picandies
Command to check GPIO'S?
Thu Dec 05, 2019 7:50 pm
What command(s) can be used right after booting up is completed to check the states /modes of all the GPIO's?
I believe it is a linux command, rather than python command (though either is fine). This is an RPI3B
Also, I'm investigating GPIO 14...I believe GPIO 1-8 are set as inputs with hi-pullups & the rest areset as inputs with low-pullups.
However, GPIO 14 seems to be set as an output (even if I load with 5K), so this does NOT match what I've read.
Is there an official (up to date) list?
Of course with the proper commands, I can always verify myself.
joan
Re: Command to check GPIO'S?
Thu Dec 05, 2019 8:34 pm
GPIO14 has always been serial TXD which is high by default. It sounds like you have enabled the console or serial link. You can use raspi-config to disable this behaviour.
picandies
Thu Dec 05, 2019 10:11 pm
Thanks for the wiring pi tip....however:
I'm not using wiring pi (but perhaps could).
I need to see whether each pin is in/out, or something else and hi/lo (if output)
I want to look at ALL of the pins, not one...right after boot is finished & I can start typing
Isn't there a command to type in to list this info for them? Maybe my imagination?
DirkS
Thu Dec 05, 2019 10:45 pm
IIRC it's installed by default on the RPF images.
There's also the RPF GPIO utility:
raspi-gpio get
RonR
Thu Dec 05, 2019 11:06 pm
Not on Raspbian Buster Lite.
DirkS
Thu Dec 05, 2019 11:09 pm
sudo apt update
sudo apt raspi-gpio
RonR
Thu Dec 05, 2019 11:15 pm
sudo apt update
sudo apt raspi-gpio
I know how to install them, but they're not installed by default as you speculated.
picandies
Fri Dec 06, 2019 6:16 am
Hey guys , thanks for the tip.
By the way, I found a command you may not have heard of (there seem to be many undocumented or hard to find):
gpio readall
The will also show a very informative listing of all the I/Os!
rpdom
Fri Dec 06, 2019 6:19 am
gpio readall
That is the gpio command from WiringPi.
Milliways
Fri Dec 06, 2019 6:29 am
gpio readall
Now that wiringpi is deprecated (and requires a download from the author's site to work on the Pi4) the future of this command is unknown.
I wrote a replacement (which uses pigpiod) - which has the advantage of displaying the ACTUAL programmed GPIO function if changed.
https://www.raspberrypi.org/forums/view ... 6&t=254071
rpdom
Fri Dec 06, 2019 7:01 am
The "raspi-gpio get" command will list the status of all GPIOs (not just those available on the connector). You can limit it with "raspi-gpio get 2-27" to just list the ones available for general use. This won't show them in a pretty order with pin numbers, but it is the official tool for work with GPIOs.
Milliways
Sun Dec 08, 2019 1:53 am
I just looked at this (which I was unaware of) and noted that it outputs lines like
GPIO 4: level=1 fsel=0 func=INPUT pull=UP
My reading of the peripherals documentation (which is rather confusing) states that it is not possible to read state of pull-ups and the user must remember these. I have seen similar comments in WiringPi documentation.
I am intrigued how this is determined.
I will have to run a few tests to see what it reports.
A quick test with echo "pud 4 d" >/dev/pigpio shows that it does indeed work as this now shows
GPIO 4: level=0 fsel=0 func=INPUT pull=DOWN
rpdom
Sun Dec 08, 2019 4:26 am
It is possible on the Pi4. The GPIO configuration is different. The forthcoming documentation will show the changes.
