Hello
I bought a Raspberry Zero W from a German dealer. But he has a different chip than usual.
I bought a Raspberry Zero W from a German dealer. But he has a different chip than usual. An ELPIDA is normally installed.
That's the PoP (Package-on-Package IIRC)** mounted memory chip - historically they can be from different manufacturers so i doubt it's a fake.
HawaiianPi wrote: ↑Fri Jan 24, 2020 9:17 pmYup, the "chip" you see is the RAM, not the SoC (which is underneath the RAM). If you look closely at the edge you can make out a small layer separation between the 2 components.
So what you have "discovered" is that not all Pi0 computers use the same RAM chip. Nothing revolutionary there. Components often change over time in any system. It's quite common, actually.
EDIT: added crappy phone picture.
