Page 1 of 2
Slow serial communication between Raspberry Pi 3+ and Arduino Mega
Posted: Mon Dec 16, 2019 9:41 am
by hussein91
Hello
I used the serial communication between Raspberry Pi 3+ and Arduino Mega, but the connection was very slow. is there any way to make it faster.
Those are codes of arduino and python :
arduino code:
float a=3.55;
float x1,x2,x3;
char s;
boolean rc=0,sx1=0,sx2=0,sx3=0;
void setup(){
  Serial.begin(115200);
void loop(){
  if(rc==0 & Serial.available()){
    s=Serial.read();
    rc=1;
  if(rc==1){
    rc=0;
    if(s=='z'){//reset the system states on the initial conditions (x1=x1_0;x2=x2_0;x3=x3_0)
      x1=2,x2=5,x3=-1;
      s=0;sx1=0;sx2=0;sx3=0;
    if(s=='a'){
      Serial.println(x1*3);
      sx1=1;
      s=0;
    if(s=='b'){
      Serial.println(x2*5);
      sx2=1;
      s=0;
    if(s=='c'){
      Serial.println(x3*10);
      sx3=1;
      s=0;
    if(sx1*sx2*sx3==1){
      x1=sin(x1);
      x2=sin(x1+x2);
      x3=sin(x3-x1*x2);
      sx1=0;
      sx2=0;
      sx3=0;
and this is the code of python using thonny 3.2.0 on raspberry
import serial
s1=serial.Serial("/dev/ttyACM0",115200)
X1,X2,X3,t=[],[],[],[];
dt=0.01
i=0;
rx1=0
rx2=0
rx3=0
s1.write(b'z')
while i<20/dt:
    s1.write(b'a')
    while rx1==0:
        if s1.inWaiting():
            x1=s1.readline()
            rx1=1
    s1.write(b'b')
    while rx1==1 and rx2==0:
        if s1.inWaiting():
            x2=s1.readline()
            rx2=1
    s1.write(b'c')
    while rx2==1 and rx3==0:
        if s1.inWaiting():
            x3=s1.readline()
            rx3=1
    i=i+1
    rx1=0
    rx2=0
    rx3=0
    X1.append(float(x1))
    X2.append(float(x2))
    X3.append(float(x3))
    t.append(dt*i)
Re: Slow serial communication between Raspberry Pi 3+ and Arduino Mega
Posted: Mon Dec 16, 2019 9:44 am
by scotty101
How did you characterise the speed of the connection as 'slow'? What speed are you looking for?
You are currently sending data at 115200 bps. Have you tried increasing the baud rate?
Posted: Mon Dec 16, 2019 10:20 am
by rin67630
Hello
[program examples not repeated here]
May I suggest, that you explain from the beginning what you're trying to do and which results you expect to get?
it commonly does not make much sense to let the much weaker Arduino make floating-point trigonometric computations, that could have been done much efficiently on the Raspberry side.
Maybe the speed limitation comes from here?
Posted: Mon Dec 16, 2019 11:03 am
by scotty101
Good suggestion here.
If you want to time how long the mathematical functions take, you could turn on one of the Arduino's pins before the calculations and then off once they are complete. You can then measure how long they take with an oscilloscope (or use the raspberry pi to measure the pulse length)
Posted: Mon Dec 16, 2019 12:20 pm
by hussein91
thanks for you all
i mean when i excute the python code, It takes a long time, although the program is simple
Posted: Mon Dec 16, 2019 12:44 pm
by Paul Hutch
I'd bet most of time is spent waiting for the 8-bit processor in the arduino to complete the heavy math involving floating point manipulation. The heavy math is more suited to a 32 bit or higher processor like the Raspberry Pi.
Posted: Mon Dec 16, 2019 2:12 pm
by hippy
My response on your other thread, before that gets deleted as a duplicate -
hippy wrote:
Mon Dec 16, 2019 1:52 pm
You will probably have to explain what "this problem" is, in what way the Arduino to Raspberry Pi solution is slower than Arduino to Arduino. How are you determining or observing there is this 'slowness' ?
