Redcarred2
Raspbian without preinstalled software
Wed Mar 18, 2020 3:11 pm
I am in need of a image of raspbian for the Raspberry pi 4b with 4 GB of ram without any of the bloatware, I just need the file explorer and the command prompt, any ideas? Thanks! :D
Re: Raspbian without preinstalled software
Wed Mar 18, 2020 3:36 pm
Raspbian Lite.
pcmanbob
Wed Mar 18, 2020 4:25 pm
Raspbian buster lite will give you the command line only , there is no GUI so no file explorer.
To have the file explorer as well you need raspbian buster with desktop.
sparkyhall
Wed Mar 18, 2020 4:33 pm
You can install command line file managers such as midnight commander (mc).
Redcarred2
Wed Mar 18, 2020 5:27 pm
Is there a way I can install the buster desktop, from buster lite without the bloatware of all the ides and random games?
Edit: Im trying to run a minecraft forge server (I know its not the best host but whatever)
pcmanbob
Wed Mar 18, 2020 5:57 pm
There are 2 desktop versions
Raspbian buster with desktop
Raspbian buster with desktop and recommended software
So I suggest you try the first one..
MikeGrimwood
Wed Mar 18, 2020 8:03 pm
You can also install raspbian buster lite and then add the gui, by
sudo apt-get install raspberrypi-uixmods
Mike
stan_qaz
Wed Mar 18, 2020 10:34 pm
It isn't that hard to go down the list of installed software and remove a bunch of it.
On the other hand what do you hope to gain, aside from a bit of SD card space, by removing software.
Imperf3kt
Wed Mar 18, 2020 11:20 pm
A cleaner, neater OS experience.
Icons take space in the Raspbian menu. Space one must skip past to find the programs one actually wants to use.
55:55:44:44:4C
52:4C:52:42:41
Rose coloured glasses are difficult to see through.
Redcarred2
Fri Mar 20, 2020 9:09 pm
Mike
Thanks! its worked!
emma1997
Fri Mar 20, 2020 9:23 pm
Does anyone know how much extra space that adds to Buster Lite?
DirkS
Fri Mar 20, 2020 9:50 pm
If you run 'sudo apt install raspberrypi-ui-mods'' it will tell you how much extra space it takes. No idea how accurate it is.
On my (already modified) Lite system it's about 400MB
