david_1234
PI get stuck after boot - showing only error messages
Mon Dec 23, 2019 7:45 am
Hello ,
I running om my pi only zoneminder
yesterday i notice I can't enter the server
when I try to connect to the PI using ssh I got this error messges
Message from syslogd@raspberrypi at Dec 23 08:33:19 ...
 in decoder error:
 iled to create audio output
 SA lib confmisc.c:767:(parse_card)
 nnot find card '0'
 SA lib conf.c:4528:(_snd_config_evaluate)
 nction snd_func_card_driver returned error: No such file or directory
 SA lib confmisc.c:392:(snd_func_concat)
 ror evaluating strings
 nction snd_func_concat returned error: No such file or directory
 SA lib confmisc.c:1246:(snd_func_refer)
 ror evaluating name
 nction snd_func_refer returned error: No such file or directory
 SA lib conf.c:5007:(snd_config_expand)
 aluate error: No such file or directory
 SA lib pcm.c:2495:(snd_pcm_open_noupdate)
 known PCM default
 sa audio output error:
 nnot open ALSA device "default": No such file or directory
 in audio output error:
 dio output failed
 e audio device "default" could not be used:#012No such file or directory.
 dule not functional
 in decoder error:
 nnot find card '0'
 ror evaluating name
 known PCM default
 dio output failed
 dule not functional
 in decoder error:
 nnot find card '0'
 ror evaluating name
 known PCM default
 dio output failed
 dule not functional
 in decoder error:
 nnot find card '0'
 ror evaluating name
 known PCM default
 dio output failed
 dule not functional
 in decoder error:
 nnot find card '0'
 ror evaluating name
 known PCM default
 dio output failed
 dule not functional
 in decoder error:
 nnot find card '0'
 ror evaluating name
 known PCM default
 dio output failed
what could be the reason ? and how can I fix this ?
the only thing I do to this pi is
"sudo apt-get update && upgrade " once every 2 weeks
I don't install on it any other programs
Thanks ,
pcmanbob
Re: PI get stuck after boot - showing only error messages
Mon Dec 23, 2019 10:48 am
Looking at the errors I would say you have a corrupt or possibly failing SD card,
david_1234
Mon Dec 23, 2019 10:51 am
:o :cry: :cry:
is there soemething I can try doing?
try to reload \ change old setting somehow?
or no other option and I need to run a fresh installation?
pcmanbob
Mon Dec 23, 2019 11:02 am
:o :cry: :cry:
To attempt any fix you would need access to the pi , probably using a screen and keyboard, assuming it actually boots to a usable state.
if you can get access then you should first check if the SD card is full
df -h
if you have space then you could try
sudo apt-get update
sudo apt-get dist-upgrade
but you will probably end up starting over with a fresh install.
david_1234
Mon Dec 23, 2019 11:39 am
I will try to connect to pi usong keybaord and sceen and see
I will let you know in a day or 2
Thanks ,
david_1234
Tue Dec 24, 2019 8:13 am
I have connected to the pi using HDMI
it open it on the desktop , I reboot it
and now I can only enter using cmd
when I use
df -h
I see that
"/dev/root 15G 100% used"
when I enter run
du -h /var/log
I see it's 9.5G
when I enter /var/log ls -ls
I see that
kern.log,kern.log.1,syslog.1,messages,messages.1,debug,debug.1 are very large files
is there something I can do?
also what can cause this problem ?
can I remove this files?
Thanks ,
pcmanbob
Tue Dec 24, 2019 11:24 am
Well there's your problem a full SD card,
yes you can try deleting the various log files, then try rebooting and running the update commands I gave you to see if your pi will work normally.
if you are lucky it might.
david_1234
Tue Dec 24, 2019 12:35 pm
can I just delete all of those file using "rm" ?
no need to diable any service first?
pcmanbob
Tue Dec 24, 2019 1:40 pm
Anything with a number after it should be ok to just delete, I would leave the currently active logs intact.
david_1234
Tue Dec 24, 2019 7:21 pm
I did what you told me
this is what I have now after reboot
pi@raspberrypi:/var/log $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G  7.8G  6.2G  56% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           464M     0  464M   0% /dev/shm
tmpfs           464M   13M  451M   3% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           464M     0  464M   0% /sys/fs/cgroup
/dev/mmcblk0p1   43M   23M   20M  53% /boot
tmpfs            93M     0   93M   0% /run/user/1000
then I run the update like you told me
reboot the unit again
now (while connection with HDMI - it doesn't upload at desktop mode
just command line ....
when I try to enter the PI using VNC - it get connected but I get black screen "Cannot show desktop"
when I connect using ssh I see this
pi@raspberrypi:~ $ df -h
/dev/root        15G  7.9G  6.0G  58% /
tmpfs           464M   13M  452M   3% /run
seem very strange that I get 200MB of logs after 25 min , no?
in this rate until tomorrow morning it will get stuck again
what else can I check and fix?
