aszy
Buster : downgraded 'rm' command , how to upgrade
Wed Nov 06, 2019 4:36 am
Good day all. Started running a Buster install and noticed that the 'rm' command has been , um.... reduced in function. I'd use another word , but you get the idea. Gone is the ability to 'rm -rF' and 'rm -R' to recursively remove the directory as well as contents.
Now , I get it that the intended audience may have a reduced function and could wield the 'rm' command and cause havoc. I get it.
But , I'd like to get a real version of 'rm' installed. I don't see it in the repository , so where and how can I go about it?
Thanks in advance,
Al
Pi 2, Pi 3, Pi 3B+ and soon a Pi 4 - for Amateur Radio.
ejolson
Re: Buster : downgraded 'rm' command , how to upgrade
Wed Nov 06, 2019 4:41 am
Thanks in advance,
Al
I thought rm is the same as always. Has something changed?
RossDv8
Wed Nov 06, 2019 5:11 am
My Buster says rm -r and rm -f are still available, so I expect rm -rf should still work. But I have nothing I want to test it on just at the moment.
Possibly try with a lower case f (justin case..)
[email protected]:~ $ rm --help
Usage: rm [OPTION]... [FILE]...
Remove (unlink) the FILE(s).
-f, --force ignore nonexistent files and arguments, never prompt
-i prompt before every removal
-I prompt once before removing more than three files, or
when removing recursively; less intrusive than -i,
while still giving protection against most mistakes
--interactive[=WHEN] prompt according to WHEN: never, once (-I), or
always (-i); without WHEN, prompt always
--one-file-system when removing a hierarchy recursively, skip any
directory that is on a file system different from
that of the corresponding command line argument
--no-preserve-root do not treat '/' specially
--preserve-root[=all] do not remove '/' (default);
with 'all', reject any command line argument
on a separate device from its parent
-r, -R, --recursive remove directories and their contents recursively
-d, --dir remove empty directories
-v, --verbose explain what is being done
--help display this help and exit
--version output version information and exit
By default, rm does not remove directories. Use the --recursive (-r or -R)
option to remove each listed directory, too, along with all of its contents.
To remove a file whose name starts with a '-', for example '-foo',
use one of these commands:
rm -- -foo
rm ./-foo
Note that if you use rm to remove a file, it might be possible to recover
some of its contents, given sufficient expertise and/or time. For greater
assurance that the contents are truly unrecoverable, consider using shred.
GNU coreutils online help: <https://www.gnu.org/software/coreutils/>
Full documentation at: <https://www.gnu.org/software/coreutils/rm>
or available locally via: info '(coreutils) rm invocation'
Remember, nobody is listening to you
until you fart ...
Wed Nov 06, 2019 5:38 am
aszy,
As far as I know "rm -rF..." has never existed.
However "rm -rf ..." does and works as it always did.
Oddly I now notice there is bot a -r and -R option. Which do the same recursive thing.
jahboater
Wed Nov 06, 2019 8:32 am
That's for historical reasons. There were some versions of rm on UNIX that needed -R.
