Page 1 of 2
STICKY: THE DEAD PI STORE.
Posted: Mon Dec 17, 2012 12:08 pm
by liz
Today, with the help of our good friends at Indiecity and Velocix, we've launched a new feature for your Raspberry Pi. Read more about it at this blog post, download it to your Pi, and come back and discuss it here!
Re: Introducing the Pi Store!
Posted: Mon Dec 17, 2012 12:30 pm
by Rushy
This is fantastic to share projects with others, Just what the Pi needed. ;)
Must run an update first though to install the PiStore.
sudo apt-get update && sudo apt-get install pistore
Posted: Mon Dec 17, 2012 12:58 pm
by ghans
This is cool.
Congratulations to everyone involved.
ghans
Posted: Mon Dec 17, 2012 1:07 pm
by poglad
Pleased to meet you, Pi Store!
Posted: Mon Dec 17, 2012 3:09 pm
by redhawk
Pi Store sounds like a good idea but are the apps tested and scrutinised before they're released to the general public i.e. bugs, and naughty lines of code??
Richard S.
Posted: Mon Dec 17, 2012 3:13 pm
by jamesh
They are moderated.
Posted: Mon Dec 17, 2012 3:19 pm
by rdb
I can confirm that any submissions to the store are manually checked before they are approved to be listed for download. The main things that we're checking for are that it runs without error on the Pi and doesn't contain any illegal content, themes or copyright/license infringements.
Posted: Mon Dec 17, 2012 3:39 pm
by hippy
An excellent development. There does seem to be some conflicting information relating to licensing in places, for example ... http://store.raspberrypi.com/projects/libreoffice
"Developer's Description : You can download, install and distribute LibreOffice freely, with no fear of copyright infringement"
"Licence : Game/App EULA : You may not modify or redistribute this content"
Same Game/App EULA for "open source" http://store.raspberrypi.com/projects/despotify
Posted: Mon Dec 17, 2012 4:05 pm
by rurwin
Very nice.
I do notice that there are 25 applications listed, and 259 developers registered. That's an average of 0.097 applications each. Maybe there are 234 apps in an "advanced stage of development" ;-) Or possibly it would be better not to list developers until they publish.
Posted: Mon Dec 17, 2012 4:26 pm
by rdb
ruwin - I don't think it distinguishes between Indiecity Developers and those who are Pi Store focussed, hence the apparently large number of devs signed up.
Posted: Mon Dec 17, 2012 6:07 pm
by trouch
I'm trying to upload WebIOPi...
But when registered as a developer, we are redirected to indiecity without ability to specify a "Raspberry Pi" project...
Also, is there any guideline to upload apps for the Pi ?
Posted: Mon Dec 17, 2012 7:16 pm
by ChrisSwan
Are you on PC when doing this? In order to upload currently you need to be in the Pi Store on the Pi itself, and then use the Upload section.
Very soon you will be able to upload from PC as well, and a detailed instructions page will shortly be provided.
Posted: Mon Dec 17, 2012 8:22 pm
by trouch
ChrisSwan wrote:Are you on PC when doing this? In order to upload currently you need to be in the Pi Store on the Pi itself, and then use the Upload section.
On another computer (not a PC ;)), yes, I develop on a headless Pi using SSH and network sharing.
I'll try to add a remote desktop on my Pi to do it because I don't have any screen to plug in.
Many thanks for your feedback
Posted: Mon Dec 17, 2012 10:43 pm
by SN
Will there be command line access to the Pi Store?
Posted: Tue Dec 18, 2012 1:06 am
by pepedog
Will it ever run on archlinuxarm?
Posted: Tue Dec 18, 2012 3:44 am
by dan3008
If you want someone to help test, I have a rev1.1 board and an SD card that i'm willing to put to work testing apps from the pi store :)
Its got one broken USB port, but other than that its working, and i'm more than happy to set aside an SD card, and isolate the pi from my network, so i dont have to worry about virus's.
Offers there if you want it :)
Posted: Thu Dec 20, 2012 11:28 pm
by mypifi
Hi I've done the sudo apt thing above to download pi store now how do I run / open it as nothing happens. I might be having a blonde moment but at moment it does nothing.
Posted: Thu Dec 20, 2012 11:49 pm
by Pankoi
Hi smstext,
If you type 'pistore' into a terminal, what happens? Does it output any text or errors?
Thanks very much,
~Richard Williams
Posted: Fri Dec 21, 2012 12:02 am
by jackokring
You can register as a developer from a PC. I did. I'm converting some JavaME phone code to JavaFX, and then adding to it. I hope to have it done round about when the oracle VM is in full release. Just wondering what the situation is with LinuxPC/Pi dual release is. Do you just upload one thing and select 2 platforms or is a double upload needed? I could have two startup scripts in the one release. It could even work on windows if someone else wrote the startup script.
It would be nice if the start up scripts were automated to be added to the download after finding the Application class. Also nice to have would be an addition to the download of a helper process which could be configured to send key presses to the Application Scene. This would in effect make a keyboard the standard controller, and make all applications automatically joypad compatible.
Posted: Fri Dec 21, 2012 12:16 am
by Pankoi
Hi jackokring,
jackokring wrote:Just wondering what the situation is with LinuxPC/Pi dual release is. Do you just upload one thing and select 2 platforms or is a double upload needed? I could have two startup scripts in the one release. It could even work on windows if someone else wrote the startup script.
You need to do a separate upload for each platform, but these can all be managed under the one project. If you just select a new platform in the project's 'Platforms/Installers' tab, you're presented with a set of Upload/Build buttons for each platform. :)
Hope that helps,
~Richard Williams
Posted: Fri Dec 21, 2012 12:46 am
by mypifi
I'm getting error whilst loading shared libraries: 23_server_method: cannot open shared object file: no such file or directory
Posted: Fri Dec 21, 2012 9:37 am
by Pankoi
Thanks for posting the error.
Hrm - I'll admit it's not one I've seen before. Sounds like a missing dependency though. Would you mind removing and reinstalling the Pi Store, if you haven't already?
Also, are you on a fairly new Raspbian image (I'm not aware of any problems with older images, but I'd recommend being as up-to-date as possible)? Have you removed any packages which came on the image?
Sorry for all the questions - I'm just trying to work out what it's most likely to be. :)
Thanks again for your help,
~Richard Williams
Posted: Fri Dec 21, 2012 11:21 am
by mypifi
I've removed and reinstalled pistore and no difference. Looks like I'm just going to have to wipe the sd card and start afresh and put all the stuff back on it. :(
Posted: Sat Dec 22, 2012 12:43 am
by kInOzAwA
that's great. love to see more apps on the store soon. :)
Posted: Sat Dec 22, 2012 9:36 pm
by mypifi
update, i formatted the card and reinstalled raspbian, all works fine now.
