alixm
Where can I download Raspbian 32 bit
Mon Feb 24, 2020 5:21 pm
HI i have a Pi 2 and my card is corrupted. I can't find a 32 bit imnage, where can I find this dowload please? Please do not suggest that I buy a new PI! I have no money. I just need to get the 32 bit image as my Pi does not support 64 bit. Thanks.
dickon
Re: Where can I download Raspbian 32 bit
Mon Feb 24, 2020 6:07 pm
There is no 64b Raspbian -- yet. There is a 64b kernel optionally available for the hardware that can run them, but that won't be loaded by the bootloader on machines that can't cope, and, anyway, you need to explicitly ask for it -- it isn't the default.
Botspot
Mon Feb 24, 2020 6:15 pm
A 64 bit kernel is being tested on the Pi 4, but it's not the default yet. Also I would be shocked if someday Raspbian stops being able to run on older Pies. (Backwards compatibility is a high priority to the Foundation)
The latest Buster runs fine on all Pies - even on the slowest 32-bit Pi zero.
You can get it at https://www.raspberrypi.org/downloads/raspbian/.
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
Mon Feb 24, 2020 6:41 pm
Raspbian Buster is ARMHF 32bit and suitable for all Raspberry Pi SBC & Compute Module:
RPi 4B 4GB (SSD Boot)..
lpsw
Mon Feb 24, 2020 7:37 pm
<snip>
I can't find a 32 bit imnage, where can I find this dowload please? Please do not suggest that I buy a new PI! <snip>
Not sure why you would think that anyone would suggest your failure to find the downloads page (see the very top of this page) would result in your needing to buy a new Pi.
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
Imperf3kt
Mon Feb 24, 2020 8:46 pm
I think instead of Pi zero, you meant the Pi 1b
55:55:44:44:4C
52:4C:52:42:41
W. H. Heydt
Tue Feb 25, 2020 12:16 am
To answer the question posed in the thread title.. At the top of every page. Click on "Downloads" then follow the obvious links from there.
Burngate
Tue Feb 25, 2020 10:01 am
Possibly the confusion is because nowhere on the downloads page does it mention "32 bit"
... I can't find a 32 bit imnage, where can I find this dowload please?
32 bit is the default.
If it doesn't say it's 64-bit (or any other number) then it's 32-bit
SoniaAllison
Sat Feb 29, 2020 10:50 am
https://www.raspberrypi.org/downloads/raspbian/telldunkin
Many thanks for that complete information!
