[   13.470939] Bluetooth: HCI UART protocol H4 registered
[   13.471009] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   13.471207] Bluetooth: HCI UART protocol Broadcom registered
[   13.755345] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.755356] Bluetooth: BNEP filters: protocol multicast
[   13.755373] Bluetooth: BNEP socket layer initialized
[   13.826967] Bluetooth: RFCOMM TTY layer initialized
[   13.826989] Bluetooth: RFCOMM socket layer initialized
[   13.827014] Bluetooth: RFCOMM ver 1.11
[  413.163365] JBD2: assertion failure: h_type=4 h_line_no=2470 block_no=304 jlist=0
[  413.163397] ------------[ cut here ]------------
[  413.163428] kernel BUG at fs/jbd2/transaction.c:1377!
[  413.163454] Internal error: Oops - BUG: 0 [#1] SMP ARM
[  413.163480] Modules linked in: rfcomm bnep hci_uart btbcm serdev bluetooth ecdh_generic 8021q garp stp llc brcmfmac brcmutil vc4 sha256_generic v3d drm_kms_helper cfg80211 gpu_sched rfkill drm bcm2835_codec(C) bcm2835_v4l2(C) snd_soc_core v4l2_mem2mem drm_panel_orientation_quirks bcm2835_mmal_vchiq(C) v4l2_common videobuf2_dma_contig snd_bcm2835(C) videobuf2_vmalloc snd_compress raspberrypi_hwmon videobuf2_memops hwmon videobuf2_v4l2 snd_pcm_dmaengine snd_pcm videobuf2_common vc_sm_cma(C) snd_timer snd syscopyarea sysfillrect sysimgblt fb_sys_fops videodev media rpivid_mem uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  413.163751] CPU: 1 PID: 1953 Comm: dpkg Tainted: G         C        4.19.97-v7l+ #1294
[  413.163779] Hardware name: BCM2835
[  413.163817] PC is at jbd2_journal_dirty_metadata+0x274/0x400
[  413.163847] LR is at __irq_work_queue_local+0x3c/0x7c
[  413.163871] pc : [<c04d8e3c>]    lr : [<c0321bdc>]    psr: 80000013
[  413.163896] sp : da23fad8  ip : da23f9e8  fp : da23fb2c
[  413.163919] r10: dc450c00  r9 : da922cc0  r8 : c1004d88
[  413.163942] r7 : 00000000  r6 : da922cc0  r5 : d8c63180  r4 : ef7c6880
[  413.163967] r3 : 00000000  r2 : deff6ca5  r1 : eff2a3d8  r0 : 00000045
[  413.163995] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  413.164022] Control: 30c5383d  Table: 1a661140  DAC: 55555555
[  413.164050] Process dpkg (pid: 1953, stack limit = 0x400a6dd9)
[  413.164075] Stack: (0xda23fad8 to 0xda240000)
[  413.164099] fac0:                                                       00000130 00000000
[  413.164132] fae0: 00000000 da23faf0 c09c996c c0292c68 da23fb4c da23fb00 c0412870 deff6ca5
[  413.164164] fb00: 00001000 ef7c6880 dc06e050 00000000 000014eb c0a11e94 00000000 dc450000
[  413.164203] fb20: da23fb7c da23fb30 c0474dd0 c04d8bd4 000003d0 00000130 00000000 c02d0238
[  413.164241] fb40: da23fbc4 da23fb50 c048e774 c0412848 00001000 deff6ca5 d8f2ee30 c0f86000
[  413.164278] fb60: d8f2effc da23fc04 00000000 00000000 da23fbec da23fb80 c0493d5c c0474d4c
[  413.164315] fb80: ef7c6880 ef7c6880 da23fbc4 00000000 dc450000 d8f2efac 00000000 c1004d88
[  413.164352] fba0: 00000000 d8f2ed80 dc06e050 ef7c6880 dc06e050 00000000 da23fbec deff6ca5
[  413.164389] fbc0: c0494104 da23fc04 d8f2ee30 c1004d88 c048634c dc06e050 dc450400 00000020
