7ewis
StartX blank screen problem (solved)
Wed Dec 26, 2012 11:42 am
Hello guys, I finally got my Raspberry Pi yesterday! But STILL haven't managed to get it to work properly!
I was up till 2AM last night trying to make it run the graphical interface, but cannot make it work :(
So I am hoping you guys will be able to help me, I have formatted an SD card, used the tool to write the Wheezy image file to the SD, put the SD into my Pi and then connected ethernet, hdmi, wireless mouse and keyboard, and power. It turns on, the lights start flashing, it seems to be okay. I get to the initial settings screen, at first I didn't change anything, clicked finish, logged in and typed 'startx'. The white Raspberry wallpaper loads, but no desktop icons or menus or anything. All it would let me do is right click, and switch desktop, the internet browser wouldn't work and neither would any other options.
I don't have a clue why it does this, I have read a couple of other people mentioning this problem, but I can't find an answer.
I have re flashed the SD card multiple times, used different SD cards, changed the power supply, used multiple different tv's (read it might be an issue with the tv resolution, tried adjusting that too though), I tried updating it too, and nothing I do will make it work!
I then tried Arch Linux, and couldn't manage to get a desktop to appear, even though I followed a guide to install lxde and run it, I got to the last stage and startx still wouldn't work!
Ideally, I would like to make it work on Wheezy, but I just can't figure out why it won't work! Please help me someone!
Raspberry Pi - Model B (512MB)
cmatthews
Re: StartX
Wed Dec 26, 2012 1:52 pm
I wonder whether your LXDE desktop is extending beyond the edges of your physical display. It may be necessary to edit your config file to set the display resolution to ensure that the desktop is fitted to your display size. What screen are you using?
www.mydominion.co.uk
stevhorn5
Re: StartX
Wed Dec 26, 2012 2:09 pm
Also try turning Overscan on or off on the TV itself.
Cloudcentric
Re: StartX
Wed Dec 26, 2012 2:42 pm
You may have better luck with Raspbian: http://debianarmpi.blogspot.co.uk
Arch does not use StartX by default: http://archlinuxpi.blogspot.co.uk
I know everything about nothing"
7ewis
Re: StartX
Wed Dec 26, 2012 2:51 pm
I have a 50" LG TV which I tried it on first, I used the Aspect setting to change it to original, 16:9, etc. and it still didn't show properly.
Then I tried it on a 42" Panasonic, tried adjusting the screen and it still showed the same.
Lastly, I tried it on a 22" Toshiba TV, and again the same problem.
I have only been using HDMI as the output, I have used different leads as well, but mostly the one that I bought from Farnell with my Pi.
Am I supposed to change the Overscan option on the intial start up? Because I haven't touched it so far, but surely after being tested on 3 TV's it should have worked on one... Is there a way to get the options screen back up again without flashing the SD again, I'm sure there is but I don't know how.
7ewis
Re: StartX
Wed Dec 26, 2012 2:54 pm
I'm back to Raspbian now, I was only using Arch just to see if I could get a desktop to work on another OS, it failed so I'm back to Wheezy.
I did follow a guide to get startx, or the equivelent to work on Arch though, it seemed to be running fine, until I had to type the command in at the end, as it didn't work.
Cloudcentric
Re: StartX
Wed Dec 26, 2012 2:57 pm
7ewis wrote:Am I supposed to change the Overscan option on the intial start up? Because I haven't touched it so far, but surely after being tested on 3 TV's it should have worked on one... Is there a way to get the options screen back up again without flashing the SD again, I'm sure there is but I don't know how.
Type raspi-config at the command prompt to launch the configuration menu..
7ewis
Re: StartX
Wed Dec 26, 2012 3:22 pm
Okay thank you!
One of my neighbours has invited my family around later for some drinks, and he has 2 raspberry pi's so he said he'll have a look at it for me. He works with computers for his job so hopefully he'll be able to give me some advice.
