hitsware
RPi 4 power consumption vs. RAM
Sun Oct 20, 2019 1:53 am
Does additional RAM make for significant additional current draw ?
Additional heat ?
What performance enhancement does more RAM provide ?
Paeryn
Re: RPi 4 power consumption vs. RAM
Sun Oct 20, 2019 3:16 am
The static power will increase (that needed to keep the memory refreshed) but the power needed for accessing the memory (reading & writing) will largely be the same as the bandwidth doesn't change. I'd think the power usage of the rest of the system would make power consumption fairly negligible between having 1GB and 4GB (not that I have any experience in the field so I may be wrong).
As for performance gains, Linux will be able to keep more data in the file caches to reduce disk access times, less likely to run into needing swap space when running memory hungry programs (like browsers with lots of tabs open or big compiling jobs). Pretty much the gains you have in any computer by having more available memory.
hitsware
Sun Oct 20, 2019 3:23 am
Is the RAM on the main (SOIC ?) chip ?
Paeryn
Sun Oct 20, 2019 3:33 am
No, the RAM is on a separate chip. The RPi0 and RPi1 have the RAM chip sat directly on top of the SoC (so it looks like one chip unless you look closely) but for all other RPis they are on different parts of the PCB. The SoC does have some cache memory on-chip for the CPUs but that is nothing to do with the amount of RAM.
hitsware
Sun Oct 20, 2019 5:52 pm
So RPi w/8G RAM is not more apt to thermally ' throttle down ' than w/1G ?
How does more RAM help performance ?
jahboater
Sun Oct 20, 2019 6:02 pm
The maximum memory size is 4GB.
Please read Paeryn's post again.
Sun Oct 20, 2019 6:05 pm
It depends what you are running. Some software needs (wants) more memory than others. If you haven't got enough RAM available it will use virtual memory (swap space on the SD card) instead and run really slowly.
jahboater
Sun Oct 20, 2019 7:17 pm
Also if you are running multiple things at the same time, then obviously more memory is needed.
Sun Oct 20, 2019 7:39 pm
The key here is that if you run out of memory you don't just crash and die. The Linux kernel will rather start swapping what you have in RAM in and out of disk storage. Which is thousands of times slower than running from RAM directly.
This is more likely to happen if you are running a lot of big programs at the same time, but it can also happen if you are running a single program that needs more memory space than you have RAM space.
The end result for the user is that the machine is often much faster with more RAM as there is less swapping or RAM content to disk and back again.
hitsware
Mon Oct 21, 2019 10:29 pm
Thank You Every One ! :D
W. H. Heydt
Mon Oct 21, 2019 11:01 pm
There isn't an 8GB Pi. The largest Pi, so far, has 4GB.
This is not to say that there *couldn't* be an 8GB Pi4B, just that there isn't one on the market.
rin67630
Tue Oct 22, 2019 10:21 am
Frequently for systems running unattended just nothing...
jahboater
Tue Oct 22, 2019 7:17 pm
Unused memory gets used for disk cache.
W. H. Heydt
Tue Oct 22, 2019 8:50 pm
Well...maybe. Given that the system issues a sync command periodically, those disk caches will get cleared. Plus, not all programs write very much, so not much caching may be needed.
jahboater
Tue Oct 22, 2019 10:46 pm
The dirty pages get flushed. Others remain.
Disk reads are cached as well of course (read a file or run a large program for the first time, and its slow because it must be read from the disk. Read the same file, or run the same program some time later, and it will be fast because its come from the cache).
Executable and read-only pages are retained in the cache so that multiple programs can share them. (run multiple instances of the same program, or multiple programs using the same library, and the total memory required is much less than you would expect because the immutable pages are shared).
When your program reads a disk block, following disk blocks are read (prefetched) into the cache automatically and asynchronously so that they are available quickly if needed.
Many filesystems now on Linux are tmpfs which is virtual memory.
[email protected]:~ $ df
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        59G  9.9G   47G  18% /
devtmpfs        1.8G     0  1.8G   0% /dev
tmpfs           1.9G     0  1.9G   0% /dev/shm
tmpfs           1.9G  8.5M  1.9G   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
tmpfs           1.9G  768K  1.9G   1% /tmp
tmpfs            16M  600K   16M   4% /var/log
/dev/mmcblk0p1  253M   53M  200M  21% /boot
tmpfs           386M     0  386M   0% /run/user/1000
Lots of things happen in a modern OS's cache/memory!
hitsware
Wed Oct 23, 2019 3:34 am
The plot thickens :D