[  413.164426] fbe0: da23fc4c da23fbf0 c0494378 c04937ac 00000000 00000000 d8f2ee30 dc0362d0
[  413.164464] fc00: da23fc4c ef7c6880 00000000 00000000 00000000 00000000 daafcd40 deff6ca5
[  413.164501] fc20: dc0362d0 dc450000 00000000 00000000 daafcd40 00008000 dc0362d0 d8f2ee30
[  413.164538] fc40: da23fd94 da23fc50 c048634c c0494300 00000020 da23fc60 c0257190 c0256e24
[  413.164576] fc60: eff324c0 c03e10c4 c1004d88 00000000 ef7e0188 00002043 da23fca4 da23fc88
[  413.164613] fc80: c09b9ef8 c09b9e24 ef7d6ad0 deff6ca5 da23fcf4 00000001 da23fccc da23fca8
[  413.164650] fca0: c035cc54 c09b9ed8 00000000 00002043 c1004d88 c035cf58 00000000 c04733a8
[  413.164688] fcc0: da23fdb8 c0e9bad8 c0411d44 ef6d5040 ef7e0000 c0e9c600 00000000 c03e10c4
[  413.164725] fce0: da23fd0c da23fd28 00000006 ef9b9015 da23fd1c da23fe90 c1004d88 c03e1140
[  413.164762] fd00: da23fe90 db05c088 da23fd6c c04ae820 da23fd5c da23fd20 eff5e000 d8f2ee30
[  413.164799] fd20: 00000000 dc0362d0 da23fc80 d8eeda30 dc450400 dc06e050 c1004d88 00008000
[  413.164836] fd40: 5e9d6ad4 00000000 08650f4d c04d87f0 ef7be140 00000000 000003d1 000200c1
[  413.164873] fd60: db05c088 deff6ca5 da23ff50 000200c1 00000000 dc0362d0 da23e000 c0a118c0
[  413.164910] fd80: c0a11840 c100da04 da23fdfc da23fd98 c04ae820 c0484fe0 00000000 00000000
[  413.164948] fda0: 00000000 00000004 000009a6 00000027 0000000b c1004d88 d8eeda30 00000027
[  413.164985] fdc0: d8eeda18 00008000 00000000 deff6ca5 c03e1c14 000200c1 db05c088 00000000
[  413.165022] fde0: da23ff50 dae66900 da23fe90 c100da04 da23fe8c da23fe00 c03e524c c04ae6d8
[  413.165059] fe00: 00000000 c09c996c ef6d5040 d8eeda18 00000000 00008000 dc0362d0 da23e000
[  413.165096] fe20: d8eeda18 000200c1 c1004d88 00000041 c10056dc 00000040 00000001 00000002
[  413.165133] fe40: da23fe6c c1004d88 00000000 da23fee0 00000000 da23fe54 da23fe54 deff6ca5
[  413.165170] fe60: d8eedb54 c1004d88 c1004d88 da23ff50 da23fe90 00000001 da23e000 00000142
[  413.165208] fe80: da23ff44 da23fe90 c03e698c c03e4688 dc430010 db05c088 6428e4b0 00000012
[  413.165245] fea0: ef9b901c 006000c0 00000000 ef7b9110 dc0362d0 00000701 00000002 00000774
[  413.165282] fec0: 00000000 00000000 00000000 da23fed0 c03955b0 deff6ca5 60000013 0000000c
[  413.165320] fee0: db95f900 db95f918 00000000 00000400 000200c1 00000020 da23ff34 da23ff08
[  413.165357] ff00: ef9b9000 00000000 000200c1 00000002 ffffff9c ffffff9c ef9b9000 deff6ca5
[  413.165394] ff20: da23e000 0000000c c1004d88 ffffff9c ef9b9000 c02011c4 da23ff94 da23ff48
[  413.165431] ff40: c03d2304 c03e6918 dc430010 db05c088 000200c1 00008000 00000002 00000700
[  413.165468] ff60: 00000001 deff6ca5 198c6db9 00058284 00057c88 bef599b0 00000142 c02011c4
[  413.165505] ff80: da23e000 00000142 da23ffa4 da23ff98 c03d2400 c03d21d0 00000000 da23ffa8
[  413.165542] ffa0: c0201000 c03d23f0 00058284 00057c88 ffffff9c 028421d0 000200c1 00000000
[  413.165579] ffc0: 00058284 00057c88 bef599b0 00000142 00058124 028421d0 00000000 01f433e8
[  413.165616] ffe0: b6f28000 bef59588 00013d04 b6ea3464 60000010 ffffff9c 00000000 00000000