I'll let you know.
stevhorn5
Re: StartX
Wed Dec 26, 2012 3:24 pm
Good luck. You'll sort it.
7ewis
Re: StartX
Thu Dec 27, 2012 12:47 pm
He didn't get time to look at it yesterday, so I'm going to try and work it out myself again.
So I have to change the overscan some how? I did try 3 TV's so surely one of them should have fitted it anyway?
Jim JKla
Re: StartX
Thu Dec 27, 2012 12:51 pm
Have a dip in the surf here http://elinux.org/R-Pi_Troubleshooting some overscan info at the bottom of the page. ;)
1dwb
Re: StartX
Thu Dec 27, 2012 2:55 pm
Hi I am experiencing exactly the same problem. After typing 'startx' I am presented with the Raspberry Pi wallpaper but no icons. Played with the overscan options in the config.txt file (edited SD card image in Windows) but this just resized wall paper within display but still no icons. So assuming this solution is headed up the wrong path. Possibly something missing from the X windows installation /setup? Followed all instructions from the recent quick start guide ( e,g, raspbian wheezy image). Using Dell monitor with HDMI to DVI connector. Any further pointers appreciated.
brizza1
Re: StartX
Thu Dec 27, 2012 4:55 pm
I have recently used start x on my raspberry pi. It has gone straight to the white screen. What shall I do next?
7ewis
Re: StartX
Thu Dec 27, 2012 5:29 pm
1dwb please let me know here if you find a solution, I don't have a clue what is wrong :(
What SD card are you using? Just seeing if I can narrow the problem down a bit.
I installed Raspmc fine, and that all works. So the Pi must be okay, it must be something to do with the Wheezy image? I don't know :?:
Jim JKla
Re: StartX
Thu Dec 27, 2012 5:38 pm
There is a fix to do with the changed 512Mb memory I am still on the old 256Mb but I'll look into this and put something on the wiki ;)
This change may be the cause of the problems.
7ewis
Re: StartX
Thu Dec 27, 2012 6:02 pm
Oh really? I have the 512mb version, I tried changing the overscan but ddin't really know what I was doing and ended up with a black screen.
I know how to stop the TV scanning, as there is options of '16:9', 'Just Scan', 'Zoom', 'Zoom 1', 'Original' etc. so I'll choose 16:9 or Original and see if I can make it work.
What lines of code might I need to add? If you let me know I'll test it for you, so you will know what to put on the wiki :)
Jim JKla
Re: StartX
Thu Dec 27, 2012 6:09 pm
There is a fully commented full version of config.txt here
https://raw.github.com/Evilpaul/RPi-con ... config.txt
Warning this is not for the faint hearted anything on a line that starts with a # is a comment ;)
7ewis
Re: StartX
Thu Dec 27, 2012 6:24 pm
So what needs to be uncommented then? I'm just formatting an SD now, I'll put Wheezy on it and paste the code into the config file
Jim JKla
Re: StartX
Thu Dec 27, 2012 6:40 pm
It's a trial and error thing obviously the screen setup you have loads of options under HDMI mode but you only use one at a time.
Like I said it's not for the faint hearted.
Obvioussly stv-mode you are only going to use the one for your TV setup
Europe
USA
Japan
Brazil
I don't know where in the world you are it's not in your profile. :D
I actually use "hdmi_force_hotplug=1"
For some reason the version of wheezy I am using keeps trying to use the RCA socket if I don't.
This can be useful because you can start yor RPi first then put the monitor on later and it's using the HDMI.
Normally if it does not detect the HDMI it defaults to RCA (the composite channel (yellow phono)) ;)
Try not to change too much at once. ;)
7ewis
Re: StartX
Thu Dec 27, 2012 6:56 pm
Yeah, I'm new here :)
I'm from the UK, so I don't think I have to change much really.
I'll be back, just have dinner now.
