nakam
Playing music files on Raspberry Pi 3
Wed Jan 29, 2020 5:00 pm
I have got the omxplayer playing .mp3 files in the /home/pi folder but it will not play music files in the /home/pi/Music folder.
Can't see where I am going wrong.
Also how do you get it to play all the music files in a folder instead of just one.
Please make you answer simple with a step by step guide for 10 year old!!
lmarmisa
Re: Playing music files on Raspberry Pi 3
Wed Jan 29, 2020 6:22 pm
Open a terminal and type these commands:
cd ~/Music
ls -l *.mp3
omxplayer *.mp3
NOTE: the Tab key will help to complete your commands, parameters, directories and file names (for example type omx and Tab). This is a very useful help!.
W. H. Heydt
Thu Jan 30, 2020 12:18 am
Please supply the failing command and any error messages, plus a listing (ls -l) of the Music directory. Use code tags to make them properly readable.
jehutting
Sat Feb 01, 2020 8:46 am
Be aware that omxplayer can only play one file at the time.
So
omxplayer *.mp3
simply won't work.
Also omxplayer doesn't support .m3u files (again, due to the single file play).
In case you have a music file with spaces in the name, use e.g. double quotes.
omxplayer "filename with spaces.mp3"
Posting the content of your /home/pi/Music folder can give more insight.
