I'm running a Plex server on my Raspberry Pi and I've run into a problem.
I've got three separate hard drives, all NTFS formatted (in case I want to transfer a large amount of files, then I can still plug it into Windows instead of using the FTP).
All three drives are auto mounted using the /etc/fstab file.
One of the drives works fine, but the other two are getting 'Read Only File System' errors whenever I try to do anything with them.
I've installed all of them the same way. The only differences are that both drives that don't work were used internally on a Windows before, and are connected through a (powered) USB hub.
Does anyone have any idea how to get rid of these errors?
Thanks in advance