Jim JKla
Re: StartX
Thu Dec 27, 2012 6:57 pm
Nothing wrong in being New. ;)
7ewis
Re: StartX
Thu Dec 27, 2012 7:32 pm
Ah that explains why it doesn't seem to work unless I have the HDMI cable plugged in, I'll definitely set that!
So I'll need to change the bottom overscan option to a minus number?
Edit: Okay, so I turned off overscan and set the HDMI force, and that gave me a completely full screen of the Raspberry Pi logo rather than having some black bars at the sides, but still no menu.
I'm sure it must be something else, as even right clicking, all I can do is change desktop nothing else works!
7ewis
Re: StartX
Thu Dec 27, 2012 8:37 pm
It hasn't been letting me update, it says 'Error running do_update' so I rm'ed /var/lib/dpkg/status
and then touched it, that seemed to fix the problem.
Then I installed tightvnc to see if I could get the screen working on there, and then that update failed.
[email protected] / $ sudo apt-get install tightvncserver
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  apt-utils coreutils cpp cpp-4.6 debconf debconf-i18n debianutils dpkg e2fslibs e2fsprogs fontconfig-config gcc-4.6-base gcc-4.7-base ifupdown
  initscripts insserv iproute libacl1 libapt-inst1.5 libapt-pkg4.12 libatm1 libattr1 libblkid1 libbz2-1.0 libc-bin libc6 libclass-isa-perl libcomerr2
  libdb5.1 libdrm-nouveau1a libdrm-radeon1 libdrm2 libexpat1 libfontconfig1 libfontenc1 libfreetype6 libgcc1 libgdbm3 libgl1-mesa-dri libgl1-mesa-glx
  libglapi-mesa libgmp10 libgpm2 libice6 libjpeg8 liblocale-gettext-perl liblzma5 libmpc2 libmpfr4 libncurses5 libpam-modules libpam-modules-bin
  libpam0g libpng12-0 libselinux1 libsemanage-common libsemanage1 libsepol1 libslang2 libsm6 libss2 libstdc++6 libswitch-perl libtext-charwidth-perl
  libtext-iconv-perl libtext-wrapi18n-perl libtinfo5 libustr-1.0-1 libuuid1 libx11-6 libx11-data libx11-xcb1 libxau6 libxaw7 libxcb-glx0
  libxcb-shape0 libxcb1 libxcomposite1 libxcursor1 libxdamage1 libxdmcp6 libxext6 libxfixes3 libxfont1 libxft2 libxi6 libxinerama1 libxmu6 libxmuu1
  libxpm4 libxrandr2 libxrender1 libxt6 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 lsb-base multiarch-support netbase passwd perl perl-base
  perl-modules psmisc sensible-utils sysv-rc sysvinit-utils tar ttf-dejavu-core tzdata ucf util-linux uuid-runtime x11-common x11-utils
  x11-xserver-utils xauth xfonts-base xfonts-encodings xfonts-utils zlib1g
Suggested packages:
  xz-utils cpp-doc gcc-4.6-locales debconf-doc debconf-utils whiptail dialog gnome-utils libterm-readline-gnu-perl libgtk2-perl libnet-ldap-perl
  libqtgui4-perl libqtcore4-perl apt gpart parted e2fsck-static isc-dhcp-client dhcp-client ppp rdnssd net-tools bootchart2 iproute-doc glibc-doc
  libglide3 gpm libpam-doc perl-doc make libpod-plainer-perl sysv-rc-conf bum bootlogd sash bzip2 ncompress tightvnc-java util-linux-locales kbd
  console-tools dosfstools mesa-utils nickle cairo-5c xorg-docs-core xfs xserver
The following NEW packages will be installed:
  perl-modules psmisc sensible-utils sysv-rc sysvinit-utils tar tightvncserver ttf-dejavu-core tzdata ucf util-linux uuid-runtime x11-common
  x11-utils x11-xserver-utils xauth xfonts-base xfonts-encodings xfonts-utils zlib1g
0 upgraded, 123 newly installed, 0 to remove and 0 not upgraded.
