GaryH1
Raspbian 4.19.75 kernels [Solved]
Thu Oct 10, 2019 11:27 pm
I notice that in /lib/modules there are now 4 directories:
4.19.75+
4.19.75-v7+
4.19.75-v7l+
4.19.75-v8+
I know the original 4.19.75+ kernel is for the early single processor Pis (armv6l) and the 4.19.75-v7+ is for the multi-core processors (armv7l). What are the other two used for (I presume one is for 64-bit) and what are the corresponding codes reported by uname -m associated with them? Thanks in advance for any information/clarification!
fbe
Re: Raspbian 4.19.75 kernels
Thu Oct 10, 2019 11:38 pm
4.19.75-v7+ runs on my Raspberry Pi3
4.19.75-v7l+ runs on my Raspberry Pi4
4.19.75-v8+ runs on my Raspberry Pi3 and on my Raspberry Pi4 if I add arm_64bit=1 to /boot/config.txt
GaryH1
Thu Oct 10, 2019 11:50 pm
Thanks very much for the very quick reply! if it's possible, what does the 4B report when you run uname -m in 32-bit mode and also in 64-bit mode?
Fri Oct 11, 2019 11:08 am
It reports 4.19.nn-V8+ from uname -r
So a cd /lib/modules/$(uname -r) command gets you to the modules directory that's in use.
GaryH1
Fri Oct 11, 2019 1:39 pm
Thanks Dougie for that. What I'm trying to do is to match the output of uname -m to it's appropriate kernel version. It's actually in a Bash script I've written that performs various system updates. At the end it compares what's in /lib/modules/ with the output of uname -r. This is so that if there is a newer kernel downloaded than the one currently running it will prompt me to reboot the system to complete the update.
The way I currently do it is if the output of uname -m is armv6l then it looks at the 4.19.xx+ directory, if it's armv7l it looks at the 4.19.xx-v7+ directory. I don't (currently) have a 4b or a Pi running a 64-bit os so I can't actually get the output of uname -m on those systems to see what I need to test against to direct the script to one of the remaining 2 directories. Hope that makes sense!
Fri Oct 11, 2019 2:28 pm
This awk program splits uname -r "4.19.75-v7+" into "75" and "v7+". That should work on a RPi4B (I'll test it when I've got one of those).
uname -r | awk '{split($0,a,/\./); if (a[4] != "") split(a[4],b,/-/); else split(a[3],b,/-/); print b[1]; print b[2]}'
GaryH1
Fri Oct 11, 2019 3:04 pm
Thanks for that but it's actually the output of uname -m, the "machine name" that I need to know, i.e. on my 3B+ it outputs armv7l. I'm interested to know what that produces on a 4B and also a machine running a 64-bit os as I haven't got either of those to run it on.
Fri Oct 11, 2019 3:13 pm
On my Pi4B running 32-bit Raspbian I get armv7l. I don't have it running 64-bit yet. Also, I'm still running the 4.19.66-v7l+ kernel.
Unreadable squiggle
fbe
Fri Oct 11, 2019 7:42 pm
Output of uname -rm:
Raspberry Pi 3B: 4.19.75-v7+ armv7l
Raspberry Pi 4B: 4.19.75-v7l+ armv7l
Raspberry Pi 3B/4B with arm_64bit=1: 4.19.75-v8+ aarch64
GaryH1
Fri Oct 11, 2019 11:16 pm
Thanks for the info guys - that's a great help. I like the uname -rm option, hadn't occurred to me to use that!