[  413.165668] [<c04d8e3c>] (jbd2_journal_dirty_metadata) from [<c0474dd0>] (__ext4_handle_dirty_metadata+0x90/0x244)
[  413.165719] [<c0474dd0>] (__ext4_handle_dirty_metadata) from [<c0493d5c>] (ext4_mark_iloc_dirty+0x5bc/0x8d8)
[  413.165770] [<c0493d5c>] (ext4_mark_iloc_dirty) from [<c0494378>] (ext4_mark_inode_dirty+0x84/0x20c)
[  413.165818] [<c0494378>] (ext4_mark_inode_dirty) from [<c048634c>] (__ext4_new_inode+0x1378/0x1724)
[  413.165863] [<c048634c>] (__ext4_new_inode) from [<c04ae820>] (ext4_create+0x154/0x1c4)
[  413.165911] [<c04ae820>] (ext4_create) from [<c03e524c>] (path_openat+0xbd0/0x1024)
[  413.165955] [<c03e524c>] (path_openat) from [<c03e698c>] (do_filp_open+0x80/0xec)
[  413.165998] [<c03e698c>] (do_filp_open) from [<c03d2304>] (do_sys_open+0x140/0x1f0)
[  413.166043] [<c03d2304>] (do_sys_open) from [<c03d2400>] (sys_openat+0x1c/0x20)
[  413.166086] [<c03d2400>] (sys_openat) from [<c0201000>] (ret_fast_syscall+0x0/0x28)
[  413.166119] Exception stack(0xda23ffa8 to 0xda23fff0)
[  413.166149] ffa0:                   00058284 00057c88 ffffff9c 028421d0 000200c1 00000000
[  413.166187] ffc0: 00058284 00057c88 bef599b0 00000142 00058124 028421d0 00000000 01f433e8
[  413.166222] ffe0: b6f28000 bef59588 00013d04 b6ea3464
[  413.166254] Code: 1affffc4 e5953008 e3530001 0affffc1 (e7f001f2)
[  413.166289] ---[ end trace 414d166ead8e7113 ]---
I have used the official raspberry pi power supply
Any idea what it could be?
kerry_s
Mon Apr 20, 2020 10:41 am
that looks like a bad sd card to me, cause the root is read only.
how are you creating your sd cards?
Biblioman
Mon Apr 20, 2020 11:13 am
I format the cards with SD Card Formatter v 5.01 and load the image with Win32DiskImager and I have also tested balenaEtcher both applications with the latest update.
I do not think it is from SD cards or applications, I have tried them and they work well with RPI3
Biblioman
Mon Apr 20, 2020 2:03 pm
I have installed LibreELEC for RPI4 and the same thing happens to me as when I install Raspbian Buster if I leave the default options in config.txt the system does not start if I lower the CPU frequency in the configuration file:
arm_freq = 700
The operating system starts although it is not stable at all
Any possible solution?
rmast
Fri Jun 19, 2020 8:02 pm
Isn't the board just showing signs of overheating damage?
I once had a RPi3 with the case advertized by the shop. However that case appeared not to be designed for long lasting compilation runs, and the Pi3 didn't throttle down enough because the built in thermostat didn't measure the temperature correctly.
When I got my replacement RPi3 I immediately bought a fan case with it. Nowadays there are passively cooled metal cases.
The RPi4 is known for it's temperature issues even more.
Sat Jun 20, 2020 10:01 am
All Raspberry Pi have Thermal Management and regards the 4B it runs a lot cooler than it did on release due to various updates. This Blog was 6 months after release and more updates since:
https://www.seeedstudio.com/blog/2019/1 ... than-ever/
