Suige wrote: ↑Tue Dec 17, 2019 3:43 pm
Ha, it's you! I was reading through some of your older threads and came across your photos of the RPi plus the SSD. Awesome photos!. I have a question though. Through the many acrylic cases that you bought, did you have any issues with the mounting holes being different per acrylic case? If you did, which case would you recommend looking at?
There are 2 main types of these cases.
One type uses the Pi system board mounting holes for the case layers (one set of mounting holes for the board and case). With this type the spacing is defined by the board mounting holes, and they all should be the same. Unfortunately, that spacing does not match the mounting holes of a standard 2.5" laptop drive or SSD.
The other type, like mine, have separate mounting holes for the Pi system board and case layers.
- 71zUSgqRkDL._AC_SL460_.jpg (42.52 KiB) Viewed 1266 times
As far as I know, there's no standard specification for the spacing on this type of case, so it was just a happy coincidence that they lined up with an SSD when I tried it. There's no guarantee they are all the same, but the ones have purchased from two different sellers are the same.
Unfortunately, both are listed as "Currently unavailable" on Amazon right now.
JBtek Transparent Acrylic Raspberry Pi B+ / Raspberry Pi 2 Case with External Fan
CTYRZCH New Transparent Acrylic Raspberry Pi B+ Case Holder with External Fan
I see lots of other sellers on Amazon with identical looking cases at various prices (mostly higher), and they are *probably* the same, but I can't promise it since I haven't purchased from them (and it's not uncommon for sellers to have multiple similar looking, but not identical products). You can also find these types of cases on eBay, AliExpress and other sites.
Another way I have used this case is to replace the top cover with the SSD (example pic of my 4B2 with a
Fan SHIM for cooling).
- Pi4B32_FanSHIM_SSD.jpg (32.27 KiB) Viewed 1266 times
Sorry about the picture quality (quick phone snap for this post, without extra lighting).
