Chris D
STRANGE -- make changes - reboot - changes are gone!???
Sat Feb 15, 2020 3:15 pm
Wow, another odd problem.
I did an image backup of this SD last week. It runs fine, my program that is auto loaded runs as it should, HOWEVER
I just copied a new file onto the desktop - all seemed normal
I edited LXDE-PI to prevent auto running - all seemed normal
I rebooted,
Those changes were gone as if I never did them?
After the second attempt and the same result, I am pretty sure something is really messed up.
Any suggestions as to what I did that could cause such crazy behaviour?
This is an RPI3 with Stretch.
I tried some google searches and couldn't find similar problems posted anywhere.
Chris D
ejolson
Re: STRANGE -- make changes - reboot - changes are gone!???
Sat Feb 15, 2020 3:17 pm
I rebooted,
Chris D
Did you toggle read-only mode in the rpi config program or another way?
Chris D
Sat Feb 15, 2020 3:20 pm
If I did, I have no idea how I could have done that?
What should I look at to check this?
croston
Sat Feb 15, 2020 3:21 pm
I've had something similar happen before. Turned out that it was a strange SD card fault. Clone your SD card and it will probably be OK on the new one.
ktb
Sat Feb 15, 2020 3:29 pm
Yeah, I've only ever seen this on faulty/failing SD cards. What kind of card do you have? Have you tested it on another computer to see if changes can be permanently written to it?
TimG
Sat Feb 15, 2020 3:30 pm
Another possibility is that the SD card is damaged and has turned read-only. I’ve had a couple of memory cards do this after a power brown-out. It’s not immediately obvious because no errors are generated, and as long as the new files remain in the cache it appears as if they have been written as normal.
To test, try dropping the cache and see if the files disappear:
echo 3 | sudo tee /proc/sys/vm/drop_caches
klricks
Sat Feb 15, 2020 3:41 pm
Likely your card has gone into read only mode. The controller on the SD card will do this in order to preserve existing data when impending failure is sensed. This is so you don't loose all your photos in a camera etc.
This feature is not reversible.
If so then you can use the SD copy tool and copy your SD onto a new SD card.
Chris D
Sat Feb 15, 2020 4:13 pm
Wow, Seems like the general consensus is a failed SD card.
It makes sense seeing that I just did the image copy of it which means I handled it.
For what it is worth, it is (was) a:
Lexar633x
16GB Micro[1] HC I
Luckily everything is backed up both as an image and my Python programs are copied in native format to the cloud.
Thanks everyone, I am in the process of setting up a new SD card.
Chris
TimG
Sat Feb 15, 2020 4:45 pm
Here's a little script that my Pis run daily. It tests the filesystem, looks for kernel errors, and sends a warning email if anything is wrong.
#!/bin/bash
# email parameters
email="sendEmail -f me@mail.com -t me@mail.com -s smtp.mail.com:587 -o tls=yes -xu username -xp password -q"
subj="Error from $HOSTNAME"
msg="error reported by $HOSTNAME at $(date)"
# look for critical kernel errors
[[ $(dmesg -xl crit) ]] && \
  eval "$email -u '$subj' -m 'Critical kernel $msg'"     # look for critical errors in dmesg
# to clear dmesg : $ sudo dmesg -C
# check filesystem hasn't become read-only
teststring=$(date)
testfile=$(mktemp -p $HOME)
echo $teststring > $testfile                             # make a test file
sync; sync                                               # wait for disc-sync to complete
echo 3 | sudo tee /proc/sys/vm/drop_caches &> /dev/null  # drop caches
echo $teststring | diff - $testfile &> /dev/null || \
  eval "$email -u '$subj' -m 'File-system $msg'"         # check the contents of the test file
rm $testfile &> /dev/null
Imperf3kt
Sun Feb 16, 2020 5:34 am
Lexar633x
16GB Micro[1] HC I
Lexar do not list a 633x card in 16GB, lowest storage capacity they offer is 32GB - your card is likely a fake.
That doesn't mean they've never sold them in the past, just that they don't sell them now.
https://www.lexar.com/portfolio_page/hi ... s-i-cards/
55:55:44:44:4C
52:4C:52:42:41
MisterEd
Sun Feb 16, 2020 6:40 am
Lexar633x
16GB Micro[1] HC I
The following is for sale on Amazon:
Lexar High-Performance 633x MicroSDHC UHS-I Cards: 16GB, 32GB
Lexar High-Performance 633x MicroSDXC UHS-I Cards: 64GB, 128GB, 256 GB, 512 GB
What is on Lexar's website is what they are making now. Things previously made will remain for sale by sellers until their supply runs out.
