tomexx
Display lxterminal at specific screen location
Wed Oct 16, 2019 4:23 pm
I'm using a desktop shortcut that opens mplayer in a lxterminal like this:
[Desktop Entry]
Type=Application
Name=Webcam
Comment=
Exec=lxterminal -e mplayer tv:// -tv driver=v4l2:width=640:device=/dev/video0:fps=20:outfmt=yuy2 –geometry 50:50 -xy 960
Terminal=false
Hidden=false
The terminal starts and opens mplayer which shows my camera feed. Problem is the lxterminal opens randomly in different parts of the screen and interferes with my video feed.
Can I supply a parameter to lxterminal in the above desktop shortcut that will keep the lxterminal in a specific location of the screen so I can cover it with the mplayer window?
Thanks,
Tom
bjtheone
Re: Display lxterminal at specific screen location
Wed Oct 16, 2019 7:03 pm
Most terminals can be launched using the geometry switch allowing you to specify terminal's size and position (COLUMNSxROWS+X+Y) e.g.:
gnome-terminal --geometry 73x31+100+300
or
xterm -geometry 93x31+100+350
The "X" man page (http://www.x.org/archive/X11R6.8.1/doc/X.7.html#sect6) says
most X programs accept a command line argument of the form -geometry WIDTHxHEIGHT+XOFF+YOFF
The WIDTH and HEIGHT parts of the geometry specification are usually measured in either pixels or characters, depending on the application. The XOFF and YOFF parts are measured in pixels and are used to specify the distance of the window from the left or right and top and bottom edges of the screen, respectively.
However, I took a quick look at lxterminal's man page and am not convinced it has these options. I don't run LXDE so am not super familiar with it. You should be able to install a terminal program that does support location placement.
MarkDH102
Thu Oct 17, 2019 6:19 am
I use xdotool.
You will have to install it.
However, I run it from within a python script that runs in the terminal window and call it using :
import os
os.system("xdotool getactivewindow windowmove 40 35 windowsize --usehints 165 43")
I guess you can call it from the shortcut but I don't know how to get the appropriate active window.
