LONGJA
Persistent SD Card Corruption
Tue Nov 05, 2019 11:49 am
Hi there,
The problem that we are facing is SD card corruption, specifically with the Raspbian operating system. We are using the Raspberry Pis (3B+) in environments where they may lose power at any moment. We need to use them headless and have no formal process to switch them off, we just pull the power.
We knew this was a problem and likely to be causing the corruption so introduced a read-only root file system within Raspbian. This is something I found online and we tested it as thoroughly as we could:
[removed bad link]
However, after several months of no corruption related issues, recently we have had several units fail. Despite protecting the root file system, this hasn’t been enough, so I believe we need to look at protecting the rest of the partitions (boot etc).
It also appears to be a time related issue. If a Pi is restarted in a short period of time, it will normally recover and restart. If one has been running for a long period of time and it then power cycled, there's a very slim chance (almost none) that it will reboot. For me, this points at some sort of internal logging building up over time. An issue which I thought would have been removed with a read-only root file system.
I am not a programmer by trade, I’m a product designer and have done what I can but have unfortunately reached the end of my knowledge. We’re looking for an expert in Linux and Raspbian to help us build a robust, incorruptible file system. The world seems to be full of examples of people running Raspberry Pis for years but we have struggled to get ours to run consistently.
I appreciate this is slightly unorthodox but I would really appreciate any help you can provide.
Many thanks,
James
jbudd
Re: Persistent SD Card Corruption
Tue Nov 05, 2019 3:26 pm
The URL you posted tries to download a file. No thanks!
LONGJA
Tue Nov 05, 2019 3:41 pm
Sorry! Been using it in a batch script. I meant this website...
http://wiki.psuter.ch/doku.php?id=solve ... _partition
Tue Nov 05, 2019 4:08 pm
You should ensure all logging goes to a tmp filesystem - ie RAM, which means very few SD card accesses. Its possible the devices are actually filling up their SD cards, which does reduce their lifetime (less free space means less chance for wear levelling).
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
rpiMike
Tue Nov 05, 2019 4:17 pm
Why not add a UPS hat that will do a clean shutdown on power loss?
https://uk.pi-supply.com/products/pijuice-standard
LONGJA
Tue Nov 05, 2019 4:58 pm
Unfortunately, I can't use a hat as we've built our own and therefore no longer have access to the GPIO header.
I've really looking for a RAM solution - @jamesh - the read only solution we're using at the moment claims to deliver a 'read only root partition'. I assume this therefore does not cover system logging. Is there a list of directories that we need to point to a tmp filesystem?
Ideally I would like to run the whole Pi in RAM and never write to the SD card.
Tue Nov 05, 2019 6:22 pm
There's an option in raspi-config in Raspbian now to use a read-only root with all the log files and things moved to RAM disks.
Unreadable squiggle
Tue Nov 05, 2019 6:59 pm
That's cool. Missed the memo on the read-only root option in raspi-config. Just as the need of doing it again was coming around for me.
Thanks for the heads up.
LONGJA
Wed Nov 06, 2019 9:10 am
rpdom - that's great that there's now an option in Raspbain. Do you have any idea (or could you point me to) how this deals with the boot and other partitions?
Wed Nov 06, 2019 9:43 am
Have a look at what raspi-config does. It is just a bash script.
Unreadable squiggle
Wed Nov 06, 2019 10:36 am
I would expect nothing more.
LONGJA
Wed Nov 06, 2019 5:33 pm
rpdom - apologies if I'm being thick. Have had a look through raspi-config and I can't find anything that looks like 'read-only-root'.
Please could you point me in a right direction?
I'm using a 3B+, will this have any effect?
Wed Nov 06, 2019 5:43 pm
The bit that looks like it is doing the work starts with
enable_overlayfs() {
If you don't have that then you are not running the latest raspi-config.
Unreadable squiggle
hommar
Wed Nov 06, 2019 5:47 pm
https://www.raspberrypi.org/forums/view ... 9&t=212604
Paul Hutch wrote:
Tue May 15, 2018 1:41 pm
The problem is that the power can be cut while this is happening leaving the uSD card in a non-recoverable state..
Wed Nov 06, 2019 6:54 pm
Yesterday I had no read-only-root option on my Pi 3B
I had to update raspi-config to get it.
LONGJA
Fri Nov 08, 2019 9:49 am
Thanks for your responses, I've upgraded and now have access to the read-only functionality. Now to start testing...
rln
Mon Nov 11, 2019 8:55 pm
Have a look at my project Nard SDK which is exactly what you're looking for. A RAM only embedded Linux distro.
http://www.nard.se/
Author of the robust Nard distro http://www.nard.se
