david_1234
how to fix " 'apt --fix-broken install" error?
Tue Oct 15, 2019 7:19 am
I'm trying to watch netfilx on pi
and did everything is say on this guide :
https://thepi.io/how-to-watch-netflix-o ... pberry-pi/ but it doesn't wrok - and I get this error
Error Code: C7121-1331
when I look for a solution - first thing was to run
apt get update && upgrad
e
but now I get this error:
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 chromium-browser-l10n : Depends: chromium-browser (>= 72.0.3626.121-0+rpt4) but 56.0.2924.84-0ubuntu0.14.04.1.1011 is installed
 rpi-chromium-mods : Depends: chromium-browser (>= 65) but 56.0.2924.84-0ubuntu0.14.04.1.1011 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
what do I need to do?
up until now I didn't have this problem
Thanks ,
p.s
if someone have a working updted guide to watch netflix - I will love to get it :-)
Thanks ,
dickon
Re: how to fix " 'apt --fix-broken install" error?
Tue Oct 15, 2019 7:57 am
I realise that this may come as a bit of a shock, but if you run
the problem just might be corrected.
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
david_1234
Tue Oct 15, 2019 11:28 am
:roll: :roll: :roll: :roll: :roll:
thanks.
didn't help - netflix is still show me error
I will lokk for another guide
bjtheone
Tue Oct 15, 2019 8:05 pm
You likely have library issues plus Netflix is doing something goofy with DRM and blessed platforms. I recently used this method to get Spotify running and it still works with a fully up to date (as of yesterday) system.
https://blog.vpetkov.net/2019/07/12/ne ... chromium/
david_1234
Wed Oct 16, 2019 8:18 am
I have done everything is said in the guide
in the demo webpage I saw the demo movie running , also it said that he detect the and unsing Widvine
when I enter netflix I can see the trailer running in the background ,
but when I want to see the movie I get this error:
This title is not available to watch instantly. Please try another title.
For additional assistance in resolving this issue, please visit our Help Center.
Error Code: M7121-1331
any idea why?
what else I can do ?
I'm using pi3 (but I don't think it should be the problem)
Thanks ,
davidcoton
Wed Oct 16, 2019 8:34 am
So, have you tried visiting the Netflix Help Center?
david_1234
Wed Oct 16, 2019 9:25 am
yes ,
they say to remove all the chrome extensions
and if it's not helping - to reinstall the chrome
I have done all this before - didn't help
Wed Oct 16, 2019 9:29 am
You might get more appropriate replies if you edit the subject line on your first post and change it from "how to fix 'apt --fix-broken install' error?" to "How to get netflix working with Chrome browser?"
(No, I don't know how to get Netflix working, I just think this may get different people to read your post)
Unreadable squiggle
Wed Oct 16, 2019 9:53 am
e
Thanks ,
p.s
Thanks ,
The guide you are following is way out of date, mentions chromium-browser 56, we are now on version 74. If it does not specifically state Raspbian Buster give up following any guide.
There was a recent post in these forums:
https://www.raspberrypi.org/forums/view ... p?t=243900
melisa
Thu Oct 17, 2019 3:45 am
Hi david,
Before this i get problem, and i used this solution. You can try.
After trying
sudo apt-get update –fix-missing and sudo dpkg –configure -a and sudo apt-get install -f
the problem of a broken package still exist the solution is to edit the dpkg status file manually.
$ sudo nano /var/lib/dpkg/status (you can use vim or gedit instead of nano)
Locate the corrupt package, and remove the whole block of information about it and save the file.
Unlock the dpkg – (message /var/lib/dpkg/lock)
sudo fuser -vki /var/lib/dpkg/lock
For 12.04 and newer:
You can delete the lock file with the following command:
sudo rm /var/lib/apt/lists/lock
You may also need to delete the lock file in the cache directory
sudo rm /var/cache/apt/archives/lock
david_1234
Thu Oct 17, 2019 5:43 am
the version of the chrom is 72 and can't be upadte
I will start a new post
Thanks ,
Thu Oct 17, 2019 6:11 am
Thanks ,
You are running the latest supported Raspbian Buster ???
