picandies
app position is stuck
Mon Jan 20, 2020 7:12 pm
Using standard desktop, rpi4.
When I open one particular app, it opens in a position, where it is almost slid off of the desktop. I can't grab the top of it to move it anywhere. It covers over the berry & the left side task bar. I can grab the bottom or right and resize it, but I need to move it, so I can see the top of the app. It must be moved since some of the app features are not even visible on the screen due to its position.
How can I force it to be grabbed/dragged/moved somewhere?
picandies
Re: app position is stuck
Mon Jan 20, 2020 7:25 pm
FYI---I finally found something that works
To drag a window who's titlebar is hidden, use ALT + left click & DRAG, on the window to be moved...you can then drag it around.
If the titlebar is visible you can just left click on that & drag (no alt needed)