Need to get 55.4 MB of archives.
After this operation, 157 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libc-bin armhf 2.13-37+rpi1 [1,201 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main gcc-4.7-base armhf 4.7.2-4+rpi1 [144 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main multiarch-support armhf 2.13-37+rpi1 [149 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgcc1 armhf 1:4.7.2-4+rpi1 [54.5 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libc6 armhf 2.13-37+rpi1 [4,098 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libbz2-1.0 armhf 1.0.6-4 [47.4 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main liblzma5 armhf 5.1.1alpha+20120614-2 [199 kB]
Get:8 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libselinux1 armhf 2.1.9-5 [84.1 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ wheezy/main zlib1g armhf 1:1.2.7.dfsg-13 [87.2 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ wheezy/main tar armhf 1.26-4 [967 kB]
Get:11 http://mirrordirector.raspbian.org/raspbian/ wheezy/main dpkg armhf 1.16.9 [2,497 kB]
Get:12 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libattr1 armhf 1:2.4.46-8 [18.5 kB]
Get:13 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libacl1 armhf 2.2.51-8 [27.7 kB]
Get:14 http://mirrordirector.raspbian.org/raspbian/ wheezy/main coreutils armhf 8.13-3.4 [5,244 kB]
Get:15 http://mirrordirector.raspbian.org/raspbian/ wheezy/main sensible-utils all 0.0.7 [8,850 B]
Get:16 http://mirrordirector.raspbian.org/raspbian/ wheezy/main debianutils armhf 4.3.2 [77.6 kB]
Get:17 http://mirrordirector.raspbian.org/raspbian/ wheezy/main e2fslibs armhf 1.42.5-1 [185 kB]
Get:18 http://mirrordirector.raspbian.org/raspbian/ wheezy/main perl-base armhf 5.14.2-16+rpi1 [1,467 kB]
Get:19 http://mirrordirector.raspbian.org/raspbian/ wheezy/main debconf all 1.5.48 [174 kB]
Get:20 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpam0g armhf 1.1.3-7.1 [122 kB]
Get:21 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libsemanage-common all 2.1.6-6 [23.2 kB]
Get:22 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libsepol1 armhf 2.1.4-3 [126 kB]
Get:23 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libustr-1.0-1 armhf 1.0.4-3 [72.4 kB]
Get:24 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libsemanage1 armhf 2.1.6-6 [89.1 kB]
Get:25 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdb5.1 armhf 5.1.29-5 [648 kB]
Get:26 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpam-modules-bin armhf 1.1.3-7.1 [100 kB]
Get:27 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpam-modules armhf 1.1.3-7.1 [324 kB]
Get:28 http://mirrordirector.raspbian.org/raspbian/ wheezy/main passwd armhf 1:4.1.5.1-1 [1,173 kB]
Get:29 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libuuid1 armhf 2.20.1-5.3 [57.7 kB]
Get:30 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libblkid1 armhf 2.20.1-5.3 [119 kB]
Get:31 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libcomerr2 armhf 1.42.5-1 [54.7 kB]
Get:32 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libss2 armhf 1.42.5-1 [59.0 kB]
Get:33 http://mirrordirector.raspbian.org/raspbian/ wheezy/main lsb-base all 4.1+Debian8 [26.3 kB]
Get:34 http://mirrordirector.raspbian.org/raspbian/ wheezy/main tzdata all 2012j-1 [500 kB]
Get:35 http://mirrordirector.raspbian.org/raspbian/ wheezy/main sysvinit-utils armhf 2.88dsf-34 [95.3 kB]
Get:36 http://mirrordirector.raspbian.org/raspbian/ wheezy/main insserv armhf 1.14.0-5 [63.8 kB]
Get:37 http://mirrordirector.raspbian.org/raspbian/ wheezy/main sysv-rc all 2.88dsf-34 [80.2 kB]
