geffers
Old SD (or microSD) cards
Thu Mar 26, 2020 3:57 pm
Anyone any suggestions as to what to do with working but unused microSD cards.
I recall when USB memory sticks first came out capacity was measured in MegaBytes, now we are close to Terrabytes being the norm. I've got a few 8GB class 4 cards that I am reluctant to just throw away, so small in size can they be recycled, or is it worth it?
Geoff
davidcoton
Re: Old SD (or microSD) cards
Thu Mar 26, 2020 4:01 pm
I'm sure they can be used for levelling up wonky chairs (maybe not microSD).
Or filling up your drawer where you keep all your obsolete electronics "just in case".
Signature retired
pica200
Thu Mar 26, 2020 4:23 pm
Use them for archiving data like pictures. They should be able to hold the data at least 20 years.
Thu Mar 26, 2020 6:03 pm
I use old cards like that to build up systems for testing stuff out on. I can install a fresh Raspbian on them, try stuff out, then re-write them as required when it goes wrong.
Unreadable squiggle
Thu Mar 26, 2020 7:17 pm
I used old SD cards, with whatever puny capacity they had years ago, to hold the CP/M operating system image from My Z80 emulator on the Parallax Propeller MCU.
Which was wasteful enough. I would feel really silly now putting eight 8MB disk images on a 64GB SD card today,
emma1997
Thu Mar 26, 2020 7:44 pm
Me too. Only in my case it's the 2G that are 'old'. In fact even most of my 32G cards are partitioned to 4G because I hate spending hours waiting for progress bars. Or worse, no progress bar and wondering if the system hung.
Also noteworthy that reliable 2G and 4G cards cost more than bigger ones. There are situations where the bigger ones just don't work so probably not a good idea to toss them.
jbudd
Thu Mar 26, 2020 11:07 pm
In my experience, micro sd cards that aren't in use in a camera, phone or Raspberry Pi simply evaporate.
Maybe they elope to Africa with ballpoint pens and teaspoons.
My stash of full sized SD cards only reappeared in the desk drawer when I disposed of the last Pi that could use them.
Botspot
Thu Mar 26, 2020 11:13 pm
Old SD cards are perfect for mechanical stress testing:
From this thread:
Heater wrote:
Wed Feb 05, 2020 8:28 pm
W. H. Heydt,
W. H. Heydt wrote:
Wed Feb 05, 2020 6:28 pm
The microSD cards are pretty thin and fragile.
That prompted me to pull an 8GB card out of a Pi and try to break it in half.
Amazing, it's actually pretty easy.
Also amazing that I have never broken one before or anything else on a Pi. Given how I keep them in junk boxes with piles of other stuff and tote them around in my pockets and so on.
Edit: revised due to Heater's statement of confusion
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
Thu Mar 26, 2020 11:17 pm
W. H. Heydt,
The microSD cards a pretty thin and fragile.
I think quoting me from some other thread months ago might confuse people. It confused me :)
geffers
Fri Mar 27, 2020 9:11 am
I've still got 4 Pi devices that use full sized cards, all in regular use, I just use micro cards in a full size adapter.
Geffers
geffers
Fri Mar 27, 2020 9:13 am
You'd have to be very methodical with records and storage.
Geffers
geffers
Fri Mar 27, 2020 9:19 am
That is a decent idea,, I do have one of those plastic holder that store 8 microSD cards, don't write on the labels, just keep a file numbered 1-8 with details of card content on it.
Geffers
FTrevorGowen
Fri Mar 27, 2020 11:34 am
Geffers
And, maybe, FWIW, also log their, decoded, CID info. : https://www.cpmspectrepi.uk/raspberry_p ... cking.html ?
Trev.
Paul Hutch
Fri Mar 27, 2020 1:49 pm
Geffers
To make it easier to track and catalog the contents be sure to give each card a unique volume label and then use Virtual Volumes View to catalog all the cards. http://vvvapp.sourceforge.net/
I use this for all my external hard drives, memory cards, thumb drives, and optical media that contain archived data.
mikerr
Fri Mar 27, 2020 2:03 pm
Old small SD are useful for old pi models to enable USB / network boot.
Just put the single file bootcode.bin on an otherwise empty SD card, and that enables them to boot from USB or network.
