david_1234
unabel to save PI image for backup&restore
Tue Dec 24, 2019 4:07 pm
Hello ,
I have a working PI3 with stretch on 16GB SD card.
I remove the SD from the pi
connect it to my computer
open Win32 Disk Imager
read the SD (took about 10 min)
remove the SD
put a new 16GB SD card ,format it.
using Win32 Disk Imager press "Write" with the file I saved before
finish
put the SD in another PI3, start to boot then stuck
Kernel Panic - not syncing: VFS: Unable to mount root fs on unknown-block(137,1)
why ?
what am I doing wrong \ missing?
Thanks ,
Re: unabel to save PI image for backup&restore
Tue Dec 24, 2019 4:46 pm
Removed because OP has other issues which are in his current post here:
https://www.raspberrypi.org/forums/view ... 3&t=260072
Last edited by fruitoftheloom on Wed Dec 25, 2019 9:23 am, edited 1 time in total.
RPi 4B 4GB (SSD Boot)..
david_1234
Wed Dec 25, 2019 8:53 am
I did what you told me :
copy from a working pi into external DOK, then copy all of it in to my computer for backup.( I have all kind of files inside )
with which program I need to use now to make a new SD card with the backup?
Thanks ,
Re: unable to save PI image for backup&restore
Wed Dec 25, 2019 10:51 am
david_1234 wrote:
Wed Dec 25, 2019 10:14 am
SD Card Copier is to back up to USB Device, in the case of the 4B that is a SD Card in a SD Card Reader ie a cloned SD Card.
If you have a Raspberry Pi which can boot from USB Mass Storage Device, then you use SD Card Copier to clone the running SD Card to the MSD.
SD Card Copier does not make an image file, which you were expecting, it just clones the running bootable device.
david_1234
Wed Dec 25, 2019 10:53 am
so how can I make an image of working system and duplicate it ?
Cardship2
Wed Dec 25, 2019 10:51 pm
Are you writing to a file with .img as the extension? I’ve accidentally forgotten to type .img at the end of my file name.
RonR
Wed Dec 25, 2019 11:06 pm
Take a look at image-backup. The image files it creates can be restored (wriiten to an SD card or USB device) with Etcher.
david_1234
Thu Dec 26, 2019 1:31 pm
I will try this,
Thanks!
