hussein91
send float through ethernet
Tue Dec 24, 2019 4:13 pm
hello mumbers
please help
i'm trying to transfer 3 flaots form raspberry to pc through ethernet cable.
i used this code
on client
s.send(b'5.5')
s.send(b'30.21')
s.send(b'10.02')
and on server
x1=client.recv(1024)
x2=client.recv(1024)
x3=client.recv(1024)
print(x1)
print(x2)
print(x3)
i got this result
b'5.530.2110.02'
b' '
b' '
how can i solve it
ejolson
Re: send float through ethernet
Tue Dec 24, 2019 4:17 pm
hello mumbers
please help
i used this code
on client
s.send(b'5.5')
s.send(b'30.21')
s.send(b'10.02')
and on server
print(x1)
print(x2)
print(x3)
i got this result
b'5.530.2110.02'
b' '
b' '
how can i solve it
What programming language is this? Have you tried placing newlines after each number in the send commands?
hussein91
Tue Dec 24, 2019 4:29 pm
hello mumbers
please help
i used this code
on client
s.send(b'5.5')
s.send(b'30.21')
s.send(b'10.02')
and on server
print(x1)
print(x2)
print(x3)
i got this result
b'5.530.2110.02'
b' '
b' '
how can i solve it
Thanks for answering
I'm programming with python.
I don't understand what you mean by newlines
ejolson
Tue Dec 24, 2019 4:44 pm
I don't know much about Python, but what happens if you try
s.send(b'5.5\n')
s.send(b'30.21\n')
s.send(b'10.02\n')
instead?
scotty101
Tue Dec 24, 2019 6:23 pm
You are sending the float as a string so the recieving end needs to be told when one number ends and the next begins. You can do this by adding a delimiter, a character that indicates the gap between two values.
A newline or something like a comma or semi-colon are commonly used as delimiters.
If you are using python and use a comma as a delimiter, they you can split the string in to separate values using the split function.
x1,x2,x3 = client.recv(1024).split(',')
Another alternative is to send the float as a float rather than a string. In python a float is 24bytes in size. So recieving 24 bytes will read in one float.
hussein91
Wed Dec 25, 2019 7:50 am
thank you so much
it work
PeterO
Wed Dec 25, 2019 7:56 am
There's a Wikipedia page (*) for "newline" with more information than you'll ever need to know :lol: https://en.wikipedia.org/wiki/Newline
PeterO
(*) Who knew ? :lol:
