THORNADOR
Control LED
Wed Mar 11, 2020 10:38 am
Hi, I´m doing a web page for the control of one LED. I have seen two different possibilites for do it, but I don´t know which one is better (or if it works).
OPTION 1
<html>
<head>
<meta name="viewport" content="width=device-width" />
<title>Raspberry Pi WiFi Controlled LED</title>
</head>
       <body>
       <center><h1>Control LED using Raspberry Pi Webserver</h1>
         <form method="get" action="index.php">
            <input type="submit" style = "font-size: 14 pt" value="OFF" name="off">
            <input type="submit" style = "font-size: 14 pt" value="ON" name="on">
         </form>​​​
            </center>
	   </body>
</html>
<?php
    shell_exec("/usr/local/bin/gpio -g mode 27 out");
    if(isset($_GET['off']))
            echo "LED is off";
            shell_exec("/usr/local/bin/gpio -g write 27 0");
    else if(isset($_GET['on']))
            echo "LED is on";
            shell_exec("/usr/local/bin/gpio -g write 27 1");
OPTION 2 (with Pyton)
<html>
 <body>
  <!--GPIO-->
  <form action="" method="post">
			<input type="submit" name="on" value="On">
			<input type="submit" name="offr" value="Off">
 </body>
</html>
<?php
  if ($_POST[on]) {
   $a- exec("sudo python /var/www/html/on.py");
   echo $a;
  if ($_POST[off]) {
   $a- exec("sudo python /var/www/html/off.py");
   echo $a;
## on.py
#!usr/bin/env/ python
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(27, GPIO.OUT)
GPIO.output(27, GPIO.HIGH)
GPIO.cleanup()
## off.py
GPIO.output(27, GPIO.LOW)
GPIO.cleanup()
JohnsUPS
Re: Control LED
Wed Mar 11, 2020 10:42 am
neilgl
Re: Control LED
Wed Mar 11, 2020 11:07 am
I would go with (2) the python method. The first one uses wiringpi which is no longer supported unfortunately.
THORNADOR
Re: Control LED
Wed Mar 11, 2020 11:59 am
And the code is well write, isn´t it?