Get:38 http://mirrordirector.raspbian.org/raspbian/ wheezy/main initscripts armhf 2.88dsf-34 [90.8 kB]
Get:39 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libtinfo5 armhf 5.9-10 [264 kB]
Get:40 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libncurses5 armhf 5.9-10 [94.6 kB]
Get:41 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libslang2 armhf 2.2.4-15 [515 kB]
Get:42 http://mirrordirector.raspbian.org/raspbian/ wheezy/main util-linux armhf 2.20.1-5.3 [669 kB]
Get:43 http://mirrordirector.raspbian.org/raspbian/ wheezy/main e2fsprogs armhf 1.42.5-1 [983 kB]
Get:44 http://mirrordirector.raspbian.org/raspbian/ wheezy/main iproute armhf 20120521-3 [436 kB]
Get:45 http://mirrordirector.raspbian.org/raspbian/ wheezy/main ifupdown armhf 0.7.5 [61.6 kB]
Get:46 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libstdc++6 armhf 4.7.2-4+rpi1 [291 kB]
Get:47 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libapt-pkg4.12 armhf 0.9.7.7+rpi1 [869 kB]
Get:48 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libapt-inst1.5 armhf 0.9.7.7+rpi1 [162 kB]
Get:49 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgdbm3 armhf 1.8.3-11 [44.9 kB]
Get:50 http://mirrordirector.raspbian.org/raspbian/ wheezy/main liblocale-gettext-perl armhf 1.05-7 [19.6 kB]
Get:51 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgpm2 armhf 1.20.4-6 [34.9 kB]
Get:52 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libatm1 armhf 1:2.5.1-1.5 [71.1 kB]
Get:53 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdrm2 armhf 2.4.33-3 [440 kB]
Get:54 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdrm-nouveau1a armhf 2.4.33-3 [431 kB]
Get:55 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdrm-radeon1 armhf 2.4.33-3 [439 kB]
Get:56 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libexpat1 armhf 2.1.0-1 [117 kB]
Get:57 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libfreetype6 armhf 2.4.9-1 [402 kB]
Get:58 http://mirrordirector.raspbian.org/raspbian/ wheezy/main ucf all 3.0025+nmu3 [70.8 kB]
Get:59 http://mirrordirector.raspbian.org/raspbian/ wheezy/main ttf-dejavu-core all 2.33-3 [1,021 kB]
Get:60 http://mirrordirector.raspbian.org/raspbian/ wheezy/main fontconfig-config all 2.9.0-7.1 [233 kB]
Get:61 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libfontconfig1 armhf 2.9.0-7.1 [285 kB]
Get:62 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libfontenc1 armhf 1:1.1.1-1 [22.6 kB]
Get:63 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libglapi-mesa armhf 8.0.5-3 [52.0 kB]
Get:64 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxau6 armhf 1:1.0.7-1 [17.6 kB]
Get:65 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxdmcp6 armhf 1:1.1.1-1 [24.6 kB]
Get:66 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxcb1 armhf 1.8.1-2 [42.7 kB]
Get:67 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libx11-data all 2:1.5.0-1 [189 kB]
Get:68 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libx11-6 armhf 2:1.5.0-1 [836 kB]
Get:69 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libx11-xcb1 armhf 2:1.5.0-1 [139 kB]
Get:70 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxcb-glx0 armhf 1.8.1-2 [27.1 kB]
Get:71 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxdamage1 armhf 1:1.1.3-2 [13.8 kB]
Get:72 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxext6 armhf 2:1.3.1-2 [49.7 kB]
Get:73 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxfixes3 armhf 1:5.0-4 [19.8 kB]
