I installed Raspbian Buster Desktop with recommended software on a RPi 3b+.
Is it possible to switch back to headless?
And if so, does it benefit the amount of RAM and CPU usage?
Any version of Raspbian can be run on a headless system.
I only use VNC to connect once in a while, but most of the time I use ssh and winscp. Domoticz and node-red are accessed via a webserver. So I also hardly use the recommended software.HawaiianPi wrote: ↑Thu Feb 13, 2020 7:06 pmNot loading the desktop will save some RAM, so if you don't run software that needs a GUI, booting to the CLI will save some memory.
However, it will still be using up storage space on your SD card, so you could free up some storage space by running Raspbian Lite (on another card, if you don't want to lose your current configuration, as jahboater suggested above).
