weberjn
Pi 3B did not boot after update - /boot full with 64m
Sun Jan 26, 2020 8:02 am
in case anybody else runs into this problem:
yesterday my pi 3B would not boot after rpi-eeprom rpi-eeprom-images update.
I plugged the SSD into my pi4, saw nothing in the logs, finally noticed that the /boot partition was full. The SSD was a clone from an old image from 2016, so /boot was only 64m.
With gparted and this tutorial: https://learn.adafruit.com/resizing-ras ... partitions
I resized the partitions, /boot to 256m, copied the files from https://github.com/raspberrypi/firmware onto /boot
and the system came up again. Nftables did not work until I did rpi-update.
Now everything works again
Re: Pi 3B did not boot after update - /boot full with 64m
Sun Jan 26, 2020 10:39 am
The /boot partition was resized to 256MB with the introduction of Buster (&RPi4B).
You'll only get the problem if you run the unsupported migration from Stretch to Buster.
Running
sudo apt install --reinstall raspberrypi-kernel raspberrypi-bootloader
to rebuild /boot and the matching /lib/modules is better than running rpi-update (which gets the latest experimental kernel and bootcode).