Get:74 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxxf86vm1 armhf 1:1.1.2-1 [18.4 kB]
Get:75 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgl1-mesa-glx armhf 8.0.5-3 [121 kB]
Get:76 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgmp10 armhf 2:5.0.5+dfsg-2 [208 kB]
Get:77 http://mirrordirector.raspbian.org/raspbian/ wheezy/main x11-common all 1:7.7+1 [278 kB]
Get:78 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libice6 armhf 2:1.0.8-2 [56.2 kB]
Get:79 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libjpeg8 armhf 8d-1 [132 kB]
Get:80 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libmpfr4 armhf 3.1.0-5 [524 kB]
Get:81 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpng12-0 armhf 1.2.49-1 [179 kB]
Get:82 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libsm6 armhf 2:1.2.1-2 [32.5 kB]
Get:83 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxt6 armhf 1:1.1.3-1 [181 kB]
Get:84 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxmu6 armhf 2:1.1.1-1 [59.1 kB]
Get:85 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxpm4 armhf 1:3.5.10-1 [44.9 kB]
Get:86 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxaw7 armhf 2:1.0.10-2 [192 kB]
Get:87 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxcb-shape0 armhf 1.8.1-2 [10.5 kB]
Get:88 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxcomposite1 armhf 1:0.4.3-2 [16.2 kB]
Get:89 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxrender1 armhf 1:0.9.7-1 [29.9 kB]
Get:90 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxcursor1 armhf 1:1.1.13-1 [23.7 kB]
Get:91 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxft2 armhf 2.3.1-1 [55.4 kB]
Get:92 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxi6 armhf 2:1.6.1-1 [70.2 kB]
Get:93 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxinerama1 armhf 2:1.1.2-1 [16.1 kB]
Get:94 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxmuu1 armhf 2:1.1.1-1 [23.0 kB]
Get:95 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxrandr2 armhf 2:1.3.2-2 [31.1 kB]
Get:96 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxtst6 armhf 2:1.2.1-1 [25.5 kB]
Get:97 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxv1 armhf 2:1.0.7-1 [20.2 kB]
Get:98 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxxf86dga1 armhf 2:1.1.3-2 [20.8 kB]
Get:99 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libmpc2 armhf 0.9-4 [32.0 kB]
Get:100 http://mirrordirector.raspbian.org/raspbian/ wheezy/main apt-utils armhf 0.9.7.7+rpi1 [370 kB]
Get:101 http://mirrordirector.raspbian.org/raspbian/ wheezy/main netbase all 5.0 [20.1 kB]
Get:102 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libtext-iconv-perl armhf 1.7-5 [16.7 kB]
Get:103 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libtext-charwidth-perl armhf 0.04-7 [10.6 kB]
Get:104 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libtext-wrapi18n-perl all 0.06-7 [8,980 B]
Get:105 http://mirrordirector.raspbian.org/raspbian/ wheezy/main debconf-i18n all 1.5.48 [236 kB]
Get:106 http://mirrordirector.raspbian.org/raspbian/ wheezy/main gcc-4.6-base armhf 4.6.3-12+rpi1 [141 kB]
Get:107 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libclass-isa-perl all 0.36-3 [12.3 kB]
Get:108 http://mirrordirector.raspbian.org/raspbian/ wheezy/main perl-modules all 5.14.2-16+rpi1 [3,441 kB]
Get:109 http://mirrordirector.raspbian.org/raspbian/ wheezy/main perl armhf 5.14.2-16+rpi1 [3,661 kB]
Get:110 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libswitch-perl all 2.16-2 [20.9 kB]
Get:111 http://mirrordirector.raspbian.org/raspbian/ wheezy/main cpp-4.6 armhf 4.6.3-12+rpi1 [4,248 kB]
