I like to place 3 (or less) x RPi Zero W into either a dummy wall light or celling smoke detector that have electrical mains cables fitted from the wall/celling.
Due to the size of the dummy light/smoke detector and lack of electrical wall plate (DP Switched Plug Socket) nearby the official "Raspberry Pi Universal Power Supply" is out of question to power via Micro USB port.
Is there a power supply (either from Micro USB port or via GPIO header) small enough to fit inside dummy wall light or celling smoke detector that can power all 3 x RPi Zero W's and can be connected directly to mains power cables from the wall/celling?
I have checked Screwfix and Farnell, but nothing there ....
The RPi's will be using the CSI camera slot and Wi-Fi.
