drifterf
Non Plug Top Power Supply
Tue Oct 22, 2019 5:47 am
Hi, i am looking for a power supply which does not use a plug top as the transformer.
more like a encapsulated power supply. the idea is i want to wire the 240v feed straight into a fused spur for a project.then just normal usb charger into the pi.
thanks
Re: Non Plug Top Power Supply
Tue Oct 22, 2019 6:42 am
Best of luck finding that. Those things do not exist.
You can get a UBEC from eBay, AliExpress or Banggood that will drop 12V down to a stable 5V and build your own based on an old laptop power brick.
PeterO
Tue Oct 22, 2019 6:57 am
thanks
It's not clear what you are trying to do.
At the start you say you don't want a "plug top transformer", then later you say you you will use a "normal usb charger". All the USB chargers I've seen ARE plug top devices ....
Can you draw a diagram or a picture to show what you are trying to achieve ?
PeterO
Tue Oct 22, 2019 7:17 am
I think what the OP wants is something like this:
MainsCable====[power brick]-----MicroUSBPlug
without a mains plug, just bare cable, and no other adaptors/extension leads etc.
Unreadable squiggle
PeterO
Tue Oct 22, 2019 7:31 am
So something like this with a cannibalised USB cable on the output :-)
https://www.rapidonline.com/tt-electron ... s5-90-2501
PeterO
Tue Oct 22, 2019 7:39 am
PeterO
Possibly, but I suspect it needs to be enclosed.
Unreadable squiggle
Tue Oct 22, 2019 8:07 am
https://www.screwfix.com/p/lap-usb-char ... hite/151CC
RPi 4B 4GB (SSD Boot)..
PeterO
Tue Oct 22, 2019 8:14 am
Even better :-)
PeterO
Tue Oct 22, 2019 8:45 am
https://www.amazon.co.uk/Bay-City-Elect ... B01BNGVCC4
Each port will deliver up to 4.2 Amps charge so that you can charge all devices with no worry.
Imperf3kt
Tue Oct 22, 2019 2:38 pm
Note that most laptop power bricks are not 12v, but instead either 19v or 20v
55:55:44:44:4C
52:4C:52:42:41
drifterf
Tue Oct 22, 2019 4:15 pm
PeterO
thanks this is more what im looking for. it will be built in a case anyway. its a access control unit we have done using PIGPIO and Wiegand. the idea is to build this into a automated large sliding gate. many thanks i think im going to try this
Tue Oct 22, 2019 4:21 pm
PeterO
I do use power supplies like the one PeterO has suggested on some of my Pis.
Unreadable squiggle
hippy
Tue Oct 22, 2019 11:05 pm
One of the problems with using wall-mounted USB outlets is they are often proverbial "chargers" not necessarily "power supplies".
I have read forums elsewhere reporting the common problem of voltage dropping as more current is drawn, huge amounts of ripple, and even overheating and turning off with prolonged use.
I guess it's definitely one of those cases of YMMV depending on manufacturer / model.
PeterO
Wed Oct 23, 2019 7:18 am
No longer needed.....
hippy
Wed Oct 23, 2019 9:38 am
Also no longer needed
LTolledo
Wed Oct 23, 2019 10:01 am
so this is a "replacement" for a wall receptacle, and just supply 5v?
will this require (in your area) a certified electrical technician to install (to the wall)?
to use this "off-the-wall" then one will need some wires and a plug.... then it becomes a plugged power supply once its plugged to the wall receptacle...
Some people be like:
PeterO
Wed Oct 23, 2019 10:09 am
No longer needed
DirkS
Wed Oct 23, 2019 10:10 am
One of the problems with these type of supplies is that they are often proverbial "chargers" not necessarily "power supplies".
I think it's insulting to suggest I would post a link to such an item !
I was referencing this -
Then you need to be more careful with your quotes.
Look back and you will see that the quote you're using (from @rpdom) actually is about the rapidonline PSU
hippy
Wed Oct 23, 2019 10:26 am
Fair enough; I have updated my post accordingly. I was merely trying to warn people of potential issues with using wall-mounted USB outlets.
Imperf3kt
Wed Oct 23, 2019 9:39 pm
Don't forget your wet string between the wall mounted plug and your Pi.
55:55:44:44:4C
52:4C:52:42:41
