Jangla
Make External HDD on Pi Visible in macOS Finder
Mon Feb 24, 2020 8:21 am
Beginner Rasberry-er here.
I've been trying to set up my external HDD so I can see it as a folder on macOS High Sierra.
So far I have installed netatalk and got the main pi user home directory visible in Finder. I've also mounted the HDD to a folder (hdd) on the Pi: https://puu.sh/FdKH5/49a432c219.png
But getting the HDD to show up in Finder is proving tricky.
Here's my netatalk config:
[Homes]
  basedir regex = /home
[HDD]
  path = /hdd
Here's the output from fdisk showing the HDD:
Disk /dev/sdb: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 621BB75A-632E-4A98-8745-7103BCFF1D67
Device     Start       End   Sectors   Size Type
/dev/sdb1   2048 976773134 976771087 465.8G Linux filesystem
And my fstab has this as the last line:
/dev/sdb   /hdd   ext4   nofail,uid=pi,gid=pi    0   0
Any idea where I'm going wrong? Is there a cleaner way to do this?
epoch1970
Re: Make External HDD on Pi Visible in macOS Finder
Mon Feb 24, 2020 12:40 pm
Your fstab entry doesn't match the way your drive is formatted: your data is in /dev/sdb1, not in /dev/sdb
I would try this (assuming your mount options are ok)
/dev/sdb1   /hdd   ext4   defaults,nofail,uid=pi,gid=pi    0   0
