MarkDH102
MQTT controlling multiple devices [SOLVED]
Thu Nov 28, 2019 2:56 pm
Didn't see the ClientID initialiser in the ESP8266 code!!!
Running up to date Stretch on a Pi2B.
Running MQTT mosquito broker.
Running a python app that connects ok to the broker.
Running a single ESP8266 that also connects ok to the broker on the Pi. (All on a local network).
Controlling an output on the ESP8266 from the Pi python app is all ok.
NOW:
I wanted to add a second ESP8266. So, I gave it a different username and password and set up 2 passwords in the mosquito pwfile.
It also connects OK to the broker.
But now, I can't control either of them from my Python app on the Pi.
I am new to this. What is the correct way to connect 2 or more devices/clients to be controlled via the python app on the Pi.
Search the World Wise Web has left me a little bit bamboozled.
This is a cut down version of my code showing my connection to the broker and the 2 messages I send to the 2 different ESP's.
import paho.mqtt.client as mqtt
import threading
def handleMQTT() :
    # Once we have told the client to connect, let the client object run itself
    client.loop_forever()
def handleMQTT1() :
    client1.loop_forever()
mqtt_username = "esp8266"
mqtt_username1 = "esp8266_1"
# Same for both
mqtt_password = "pwd"
mqtt_topic_from_esp = "topicfrom"
mqtt_topic_to_esp = "topicto"
# This is the ip address of THIS Raspberry Pi (which is acting as the BROKER)
mqtt_broker_ip = "192.168.0.35"
client = mqtt.Client()
# Set the username and password for the MQTT client
client.username_pw_set(mqtt_username, mqtt_password)
client1 = mqtt.Client()
client1.username_pw_set(mqtt_username1, mqtt_password)
client.on_connect = on_connect
client.on_message = on_message
client1.on_connect = on_connect1
client1.on_message = on_message1
# Once everything has been set up, we can (finally) connect to the broker
# 1883 is the listener port that the MQTT broker is using
client.connect(mqtt_broker_ip, 1883)
client1.connect(mqtt_broker_ip, 1883)
t2 = threading.Thread(target=handleMQTT)
t2.daemon = True
t2.start()
t3 = threading.Thread(target=handleMQTT1)
t3.daemon = True
t3.start()
# And I eventually call these when things need to happen...
client.publish(mqtt_topic_to_esp, "0 DEV/OFF")
client1.publish(mqtt_topic_to_esp, "0 DEV1/OFF")
Any help much appreciated. Thanks.