Get:112 http://mirrordirector.raspbian.org/raspbian/ wheezy/main cpp armhf 4:4.6.3-8 [16.6 kB]
Get:113 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgl1-mesa-dri armhf 8.0.5-3 [2,467 kB]
Get:114 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libxfont1 armhf 1:1.4.5-2 [146 kB]
Get:115 http://mirrordirector.raspbian.org/raspbian/ wheezy/main psmisc armhf 22.19-1 [131 kB]
Get:116 http://mirrordirector.raspbian.org/raspbian/ wheezy/main x11-utils armhf 7.7~1 [215 kB]
Get:117 http://mirrordirector.raspbian.org/raspbian/ wheezy/main xauth armhf 1:1.0.7-1 [34.9 kB]
Get:118 http://mirrordirector.raspbian.org/raspbian/ wheezy/main tightvncserver armhf 1.3.9-6.4 [786 kB]
Get:119 http://mirrordirector.raspbian.org/raspbian/ wheezy/main uuid-runtime armhf 2.20.1-5.3 [60.1 kB]
Get:120 http://mirrordirector.raspbian.org/raspbian/ wheezy/main x11-xserver-utils armhf 7.7~3 [181 kB]
Get:121 http://mirrordirector.raspbian.org/raspbian/ wheezy/main xfonts-encodings all 1:1.0.4-1 [584 kB]
Get:122 http://mirrordirector.raspbian.org/raspbian/ wheezy/main xfonts-utils armhf 1:7.7~1 [92.2 kB]
Get:123 http://mirrordirector.raspbian.org/raspbian/ wheezy/main xfonts-base all 1:1.0.3 [6,181 kB]
Fetched 55.4 MB in 2min 51s (323 kB/s)
E: Cannot get debconf version. Is debconf installed?
debconf: apt-extracttemplates failed: No such file or directory
Extracting templates from packages: 24%E: Cannot get debconf version. Is debconf installed?
Extracting templates from packages: 48%E: Cannot get debconf version. Is debconf installed?
Extracting templates from packages: 73%E: Cannot get debconf version. Is debconf installed?
Extracting templates from packages: 97%E: Cannot get debconf version. Is debconf installed?
Extracting templates from packages: 100%
Selecting previously unselected package libc-bin.
(Reading database ... 45 files and directories currently installed.)
Unpacking libc-bin (from .../libc-bin_2.13-37+rpi1_armhf.deb) ...
Setting up libc-bin (2.13-37+rpi1) ...
Selecting previously unselected package gcc-4.7-base:armhf.
(Reading database ... 116 files and directories currently installed.)
Unpacking gcc-4.7-base:armhf (from .../gcc-4.7-base_4.7.2-4+rpi1_armhf.deb) ...
Setting up gcc-4.7-base:armhf (4.7.2-4+rpi1) ...
Selecting previously unselected package multiarch-support.
(Reading database ... 125 files and directories currently installed.)
Unpacking multiarch-support (from .../multiarch-support_2.13-37+rpi1_armhf.deb) ...
Selecting previously unselected package libc6:armhf.
Unpacking libc6:armhf (from .../libc6_2.13-37+rpi1_armhf.deb) ...
Selecting previously unselected package libgcc1:armhf.
dpkg: regarding .../libgcc1_1%3a4.7.2-4+rpi1_armhf.deb containing libgcc1:armhf, pre-dependency problem:
 libgcc1 pre-depends on multiarch-support
  multiarch-support is unpacked, but has never been configured.
dpkg: error processing /var/cache/apt/archives/libgcc1_1%3a4.7.2-4+rpi1_armhf.deb (--unpack):
 pre-dependency problem - not installing libgcc1:armhf
I really don't know whats wrong :(
1dwb
Re: StartX
Thu Dec 27, 2012 8:53 pm
7ewis wrote:1dwb please let me know here if you find a solution, I don't have a clue what is wrong :(
No not found solution yet. Yes I am using the new model B with 512 MB and a Lexar 8gb SDHC Card.
7ewis
Re: StartX
Thu Dec 27, 2012 9:02 pm
Hmm okay, so we both have the same Pi, the SD cards should be fine too.
That was the only thing I was a bit unsure of, but I don't see why yours would be wrong as well.
This is so annoying!
