Anurag66
Putty Not Connecting(SSH enabled)
Wed Feb 19, 2020 6:08 pm
I rewrite my os Raspbian because of some problems after writing i also put ssh file without any extn,
Now Working properly.
BUT
problem is i want to & i work on my laptop so
i have to connect it with putty
so to scan ip
i connected it to my laptop threw LAN Cable
so i got ip
But
while connecting i am not able to write anything on the shell.i don't understand why
i write os by doing overwrite format 4 times but still same result
while connecting i am not able to connect with my RPI3
Any Guidance
DOUBTS
monitor i have extra in that it is saying=> ssh is enabled
IS ssh port number can be changed automatically?
if yes then how i can find that?
Any mistake i am doing?
Note:-i do not have extra keyboard mouse
sparkyhall
Re: Putty Not Connecting(SSH enabled)
Wed Feb 19, 2020 6:26 pm
Have you checked that the ssh demon is running on the pi?
To do this open a terminal on the pi and enter the following at the command prompt:
ps aux | grep ssh
and you should see something like this:
root       544  0.0  0.1  10724  5376 ?        Ss   16:33   0:00 /usr/sbin/sshd -D
chris      951  0.0  0.0   4520   288 ?        Ss   16:33   0:00 /usr/bin/ssh-agent x-session-manager
chris      993  0.0  0.0   4520   288 ?        Ss   16:33   0:00 /usr/bin/ssh-agent -s
chris    12366  0.0  0.0   7348   540 pts/0    S+   18:21   0:00 grep --color=auto ssh
B.Goode
Wed Feb 19, 2020 6:27 pm
BUT
so to scan ip
so i got ip
But
Any Guidance
DOUBTS
"while connecting i am not able to write anything on the shell"
Does that mean you can't see your password being echoed as you login? That is normal.
Anurag66
Wed Feb 19, 2020 6:40 pm
BUT
so to scan ip
so i got ip
But
Any Guidance
DOUBTS
No No That i know it is not connecting meanes nothing showing we can say like that it will appear like that when we enter wrong ip
