person1729
Start GUI through command line on remote display
Mon Dec 30, 2019 1:13 am
I booted into my pi, and I would like to start the GUI on a remote display, such as windows X server. However when I run
export DISPLAY=192.168.1.29:0
and then run
sudo startx
it gets stuck here
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Current Operating System: Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l
Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:[email protected],margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=DC:A6:32:16:44:30 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=5e3da3da-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
Build Date: 05 June 2019  12:49:54PM
xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Current version of pixman: 0.36.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Sun Dec 29 17:11:17 2019
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE) Please also check the log file at "/home/pi/.local/share/xorg/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
^Cxinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: unexpected signal 2
Couldn't get a file descriptor referring to the console
[email protected]:~ $ sudo startx
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Dec 29 17:11:27 2019
(II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
How do I configure xserver to start on a remote display?
pcmanbob
Re: Start GUI through command line on remote display
Mon Dec 30, 2019 10:15 am
Why not just use VNC ?
its already installed on buster you just need to enable it via raspi-config and down load the VNC viewer on your desktop pc ,
then you have full desktop access to your pi on the desktop PC.
PeterO
Mon Dec 30, 2019 10:33 am
and then run
sudo startx
it gets stuck here
(EE)
Fatal server error:
(EE)
(EE)
 for help.
(EE)
^Cxinit: giving up
You need to start the xserver on the remote machine from the remote machine... You could ssh into it and start the xserver.
The "DISPLAY" environment variable is used by xclients to determine which xserver they should use for their output.
Don't ever run xserver as root using sudo. It can screw up the permissions of various files that then have to be manually removed before the xserver will run properly. (I can't remember what the affected files are as I've never done it !)
Also, by default, xservers no longer listen on TCP ports for connections from remote clients.
You need to edit /etc/lightdm/lightdm.conf and inthe [Seat:*] section
change the line to
#xserver-allow-tcp=false
to
xserver-allow-tcp=true
Then you need to run "xhost +hostnameORipaddressOfClientMachine" to allow the client in the xserver access control.
Then you should be able to run "xterm -display serverAddress:0.0" and the terminal appears on the server machine.
HTH
PeterO
person1729
Tue Dec 31, 2019 1:36 am
Thanks, in the end I just used VNC, and running sudo startx did cause the GUI to glitch out a bit when starting