I would guess it comes down to the code running on the Pi, what that's doing and how it's doing it. You may want to post your Pi code so people can look to see what the cause of any slowness may be.
Posted: Mon Dec 16, 2019 2:17 pm
by hussein91
I already posted the code
Posted: Mon Dec 16, 2019 2:27 pm
by hippy
Not in the duplicate thread, and I wasn't going to let the time spent answering there go to waste.
Posted: Mon Dec 16, 2019 3:20 pm
by rin67630
Unless you explain what you expect and why you have conceived that apparently ridiculous handshake between the Arduino and the Pi to forward information in the most inefficient way one could imagine, you won't get any more advice from me. You surely have got reasons, but we don't have a working glass ball at disposal.
Posted: Mon Dec 16, 2019 3:42 pm
by hussein91
I would like Raspberry to receive 3 variables from Arduino, and then it will perform operations on these variables. I used the following method
1. Raspberry sends the variable reference to the Arduino
2. Arduino reads this reference and then sends the appropriate variable to Raspberry
3. Raspberry reads this variable and saves it
These steps are repeated 3 times in order to obtain all the 3 variables
Then, Raspberry performs operations on these variables. After completing these operations, this procedure is repeated a number of times
Posted: Mon Dec 16, 2019 4:02 pm
by rin67630
You will be far better off to forward all 3 variables in the same message. You probably lose most of the time in the repeated handshake upon reading the serial buffers in both directions, not in the communication itself...
What is the very reason to let the Arduino compute a sinus, just a preliminary step to get more interesting stuff from it, once the communication is running?
Posted: Mon Dec 16, 2019 4:14 pm
by hussein91
thanks for help
how can i writhe those variables on the same message
i'm not intersted on sinus i only made simple code to verify the good comunication between raspberry and rduino because my aim is to make a synchronisation between those boards
Posted: Mon Dec 16, 2019 4:22 pm
by rin67630
how can i write those variables on the same message?
Replace writeln(...) with write(...) add a write(",") between all but the last variable, which is the only one to get a writeln.*
On the python side, read the message into a tuple.
*by the way, doing it that way, you can see the communication in the serial monitor as a table and in the serial plotter graphically, which is a great way to debug.
Posted: Mon Dec 16, 2019 4:28 pm
by MarkDH102
Did you actually mean (note the double &&)
if(rc==0 && Serial.available())
Posted: Mon Dec 16, 2019 4:30 pm
by hussein91
Yes thanks
Posted: Mon Dec 16, 2019 4:35 pm
by hippy
You can probably simplify your Arduino code to something like -
void loop(){
  do { } while( not Serial.available() );
  s  = Serial.read();
  x1 = ...
  x2 = ...
  x3 = ...
  Serial.println(x1, ',',  x2, ',', x3);
And the equivalent Python code which interacts with that could be something like -
def Main():
  ser = serial.Serial('/dev/ttyACM0', 115200)
  while True:
    ser.write(b'x')
    x1, x2, x3 = ser.readline().strip().split(',')
    print(x1 + ', ' + x2 + ', ' + x3)
Posted: Mon Dec 16, 2019 4:40 pm
by hussein91
void loop(){
  s  = Serial.read();
  x1 = ...
  x2 = ...
  x3 = ...
  Serial.println(x1, x2, x3);
def Main():
  while True:
    ser.write(b'x')
Thanks a lot
Posted: Mon Dec 16, 2019 4:43 pm
by PeterO
If this really does turn out to be a problem caused by slow serial transfers there is also the possibility of using an Ethernet shield on the Arduino and transferring the data via a wired network.
PeterO
Posted: Mon Dec 16, 2019 4:48 pm
by MarkDH102
I can't believe the Mega is slow.
I use one to read masses of serial data (at 115200 baud) from 2 different devices, manipulate it and then store it away. It also has time to update an I2C 480*320 colour LCD.
