Lewis-H wrote: ↑Thu Nov 07, 2019 2:54 pm
If you are using your Raspberry Pi with a smaller screen you may want to change the font used on the command line to make it easier to read. I usually do this when I am using various portable LCD screens (eg the HDMIPi).
It only changes the font within the console if you are using a screen connected directly to the Pi. It won’t affect Putty/SSH sessions.
Changing the font size on the console is easy to do and there are two methods you can choose.
Method 1
This method uses a system utility called “dpkg-reconfigure”. Run it using the command shown below :
sudo dpkg-reconfigure console-setup
This will launch a “Package Configuration” screen :
Changing Raspbian Font Size
Using the up/down arrow keys select “UTF-8”. Using the right arrow key select “OK” and press ENTER.
Using the up/down arrow keys select “Guess optimal character set”. Using the right arrow key select “OK” and press ENTER.
Using the up/down arrow keys select “Terminus”. Using the right arrow key select “OK” and press ENTER.
Using the up/down arrow keys select “16×32”. Using the right arrow key select “OK” and press ENTER. There will be short delay before you are returned to the command prompt with the new font size. 16×32 is a font size that will be twice the size of the default.
See below for a video showing this method.
Method 2
This method involves editing a system file called “console-setup”. You just need to load it into your preferred text editor and tweak a few lines :
sudo nano /etc/default/console-setup
You will see the default settings :
Using the arrow keys position the cursor and change the FONTFACE and FONTSIZE lines to :
FONTFACE="Terminus"
FONTSIZE="16x32"
Your file should look something like this :
Press CTRL-X, then Y then ENTER to save the changes.
To apply these new settings to your command prompt without rebooting you can run the following command :
sudo /etc/init.d/console-setup restart
Hope this helps you!
Regards,
Lewis
