anishh2003
how to switch to user
Tue Dec 11, 2012 2:01 pm
Hi
I have my raspberry pi teminal at
[email protected] pi:/home/pi#
would someone tell me how to change it to
[email protected]~$
An
ShiftPlusOne
Re: how to switch to user
Tue Dec 11, 2012 2:04 pm
You can 'exit' to get back to the login screen, or you can run 'su pi' to switch to the user pi, I think. I would 'exit' since it's the more secure option.
SkyRise
Tue Dec 11, 2012 2:06 pm
You're logged in as user 'root' and have navigated to /home/pi
To switch to the 'pi' user, use:
su pi
This will stay in the same directory as it maintains the current environment
su - pi
will switch user to 'pi' but will re-read the users environment (and will automatically go to the users home directory)
Apologies, I know that makes hard reading...
W. H. Heydt
Tue Dec 11, 2012 7:18 pm
Since I don't know how you got to be logged in as root, I want to add a bit to the previous posters advice...
If you logged in directly as root, then you can logout and log back in as pi. Or you can use "su - pi".
If you initially logged in as pi then used su (or, possibly, sudo su) to change to root, then you can simply log out from root and you'll revert to pi.
anishh2003
Wed Dec 12, 2012 3:01 pm
Hi
Thanks for the replies .
I did log in intially as pi user , and then used sudo .
However I am experiencing this error when I give startx in pi user :
xauth :timeout in locking authority file /home/pi/.Xauthority
but am able to run startx in root .
Please tell me how to fix this problem
I have tried these 2 commands as well :
sudo apt-get update
sudo apt-get upgrade
terrycarlin
Wed Dec 12, 2012 4:38 pm
I am guessing you did a startx as root (sudo) in your pi home directory. /home/pi.
The startx command probably created some files in your pi home directory. If so, when you do a startx as pi, it cant use those files as they are owned by root.
log in as pi, make sure you are in /home/pi and try this command:
<DANGER> If you do this command somewhere other than /home/pi you could really screw up your RPi's OS. </DANGER>
sudo chown -R pi *
This should make pi the owner of all files in that directory tree.
A slightly safer thing to do would be to do a
ls -l
in the pi home directory and change the ownership of any file owned by root to pi. ie:
sudo chown pi .Xauthority
You have to use sudo in this case as some of the files could be owned by root.
Remember, when running as root or doing a sudo command there are no safety checks.
It assumes that you know what you are doing.
If it ain't broke, take it apart and see how it works.