I did increase the size of the serial buffers somewhat but that shouldn't be necessary here...
Posted: Mon Dec 16, 2019 5:13 pm
by rin67630
Thanks a lot
Please note: hippy has meanwhile corrected the line into
  Serial.println(x1, ",",x2, ",", x3);
Just to avoid a trap...
Posted: Mon Dec 16, 2019 5:21 pm
by hippy
Yes; apologies for that. I'm not familiar with C or Arduino so the code might need tweaking. I think the "not" should be some single character symbol. The println might well have some other format.
Posted: Tue Dec 17, 2019 8:05 am
by hussein91
Thanks a lot
hello
I tried the code you adviced me but i got this error message on arduino
sketch_dec17a.ino: In function 'void loop()':
sketch_dec17a.ino:18:41: error: no matching function for call to 'HardwareSerial::println(float&, const char [2], float&, const char [2], float&)'
In file included from /usr/share/arduino/hardware/arduino/cores/arduino/Stream.h:26:0,
from /usr/share/arduino/hardware/arduino/cores/arduino/HardwareSerial.h:28,
from /usr/share/arduino/hardware/arduino/cores/arduino/Arduino.h:193,
from sketch_dec17a.ino:1:
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:67:12: note: candidate: size_t Print::println(const __FlashStringHelper*)
size_t println(const __FlashStringHelper *);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:67:12: note: candidate expects 1 argument, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:68:12: note: candidate: size_t Print::println(const String&)
size_t println(const String &s);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:68:12: note: candidate expects 1 argument, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:69:12: note: candidate: size_t Print::println(const char*)
size_t println(const char[]);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:69:12: note: candidate expects 1 argument, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:70:12: note: candidate: size_t Print::println(char)
size_t println(char);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:70:12: note: candidate expects 1 argument, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:71:12: note: candidate: size_t Print::println(unsigned char, int)
size_t println(unsigned char, int = DEC);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:71:12: note: candidate expects 2 arguments, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:72:12: note: candidate: size_t Print::println(int, int)
size_t println(int, int = DEC);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:72:12: note: candidate expects 2 arguments, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:73:12: note: candidate: size_t Print::println(unsigned int, int)
size_t println(unsigned int, int = DEC);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:73:12: note: candidate expects 2 arguments, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:74:12: note: candidate: size_t Print::println(long int, int)
size_t println(long, int = DEC);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:74:12: note: candidate expects 2 arguments, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:75:12: note: candidate: size_t Print::println(long unsigned int, int)
size_t println(unsigned long, int = DEC);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:75:12: note: candidate expects 2 arguments, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:76:12: note: candidate: size_t Print::println(double, int)
size_t println(double, int = 2);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:76:12: note: candidate expects 2 arguments, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:77:12: note: candidate: size_t Print::println(const Printable&)
size_t println(const Printable&);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:77:12: note: candidate expects 1 argument, 5 provided
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:78:12: note: candidate: size_t Print::println()
size_t println(void);
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:78:12: note: candidate expects 0 arguments, 5 provided
Posted: Tue Dec 17, 2019 8:18 am
by PeterO
https://www.arduino.cc/reference/en/lan ... l/println/
Note that this is NOT the standard C printf so it doesn't support multiple parameters (or a format string).
PeterO
Serial.println()
Description
Prints data to the serial port as human-readable ASCII text followed by a carriage return character (ASCII 13, or '\r') and a newline character (ASCII 10, or '\n'). This command takes the same forms as Serial.print().
Syntax
Serial.println(val)
Serial.println(val, format)
Parameters
Serial: serial port object. See the list of available serial ports for each board on the Serial main page.
val: the value to print. Allowed data types: any data type.
format: specifies the number base (for integral data types) or number of decimal places (for floating point types).
Posted: Tue Dec 17, 2019 8:29 am
by rin67630
Ups ! Shame on me ! I did not pay attention! Sorry.
At least the error message was informative enough.