Thanks ,
pcmanbob
Tue Dec 24, 2019 8:29 pm
Sounds like your SD card might be corrupt , you might be quicker just starting over or flashing your SD card with the backup you made of the working system.
If you really want to try fixing it you will probably need to look at these log files for a clue as to what's going on.
david_1234
Wed Dec 25, 2019 8:39 am
I did what you told me :
copy from the pi into external DOK, then copy all of it in to my computer for backup.
with which program I need to use now to make a new SD card with the backup?
Thanks ,
pcmanbob
Wed Dec 25, 2019 8:44 am
Thanks ,
No you miss understood, you needed to have made the backup of your SD card before it became corrupted, copying it now will just copy the corruption.
If you did not make such a backup then your only option is to flash a fresh image to the SD card and start over reinstalling all your software , once that is done and you have a working image that when you need to make a copy of the SD card using win32 disk imager as your backup.
david_1234
Wed Dec 25, 2019 8:52 am
I wrote this in the wrong post
I'm fixing it now .... sorry
I have check the log file and see there was a problem in the zonminder service after it update to version 1.30.4
when I turn off the zonminder service , everything start to work . so I will install zonminder again .
but now I don;t seem to understand why - the VNC is not working
I can connect to the pi using VNC - but I'm getting "cannot show desktop" , I didn't touch any setting
in raspi-config I have try to selected all kind of default resolution
in boot option I have selected Desktop autologin
what could it be?
sudo systemctl status vncserver-x11-serviced
    vncserver-x11-serviced.service - VNC Server in Service Mode daemon
   Loaded: loaded (/usr/lib/systemd/system/vncserver-x11-serviced.service; enabled; vendor preset: enabled)
   Active: active (running) since Wed 2019-12-25 11:11:55 IST; 2min 54s ago
 Main PID: 418 (vncserver-x11-s)
    Tasks: 2 (limit: 4915)
   CGroup: /system.slice/vncserver-x11-serviced.service
                 418 /usr/bin/vncserver-x11-serviced -fg
                 454 /usr/bin/vncserver-x11-core -service
Dec 25 11:11:55 raspberrypi systemd[1]: Started VNC Server in Service Mode daemon.
Dec 25 11:11:56 raspberrypi vncserver-x11[454]: ServerManager: Server started
Dec 25 11:11:56 raspberrypi vncserver-x11[454]: ConsoleDisplay: Cannot find a running X server on vt
Thanks ,
pcmanbob
Wed Dec 25, 2019 9:14 am
I don't know what the problem might be with VNC , having a full SD card can lead to all sorts of corrupt files ,especially as the corruption probably occurred during the update of the OS, my guess would be one of them is related to VNC, but as we don't know which files were corrupted / not updated its difficult if not impossible to tell you which file needs fixing.
david_1234
Wed Dec 25, 2019 9:18 am
so the best solution for me will be to take the zonemonder setting and reinstall the pi with a fresh]new SD card?
pcmanbob
Wed Dec 25, 2019 9:31 am
That would be my recommendation, at least then you know you are starting from a known good build, then when its all set up again make a copy of the SD card and keep it as a back up.
Them problem with fixing a corrupt OS is you never know if some else is going to break in the future and weather its related to the corruption or some thing else.
david_1234
Wed Dec 25, 2019 10:15 am
OK . I will do this
another somehow related question :
I have another working p3i and I want to make a backup and also install the same configuration on 4 more pi3.
I created a backup on 16GB Disk On Key using "SD Card Copier" ,
I see it have many files inside ,
what do I need to do now if I want to uplaod the backup to a fresh\new SD and "duplicate" my firt PI?
Thanks ,
pcmanbob
Wed Dec 25, 2019 4:03 pm
First of all your pi3 image will only work on the pi4 if it's running buster.
To make an image file for reuse you first need to make an image file from the SD card using
win32diekimager for example, then you need to shrink the Image file so that it will fit on another SD card because no 2 SD cards are exactly the same. , I use pi shrink on a Linux desktop PC to do this.
The other option is to use the SD card copier in the raspbian with desktop version to make a copy from the running pi's SD card to a fresh SD card connected to the pi.
david_1234
Thu Dec 26, 2019 3:22 pm
yes , it's works
I have dupicate 2 SD card , boot up without any problem
Thanks !
