stan_qaz
Pi 4 No VNC screen if booted without monitor - Fix
Tue Feb 25, 2020 1:12 am
I dug the information here out of several other posts and thought having it together with a title that might make it easier to find for folks with VNC issues would be good.
My Pi 4s would boot up just fine with a monitor connected and I could also VNC into them with no issues. However, with no monitor connected I at boot I could no longer VNC in, ssh still worked though. VNC did connect but showed a "No Screen to Display" error.
To force the video system to start with no monitor connected:
Edit: /boot/config.txt
Change these lines to look like this: ( The 2 : 0x53 gives you a working 1600 x 900 option that works good on a 1980x1080 screen )
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=0x53
Then set your preferred resolution with the screen tool and reboot.
HDMI Group and Modes list and much other good information:
viewtopic.php?f=28&t=5851
