1) The situation has been resolved and...
jhuebner0504 wrote: ↑Wed Nov 13, 2019 2:33 am
using GParted, try to find the SD card (plug it into your PC) an adapter mSD to USB2.0 and some kind will be needed.
Then delete all the partions on the mSD. "Apply". Create new: "Fat32" partition. Apply. dismount. safely eject if you can see it in your file manager.
2) If using Etcher, none of the above is required. Etcher will write a full image to the card, overwriting previously written data including partition tables.
Then Etcher will be able to apply the Raspian image should be able to flash the mSD. I've had to do it with other Pi solutions.
