If you have a metal case with a large heat sink covering the computer then you can expect the WiFi signal to be reduced by 50% this does not mean your internet speed will decrease the WiFi will have a maximum download speed, use Ethernet if you needed to know the maximum internet speed that you can use on the RPI computer, you can check your internet speed using Google internet speed test:
https://www.google.com/search?q=speedte ... e&ie=UTF-8
Expect more latency with Bluetooth peripherals if you are using a metal case for example using Bluetooth headphones the audio will not be synchronized with the video, if you use a plastic case the Bluetooth latency should be minimal with better range.
